(#11576)
TomLopez's Avatar
TomLopez TomLopez is offline
Default 05-06-2020, 03:15 AM
Hi guys,
I have a 335i E92 for 6 years now with the JB4 installed since 5 years. The car is still in very good conditions and never had any trouble with it except a Lambda sensor that had to be replaced. I also installed proactively Index 12 injectors 2 years ago.
It is currently in Stage 2 with BMW Performance exhaust and a Wagner intercooler. I am using mainly Map 2 with SP98. From time to time and mainly just after the engine has warmed up, after WOT (just after I release the throttle) the blinkers light are flashing and the JB4 goes in rescue mode MAP4. I do not have any codes in the DME.
Can this be related to menu 10 or 12 settings? To me it looks like the boost pressure continues to be too high for half a second after I release the throttle caudsing the JB4 to switch in MAP 4 after overboost detection, I might be wrong but any insight from you is appreciated :-)
Thanks,
Tom
Ness Ness is offline
Car: 08 335xi
Default Trans temp broken - 05-10-2020, 09:58 AM
Originally Posted by Jonny535XI
Good afternoon all: Just upgraded to 32_14_t11 (stable) now trans temp is broken. Anyone else seeing this? Tried searching the threads, nothing recent.
-Update, I downgraded to 32_12 and the issue resolved.
Trans temp is broken for me too with both 32_14_T11 and 32_15_T1. I just installed JB4 on my 08 E92 335xi and couldn't find 32_12 available for download.
BreakMyWallet's Avatar
BreakMyWallet BreakMyWallet is offline
Car: E60 535i Sport 6mt
Default 05-12-2020, 09:00 AM
Any idea why the filenames for my logs changed format? It seems like they still refer to dates, but not the correct dates.
2009 535i 6mt, PURE Stage 2, PSP 900IC, Fuel-It PI, PR N55 location ignition coils, VTT inlets, VRSF things, Injen Intake, RPi exhaust, Walbro 525, EOS BPM4.
MPTUNED335I MPTUNED335I is offline
Car: Bmw e90 335i
Default 4/2 TRANSPORT MODE - 05-14-2020, 08:49 AM
howzit i just did the mhd jb4 back end flash when i put my car into 4/2 it goes into transport mode which is another option i can try to get it into backend flash mode????
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 06-05-2020, 09:09 PM
Iím wondering the same thing. Does anyone know?
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
BMS DCI - BMS OCC - NRW CARBON COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5Ē RACE FMIC
VRSF DPís - VRSF INLETS - VRSF OUTLETS
BMS PEDAL TUNER - RB PCV VALVE - 3.5 BAR TMAP
NGK 97506 @.022 - PFS STAGE 2 LPFP - H&R SPRINGS
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 25 ROW OIL COOLER
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
MISHIMOTO 15 ROW TRANSMISSION COOLER
19Ē 666m WHEELS - HANKOOK VENTUS V12 EVO 2ís
The915 The915 is offline
Car: 07 E92
Default 06-06-2020, 09:52 AM
Please help.... I have been scratching my head on this one so much that I'm losing hair. But I tried to do a log. The car is running like doo doo. Cant get passed code 2D33.
ludo ludo is offline
Car: E93 335i
Default 06-22-2020, 11:22 AM
when on my JB4, it says the range number for meth safety is 0-3
what about the 4th :4 - Run a progressive meth safety on all maps
still available ?
Jaysn54 Jaysn54 is offline
Default 08-10-2020, 05:08 PM
Hey so Iím having issues with the jb4 not connecting to server to download most recent firmware update. This is a brand new unit and m not getting any help other than YouTube. Any assistance would be helpful.
mg3 mg3 is offline
Default 08-26-2020, 10:25 AM
Hello new Jb4 n54 user. I have been looking and can not find the updated steering wheel controll map for latest stable firmware. Found a few on this thread but they are all old.
MG
Default 08-29-2020, 08:31 AM
MG
The one in the first post should be accurate?
Default 08-29-2020, 08:33 AM
For those running meth + flex fuel sensor, I've opened up an extra input on the small 9 pin connector, spot 8, formerly where the clutch wire went that is no longer needed. This new input can be used for flex fuel input with a firmware update. Just email me if you need it and we will include that change in the next public firmware release.
Maffixx Maffixx is offline
Car: 07 335i
Default 08-29-2020, 11:42 AM
Hey, owned my 335i for a couple of months now FBO, recently changed the injectors to index 12's 800 miles ago running mhd stage 2. Yesterday I fitted jb4 followed the instructions perfectly, took the car out today and in every gear it hesitates really bad like there is zero boost running the pump tune bef map 5 changed to map 1 and then 2 both doing the same thing definitely noticeable in 6th there is zero power (manual btw) , changed back to mhd stage 2 and it's better but at some points it feels like the car misses slightly then continues to climb the revs, never done this before hand. Also sounds like the bov is open constantly with the jb4? The car isn't throwing any codes either.
bmwboyee bmwboyee is offline
Car: 2007 335
Default 09-21-2020, 05:26 AM
I have had high battery drain since I installed the JB4. I am on firmware 14. I have heard that many people have flashed to firmware 12 and that solved their problem. My problem is I can't find the firmware 12. The link that is included in the thread shows only 14 and 15.
Is there somewhere I can find firmware 12?
