(#151)
Car: 335i e90
Default 01-26-2016, 03:46 PM
Originally Posted by feauto335xi
each section of carbon was like $50 and with couplers included came to about $250. Probably just as efficient with aluminum, I just liked the idea of the carbon and wanted to try it out. I got everything from http://www.siliconeintakes.com/ but be aware of the y couplers, as they are not quite as close to 90 degrees as the aluminum. The silicone Y is closer to 45 degrees (2.5" inlets) to 3" out where the filter is connected.
Dude, nice job! Way to execute on this.
'07 e90
BeastMode335i's Avatar
BeastMode335i BeastMode335i is offline
Car: 08 E92 335i
Default 02-10-2016, 01:57 PM
And how did you connect the PCV check valve so cleanly..??
feauto335xi feauto335xi is offline
Car: e90 335xi
Default 02-12-2016, 12:09 PM
I literally just drilled a perfect hole (slightly smaller) and forced the PCV into the carbon pipe. Then you can silicone or epoxy it in place. I chose RTV because I wasn't 100% sure about the angle and direction I wanted it and the RTV would allow me to re-position it easier if needed.
Car: e90 335xi
Default 02-12-2016, 12:11 PM
Ooh, does anyone have a 335D fan shroud (air guide) just laying around? I've been looking for one, the benefit would be that the cowl air would be directed to the passenger side opposed to the original driver side..
dmak dmak is offline
Car: 2009 135
Default 02-12-2016, 06:16 PM
Very nicely done. Would u do a diy on it? Can you list out all the parts that you used if possible? I guess there's 2 90degree 2"-2.5" elbows. One of the 2.5" to 3" Y. And maybe 2 45 degree *****? Thx
Car: e90 335xi
Default 02-12-2016, 07:15 PM
They were 1.75 to 2.5" elbows, and my recommendation is to stay closer to 2" if possible (1.75 to 2" on the 90's coming off the turbos) there is such limited space that the extra 1/2 inch isn't worth the heartake and bloody knuckles lol.. I was thinking about building a kit to sell but honestly I don't have the time and the carbon ***** are so expensive, people who want to do this will probably venture out on their own and do some custom fab lol...
mrx35i mrx35i is offline
Car: 135iA
Default 07-01-2016, 09:17 AM
slicksilver which car you get this expansion tank from?
Photo http://www.n54tech.com/forums/attach...1&d=1423527166
135iA 2010 | JB4 G5 ISO
Nicky92's Avatar
Nicky92 Nicky92 is offline
Car: 2008 335i
Default 07-01-2016, 09:36 AM
335d
335- stock
Nosrok Nosrok is offline
Car: BMW 135
Default 07-03-2016, 10:31 PM
Love this mod but I can't find a carbon y pipe anywhere. Anyone have a link or know of a place?
