(#5076)
Default 02-24-2020, 09:49 AM
Yes bit0 off means fuel wire are disabled.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-24-2020, 01:29 PM
Do you need any more logs from the new firmware?
12.64 @114mph
0-60 4.46
Default 02-24-2020, 02:52 PM
No we're good to go on that front! Just if an issue comes up.
magnetmiku magnetmiku is offline
Car: q60 rs400
Default 02-24-2020, 09:58 PM
Hi, Terry, I just got my stage1, may I ask should I upload firmware for my q60rs. I tried to upload the firmware that was download from 'https://dev.jb4connectkit.com/v1/firmwarelist.html', but it was failed, and also do I need to change the platform selection from 'BMW N54' to 'OBDII/All other models' in setting page? Sorry for my poor language.
Default 02-25-2020, 10:34 AM
Stage 1 doesn't do any updates or anything, comes as is.
You need the JB4 for updates.
WillisV37 WillisV37 is offline
Car: 2018 Q50 Luxe 3.0T
Default 02-25-2020, 10:45 AM
This new firmware is nice. Love the eco valet. Good work guys, excited for ewg
2018 Q50 Luxe 3.0T
Default 02-25-2020, 12:28 PM
Car: q60 rs400
Default 02-25-2020, 03:31 PM
After I got failed message yesterday, I could not even connect to the jb4 interface, it is said that I have to upload a firmware before I start the motor, so I upload the firmware that was posted on this thread(Q50_STAGE1_2),and now I get cel light on, what should I do for this error.I currently running map3 with 3.5 psi.Thanks.
Default 02-25-2020, 03:54 PM
You would have to get a code reader to check why you have a CEL.
Balakay Balakay is offline
Car: 2018 Q60 Luxe
Default 02-26-2020, 09:21 AM
Hey Terry, quick question about AFR. I had my Jb4 off the car for a couple of months while it was in and out of the shop for an electrical issue, but I just threw it back on and updated to the new firmware this past weekend. I've noticed that sometimes while decelerating, my afr jumps to 25 and stays there for a few seconds before dropping back down. Is that what the notes for the new firmware are talking about? "5) Fixed bug with false AFR reading during decel." These logs are from the auto logging feature, so I apologize for the short duration, but I'm too worried to be fully pushing the car at the moment. One is from last night, the other is from back in December on the old firmware. Thanks for your help on this.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-26-2020, 09:42 AM
It would say 1000 if the gauge went up high. That is normal, thottle closed, no fuel being provided
12.64 @114mph
0-60 4.46
TX_Q50S TX_Q50S is offline
Car: 2017 Infiniti Q50S
Default 02-26-2020, 02:35 PM
New to JB4 and I have some (what I hope to be) basic questions:
1) On the Stillen Turbo Efficiency blog, they reference Stock RS Boost table (max 14.5 psi). Is there anyone with the same type of table for the Stock "Silver" Sport?
2) Or similarly, is there a direct conversion from RS to SS?
3) If I wanted to target 17.5 total max boost on a stock Silver Sport, what is the max boost adder for Map 6?
4) In the BT App for JB4, I see Firmware Version: 50/2//5. How do I "convert" this to JB4_VR30_OBDII_# format to know what is loaded to my unit?
Thank you in advance!!!!
Todd (TX_Q50S)
2017 Q50S, Hemholtz Axel Back, JB4 (fuel wires not installed, yet), always 93
Austin, Texas
Default 02-26-2020, 05:36 PM
Normal as fuel is cut off during deceleration on all modern vehicles.
Car: q50
Default 02-27-2020, 05:34 AM
Todd (TX_Q50S)
Austin, Texas
1/2. SS is set to make about 8-9 psi stock.
3. You need to log it without any adder and see what the car makes and then slowly add boost and see how the car responds. Don't just throw a big number out there.
4. You should always be pulling the firmware file from the 2nd post in this thread which is the latest and the post has a rev history of what changed.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 02-27-2020, 07:18 AM
Quick question on the MPH within the JB4. I have a 2018 3.0t without navigation. I added MPH to the gauge screen on my phone and compared it to my spedo. The spedo reads 1-2 MPH faster than the JB4. It is not a lag issue as I can hold speed steady and it stays with that same delta. I am thinking it is 2-3% difference as it seems to be steady 2MPH at higher speeds (60) and 1 MPH at lower (30-40). Does my car still have GPS that JB4 reads from or is something else at play? Thanks!
Default 02-27-2020, 09:09 AM
The dash and ECU might be getting differently scaled values. I think they usually set the speed to read a little high.
Cali_Q50 Cali_Q50 is offline
Car: Infiniti Q50
Default 02-27-2020, 07:44 PM
can Someone review this log jb4 has been running a bit odd the last few days
https://***********/u/hectorsianez/map-5?log=0&data=1-4
Car: Infiniti Q50
Default 02-27-2020, 07:45 PM
File is now included
jrobohm's Avatar
jrobohm jrobohm is offline
Default 02-28-2020, 04:49 PM
Log with beta v8 firmware - Boost limit by gear test - major help with traction - very cool!!
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS WMI w/ DO7ís
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS Catted FDP (Pending)
  • AMS CAI
  • Fast Intentions Res. Touring 2.5Ē CBE
  • Mishimoto Oil Catch Can
vietnameeh vietnameeh is offline
Car: Q50
Default 03-01-2020, 01:43 PM
Did another pull this morning with fuel wires on
map 5 91 octane
Again felt smooth
3rd gear then shifted into 4th
The car threw a code P0101 I guess it’s a MAF code, cleared it and it seems fine
Does the log look ok compared to my log last week with fuel wires off
2019 lux 5500 miles
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
Default 03-01-2020, 04:11 PM
Nice!
Default 03-01-2020, 04:12 PM
What is the issue exactly? And does it come up on a lower map like map1 or map2?
Default 03-01-2020, 04:13 PM
map 5 91 octane
Again felt smooth
The car threw a code P0101 I guess itís a MAF code, cleared it and it seems fine
2019 lux 5500 miles
Log itself looks OK to me. What intake?
fd3toe46 fd3toe46 is offline
Car: 17' Q50S
Default 03-01-2020, 04:25 PM
Hello...new log on on beta 8. I could not find setting for "boost by gear" so i'm running my current map 6 with tapered boost up to +6. The Valet (Map8) seems to work flawlessly. I'm on 91 octane w/cbe and drop in filter.
Car: Q50
Default 03-01-2020, 04:42 PM
Stock intake
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
