(#26)
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 01-13-2015, 02:46 PM
Originally Posted by HeavyMetalRocker
I'll have to get with you about the drivability etc etc later after you've had some time behind the wheel! If things don't move forward with fueling etc on this platform than I'm switching over to a C6 Z06. Literally halted my build to see how this kit performs on the street!
dude, it spools faster than I ever thought possible. Its like having stock frame turbos with a lot more power, lot more spool.
Default 01-13-2015, 02:47 PM
Logs!!
robc1976's Avatar
Car: 2007 335i
Default 01-13-2015, 02:56 PM
Logs!!
I have a 50 degree day tomorrow...right now I just spin lol! I cab can try but I will break traction!
HeavyMetalRocker's Avatar
HeavyMetalRocker HeavyMetalRocker is offline
Car: BMW 335i e90
Default 01-13-2015, 04:32 PM
I'm truly excited to see how this thing sounds and performs!!! I have a strong feeling if I end up sticking with this car over the Vette, I'm gonna need to do the M3 rear fender mod to stick some fat rubber back there to hold things down!!!
robc1976's Avatar
Car: 2007 335i
Default 01-14-2015, 08:37 AM
lol!
