(#5051)
Goodfella Goodfella is offline
Car: Q50
Default 02-17-2020, 06:20 PM
Hate to be the one to ask, but any timeline or idea of a release date of how far out for the EWC?
Default 02-17-2020, 07:13 PM
No set timeframe. Hope to roll out a few test cars in a week or two though.
Car: Q50
Default 02-17-2020, 07:18 PM
Exciting news! Thank you for the update! Please PM if need a test car to test on. My Q sees action every Friday through Sunday. Would love to push it against everything else thats on the playing field!
Lonmon Lonmon is offline
Car: 16 Infiniti Q50 3.0t AWD
Default 02-17-2020, 08:01 PM
Here are my logs with the new firmware. The eco mode worked as expected switching to map 8. It actually pulled pretty good for only 9-10lbs of boost, especially at about 5500rpm or so when timing went up to 10*. My map 6 is pretty maxed out and maybe a little on the lean side. It was about 45* outside and it was only hitting about 16-17psi.
2020 BMW M340ix Portimao Blue
K&N drop in, JB+, Intake muffler delete
2016 Q50 Premium 3.0t AWD (GONE)
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
JB4 W/fuel wires Map 6 custom
E20ish mix made 413whp 410wtq (17-18psi peak)
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-18-2020, 09:07 AM
Add me to the list of beta testers as needed. I'll update my firmware this evening
12.64 @114mph
0-60 4.46
Default 02-18-2020, 10:40 AM
Thx! Working on fueling changes also as that has become more of an issue in our EWG connector testing where we can make a lot more boost down low.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-18-2020, 11:35 AM
More boost down low.. I guess I'll just stick to strictly roll racing now. Traction will be non existent lol
I broke traction badly the other day during a 40 roll
12.64 @114mph
0-60 4.46
Car: q50
Default 02-18-2020, 11:42 AM
How does the factory lean spool mode impact the fueling changes? Are you talking about commanded AFR with the fuel wires?
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Default 02-18-2020, 02:16 PM
lol you've also got boost by gear to limit it in 1st and 2nd.
Still doing development on the fueling end, will post more info when we're ready.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-18-2020, 05:52 PM
That's true.. I only have it set for 1st... lemme get new tires first to get to alleviate the problem lol
12.64 @114mph
0-60 4.46
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-19-2020, 04:50 PM
Some city WOT pulls. Probably not the best data but better here than sitting on my phone unused.
12.64 @114mph
0-60 4.46
Default 02-19-2020, 09:00 PM
Looks nice and slow. Thanks!
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-20-2020, 08:47 AM
Painfully slow lol. The interface is quicker and smoother on my phone too. Good updates
12.64 @114mph
0-60 4.46
jrobohm's Avatar
jrobohm jrobohm is offline
Default 02-20-2020, 08:52 AM
Agreed - log refresh rate update is noticeable with the beta v8 firmware.
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ BM7s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS LDP
  • Fast Intentions Res. Touring 2.5 CBE
  • Mishimoto Oil Catch Can
Default 02-20-2020, 09:48 PM
One option we're exploring for augmenting the fueling system is physically attaching to the high fuel pressure sensor on the back of the engine. It's just a PITA to reach, need to pull a solenoid bracket off the top to reach back there. Waiting on connectors to come in but we'll see how that goes and evaluate if it's worthwhile. Right now with EWG control we've got a lot more power potential but on E85 need to get the fuel trims down to take advantage of it.
Car: Q50
Default 02-21-2020, 12:57 PM
Are you guys using a upgraded lpfp for that E40 blend? When I would use E, I would go up to E30 on stock fuel pump and was great maybe the first 20-30 minutes, then as driving continued, encountered jerking. From there if I use an E mix, I would try and stay around E20-25.
Now I opt for torco or even better boostane. Big difference in using these than E. I will mention I'm aware of the issues with the orange coloring n plugs needing to be replaced. Although, I haven't had any issues with my plugs yet and have been running the octane boosters on weekends, and flush it out with 91 during the week. Just some info thought I'd share from what I've been doing lately for higher boost n race night.
Default 02-21-2020, 12:59 PM
Are you in a really cold climate?
Car: Q50
Default 02-21-2020, 01:11 PM
No, I'm not to far from your location. A bit more south of the border, on the other side of the fence but could say socal area. I notice the car being a bit more responsive as well with the octane boosters compared to E20-25 blend.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-21-2020, 02:06 PM
My exact same experience, 30 was too much and I had bad jerking and sputtering, 23 ran great but I got afraid of the potential damage I was doing that I could not see/monitor
12.64 @114mph
0-60 4.46
Default 02-21-2020, 02:34 PM
Factory low pressure pump on ours currently. The issue is fuel trims not fuel pressure, in most cases.
Car: Q50
Default 02-21-2020, 03:25 PM
I hear you. Hoping and have fingers crossed that it all works out as planned! Even if theres a end result wit a lesser HP gain from EWC,it'd be a great addition to the VR world!
Thank you for the continued updates on this project. Always nice to hear whats going on and how it's coming along!
vietnameeh vietnameeh is offline
Car: Q50
Default 02-23-2020, 04:34 PM
Decided to do a real pull since I was driving at 5am
4th gear
91 octane
Map 5
I also turned off the fuel wires as I keep hearing suggestions that it may not be the best idea for someone on 91 octane
Does it look ok, there was a bit a hesitation when I stepped on it but it pulled smoothly all the way through
(I normally just run map 2, but wanted to see if map 5 would be ok based on someone else local to me is running)
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
Default 02-23-2020, 04:55 PM
4th gear
91 octane
Map 5
It sat in lean spool mode a little down low but pulled smooth and ignition looks clean to me.
Car: Q50
Default 02-24-2020, 08:38 AM
Thanks Terry!
I will try again with the fuel wires on, assuming this log looks like the fuels wire are off LOL
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Geraldomi
