B58_M240 B58_M240 is offline
Car: M240i
Icon1 New Install | Stock | MAP2 Log Review - 12-17-2018, 02:26 PM
M240 | Shell 93 | JB4 Only | MAP2
3rd gr: looks like DME BT = ECU PSI resulted in throttle close, maybe timing pull at 4sec, and AFR / Trims trending like other logs I've reviewed
4th gr: no closure, maybe timing pull at 7sec, same on AFT / Trims
Nothing making me nervous here, but a second look would be appreciated to check my noob log reading.
Default 12-19-2018, 10:54 AM
Overall it looks good, I'm a bit surprised you have timing drops with 93 on map2. Can you get a log on map 1?
Car: M240i
Default 12-20-2018, 03:24 PM
Thanks for taking a look.
I will get MAP1 log as soon as it's possible. Lots of rain today.
Boba8523 Boba8523 is offline
Car: C
Default 12-20-2018, 11:05 PM
Hi Payam,
Are you referring to the timing drop at around 65-72 range before timing picks back up? Still learning more about reading logs. Thanks!
Car: M240i
Default 12-22-2018, 04:06 PM
Payam,
Thanks again for taking a look.
Attached are a short MAP0 and a MAP1. I'm going to try to get another MAP2, tomorrow, for comparison, after I fill at a different station.
EDIT:
Added MAP2 after Shell 93 fill. Log looks nearly identical to first one I posted.
Merry Christmas, Happy Holidays and HAPPY NEW YEAR!!!!
