Socal Hopeless Socal Hopeless is offline
Car: n54 335i
Default Dyno Today! - e85 Questions - 05-29-2014, 01:20 PM
Nice to meet everyone, first post here.
First off my only mod is a jb4 installed a month ago.
A couple days ago for the first time I ran 35% e-85 on Map 5 and the power is Nuts! I love it, however I'm hitting the dyno shop in a couple hours to get some numbers and I still have e-85 in my tank, I wanted to do a baseline run with Jb4 off as one of my 3 pulls.
Can I run no tune with 35% e-85 in my tank? If so will it effect my numbers much?
Also from my understanding running 35% is safe on an otherwise stock car (On Map 5) is this true? It's making over 15lbs of boost.
Thanks guys
I'll post results, I have till 3:45 PST till I'm on the dyno.
__________________
07 335i JB4 - 35% e85
Default 05-29-2014, 01:23 PM
The E85 will inflate the stock numbers. But dyno is not an exact science anyway.
Car: n54 335i
Default 05-29-2014, 01:59 PM
Thanks a lot Terry, Any thoughts on what % e-85 is safe to run on a stock car? or how much boost is safe without down-*****?
mike
Default 05-29-2014, 02:09 PM
Normally you'd run 40% and map 5. Although map 5 is not always dyno friendly.
Car: n54 335i
Default 05-29-2014, 02:14 PM
Thanks Terry I'll make considerably less power on map 1 vs map 5 on the streets running e-85 right?
Default 05-29-2014, 02:15 PM
Right.
Car: n54 335i
Default 05-29-2014, 06:24 PM
Awesome Day at the dyno! The numbers were really surprising to me, and I'm doubting that this can be safe without down-*****(If you can tell I'm paranoid it's because i went through hell with a mustang), what do you guys think? Thanks!!!
07, AT JB4 E40.
Default 05-29-2014, 08:15 PM
Chart only tells part of the story but looks OK to me!
Car: n54 335i
Default 05-29-2014, 08:27 PM
The fact that for 480$ and some E-85 Fuel (cheaper then 91 LOL) We can make that much HP/TQ (on an otherwise stock car) is absolutely amazing
07, AT JB4 E40.
IBND335i's Avatar
IBND335i IBND335i is offline
Car: 2007 BMW 335i coupe
Default 05-30-2014, 06:46 AM
Bad ass man. I gotta get mine on the dyno to see what im making.
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 05-30-2014, 07:22 AM
Terry - can you elaborate on this?
I'm going back to the dyno today...had issues last time with engine temp and map 5 changes without allowing timing to re-learn.
Shall I go to Map7? I did a quick test earlier in the week 7 vs 5...map 5 felt better after several good runs in 3rd and 4th for map learning. Map 7 is first...
