(#5451)
DrJason DrJason is offline
Car: Q50
Default 06-16-2020, 01:10 PM
Hello N54 community.
I'm super new when it comes to JB4 because I have only ever did VIP style mods in my previous car-mods.
A bunch of Infiniti Q50 friends recommended me to get JB4 so I did. I do have a quick questions about the maps.
In the first page here, it said
Map3 - 5.5psi peak, suggested for 93+ octane or 30% E85 mixtures.
However - my friend told me we use JB4 Map 3 on the Q50 Luxe/SS with 91 Oct gas.
In short, my question is: is it okay and is it safe for us to use Map 3 on the Q50 Luxe/SS with 91 Oct gas?
Thank you so much in advance!
Default 06-16-2020, 02:41 PM
You should be OK on map3 on an SS with 91, but can always post up a log here and we'll check it out.
Car: Q50
Default 06-16-2020, 06:18 PM
Hi Terry!
Thanks for the reply and thanks for always being so active on this forum. I have been reading through it and always see you here. Thanks for your work!
Ahh. Okay. I just wanted to double-check because the first page said 93 Oct suggested but my friends said we can use Map 3 on 91.
I will definitely do some runs and logs when I can.
Follow up question: Would Map 3 with 91 Oct be okay on a Luxe/SS with aftermarket intake and exhaust?
(I just don't want my engine to knock or damage my engine if I were to try Map 3 to do runs/logs).
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-17-2020, 06:31 AM
First you asked about a stock Q, then a modded Q. Your question is basically the same, the answer is the same. Rule of thumb is bolt ons will assist with adding boost/going to the next map. Map 3 is fine on 91, but post a log so it can be verified that no timing is being pulled/no issues. Are you familiar with how to properly log?
12.64 @114mph
0-60 4.46
Default 06-17-2020, 10:44 AM
Mods don't really change the octane suggestions much.
Car: Q50
Default 06-17-2020, 11:13 AM
Sorry. I didn't know it was the same question or would receive the same answer. I truly thought its a different situation if it was stock and modded with the JB4.
I thought mods + Map 3 would + 91 Oct would increase the APR and cause a knock.
No. Not entirely yet. I'm trying my best to learn through this thread. Again - its my first time actually do anything performance related to a car. Any tips on logging?
Thanks in advance.
Ahh. Thanks Terry!
UNEEK UNEEK is offline
Not a Racer
Default 06-17-2020, 04:35 PM
Hello Community, I have reached 16k miles on my 2019 Q50 Sport, I have been using Jb4 and 91 gas, using Map 5. For some reason it has been lagging a lot, when I floor it I have to wait 2-3 seconds delay for the motor to fully react to what I just did, I have tried taking off the JB4 and put it back on it will work as it should but than next day the power goes back. I have also noticed after going past 90+ the power dies down and it does pull as much almost like the jb4 turns off and it switches back to 300hp, please help
2019 Infiniti Q50 S
Car: q50
Default 06-18-2020, 05:04 AM
Thanks in advance.
IN A SAFE ENVIRONMENT, try to do a 2/3 gear pull as traction and speed allows with the intended map. You must go wide open throttle to really tell anything in the log. Make sure the car is up to temp for oil and coolant, 160* minimum. You will be able to upload the .csv file that can be opened and reviewed for things like boost/AFR/timing and any comments or recommendations shared.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
lyricks06's Avatar
lyricks06 lyricks06 is offline
Car: 2017 Infiniti Q50 3.0t
Default 06-19-2020, 07:46 PM
try running map 4, unless your running 93+ or e30 mix, you should probably stick with maps 1-4. whats ure current mods and jb4 settings?
2017 Q50 Premium RWD *JB4 with Bluetooth, Fuel Wires & EWG Connectors*Drop-In Filters*Megan Lowers (heat wrapped)*Frozen Boost 118*Rev9 CBE with Res.*ADD W1 Oil Catch Can*E30 mix*Megan Front Strut Bar*Hotchkis Rear Sway Bar*
Hofery Hofery is offline
Car: 2018 Q50 3.0T Luxe
Default 06-21-2020, 12:26 PM
Hey guys I tried checking the forum for a concrete answer about the risks of having my factory warranty voided for my 2018 Q50 with JB4 but couldn't find too much. I was wondering if simply removing the JB4 before going in for service or anything of the like would be enough to keep myself safe? I also have an added extended warranty. Thank you!
Not a Racer
Default 06-21-2020, 02:05 PM
Ok will try uploading Map 4 instead, I don't have any add ons just stock and muffler delete that all, still haven't had a chance to log anything since im running thru wire not Bluetooth need to have laptop in hand.
2019 Infiniti Q50 S
Not a Racer
Default 06-21-2020, 02:10 PM
Yes I will always recommend disconnecting jb4 before giving it for service so you don't get asked 1 million questions, the only way they will find out is if you blow your motor and they check the added boost to the psi.
2019 Infiniti Q50 S
Ah ok got it, but everything should be fine as long as I adhere to a max of 7 psi added while running with 93 octane right?
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-24-2020, 04:08 PM
Can someone check my buddy's logs? I think he is over boosting like crazy and causing timing issues. I noticed 21 psi on the logs
12.64 @114mph
0-60 4.46
jrobohm's Avatar
jrobohm jrobohm is offline
Default 06-24-2020, 07:29 PM
Timing is being pulled (likely due to knock) +8 is too high for the fuel he is using IMHO.
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS LDP
  • Fast Intentions Res. Touring 2.5 CBE
  • Mishimoto Oil Catch Can
Car: q50
Default 06-25-2020, 04:32 AM
LOL @ 21 psi at 5k on stock turbos. Assuming pump gas? His AFR is in the dirt, probably trying to keep the motor alive. He's been reading Facebook too much, hasn't he?
Q50 Premium RWD
BMS HE
Low cost LSD
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 06-25-2020, 08:41 AM
Holy cow 142 mph too!!
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-25-2020, 09:02 AM
That's exactly where I found him.. he was complaining about not being able to pull off on a 2015 Accord. Everyone blamed the JB4 being inferior to a tune and I knew something was up. Had him post his Map 6 and it was a nightmare. I gave him my Map 6 and he's shocked at how hard it pulls now. Here's a fresh log if anyone has time to review
12.64 @114mph
0-60 4.46
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 06-25-2020, 09:56 AM
Good thing he found you when he did before he blew out the turbos and/or the engine. Did you tell him he doesn't have to do 140+ mph to get a log also?
jrobohm's Avatar
Default 06-25-2020, 04:24 PM
The 4500 range of timing still looks like the car is struggling with the boost / octane level and pulling timing. He needs better fuel, lower boost, or suggest he add a WMI Kit to his JB4.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8s
  • AMS LDP
Default 06-25-2020, 06:15 PM
Looks too aggressive to me.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-26-2020, 05:15 AM
Well it happened.. my JB4 has a new owner. But, I'm going to stay on this forum and continue to learn/help. I like this community.
12.64 @114mph
0-60 4.46
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 06-26-2020, 12:58 PM
Did you get ECU tune or sell the Q50?
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-26-2020, 01:05 PM
Going to switch to Ecutek
12.64 @114mph
0-60 4.46
JonnyB JonnyB is offline
Car: 2017 Q60 RS400 AWD
Default 06-27-2020, 10:38 AM
Hey guys - just got my JB4 and did some map 6 tests and here are the logs. What I'm not liking is the trims moving like that, should I be worried? Also I did lower the map to spike at 4 instead of 5.5 in these logs after seeing that, but still see the jerky trims, even on map 1.
Ps: 2017 Q60 RS 400 stock ish (just lowered and BMS Heat Exchanger), 93 octane from Canada
