(#4601)
Default 09-30-2019, 03:44 PM
Looks OK to me. Go for it!
jrobohm's Avatar
jrobohm jrobohm is offline
Default 09-30-2019, 04:08 PM
Originally Posted by WillisV37
I'm pretty happy with map3 so far but if someone could check it out and see if i'm safe to move up to map 5?
What fuel are you using? Have you considered adding the Fuel Wires?
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS WMI w/ DO7’s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS Catted FDP (Pending)
  • AMS CAI
  • Fast Intentions Res. Touring 2.5” CBE
  • Mishimoto Oil Catch Can
WillisV37 WillisV37 is offline
Car: 2018 Q50 Luxe 3.0T
Default 09-30-2019, 04:13 PM
BP 93 fuel. I'll be grabbing fuel wires and lower ********* next
Default 09-30-2019, 04:26 PM
Seriously that's filtered too lol
2018 Q50 Luxe 3.0T
jrobohm's Avatar
Default 09-30-2019, 05:59 PM
On Map5 with pump 93 my 2017 Premium RWD logs we acceptable. Moving up to Map7 required an E30 fuel blend and Fuel Wires. For a whole lot of extra fun - start saving up your spare change for the BMS WMI Kit.
Total game changer on Map8 !!
  • BMS WMI w/ DO7’s
  • AMS CAI
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 10-02-2019, 08:36 AM
Originally Posted by Serstylz2
Epic typo fail, updated OP, reattached log for review
Lol np. Your timing looks ok. Do you have fuel wires turned on? Your trims are maxxed big time and it looks like the AFR leans out in the lower range of each gear.
Yep fuel wires are on and enabled, I seem to always have maxed out fuel... I wonder if they are not functioning properly
Im struggling to see it in the excel at those rows. I see that at 337 you went WOT, but boost looks linear and using the BMS JB4 windows app it looks like boost ramps normally from a 1st gear pull. I can see the AFR go real lean at 4200 but assume thats part of the lean spool. The pedal and throttle both agree (your foot and the allows throttle blade opening).
Separately youre fuel wires almost look like theyre on and off. It doesn't really settle out until mid 2nd gear and then looks like it struggles again in 3rd. Seems odd.
Yesterday I went to do a dragy run and the car wouldn't launch. I warmed the tires, set to map 6, slight brake boost and when i went WOT the RPMs climbed at a snail's pace, then finally got to redline. Never broke traction like I usually do. 0-60 time was 5.22. It was a warm day, at around 93, but my IAT and Trans Temp were both below 100 at the time of the attempt. Is my car broken? No codes are present.
Just as a reminder to myself if nobody else.. when something seems funny, step 1 should be CHECK UNDER THE HOOD. A gut feeling had me pop the hood this morning and lo and behold... my passenger side fuel wire had come loose from the posi tap. The tap is still in the O2 white wire but the black wire was just dangling away. Disabled the fuel wires and will fix it this PM.
12.64 @114mph
0-60 4.46
Car: q50
Default 10-02-2019, 09:17 AM
Hey at least it was a simple fix!
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
SouthFLRS SouthFLRS is offline
Car: 2016 Q50 RS
Default How do my logs look? - 10-02-2019, 02:28 PM
Hey everyone ! I've been reading this thread for awhile now, probably read it twice so i wouldn't have to ask so many questions. From there i hooked up my JB4 and copied some boost profiles from this thread they'll be below and blended some E30 and loaded map 6. Below is my log, everything looks good to me, though i'm not sure what max commanded spark is at WOT with no correction from the BCM or ECU or TCU. Any ideas?
I just plugged in my fuel wires, BTW to anyone reading. On the passenger side, you can pull the 02 sensor wires up and out of the bracket that's holding them down. Once that's done and unplugged from the pigtail you can use two hands to install the fuel wire without much trouble.
I installed fuel wires today, wanted some opinions on my logs before turning on the fuel wires. Bit0 should've been turned off, but when i turned on my car this afternoon it was already enabled? That being said the AFR's in the log might be wrong, i'll turn the boost down tonight and do some logging and see where i'm at..
Also i'm looking for some insight on trims, what exactly are we looking at? HPFP + LPFP duty cycles? STFT ? LTFT ? What's "bad" i couldn't exactly find that out by reading this thread.
Also, how is everyone looking at spark knock? I'm guessing if spark goes from 6-10* (what i'm seeing) to 2* or 0* we can assume the ECU is pulling timing..?
Thanks for the insight! Loved the WMI thread, going to grab some BMS goodies over the next few months and try to keep on learning as i go.
Below is my map 6 boost table. Car feels like it's dying up top, logs look "ok"to me, should i taper it down less in the upper RPM? I wish we could tune the shift points without the ECU being flashed.
1500 - 1
2000 - 1.5
2500 - 2.5
3000 - 3.5
3500 - 4.5
4000 - 5.0
4500 - 5.0
5000 - 5.0
5500 - 4.0
6000 - 2.0
6500 - 1.0
7000 - 0.0
Car: q50
Default 10-02-2019, 02:36 PM
Take a look at TO INFINITI BEYOND - ANALYZING THE VR30DDTT TURBOS | STILLEN Garage
for Stillens recommendation on max boost and some comments about RPM. Plenty are going higher but at least Stillen uses sound reasoning and math behind their claims.
Your fuel wires are definitely working. Any large drops in timing (3 degrees or more except in high gear right around 5000-5200) typically indicate knock. I've seen Ecutek tunes that showed timing drops less than this, but yours increases through the pull which is good.
Sometimes dropping a couple PSI and letting the ECU add more timing can make it feel quicker.
I do recommend the BMS WMI kit as it integrates nicely with the JB4. I did an install with pics that keeps everything under the hood if you decide to look for install options.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: 2016 Q50 RS
Default 10-02-2019, 02:45 PM
I'll keep that in mind thank you! The WMI thread is pretty good, i like how some are stepping up to a bigger nozzle to correct for maxed fuel trims. Mine look okay from what i see on E30. So i'd just use it for the octane increase.
Still need to do intakes, lower down pipe, CBE, and heat exchanger. i'd also like to do BOV's but on the stock tune, i'm not sure how well those would play.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 10-02-2019, 03:03 PM
Glad you made it over to this thread!
12.64 @114mph
0-60 4.46
Car: q50
Default 10-02-2019, 03:27 PM
Skip the intakes.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: Red Sport 400
Default 10-02-2019, 06:50 PM
Are there any updates that can be added to JB4 that can improve performance or is JB4 currently “maxed” out as a tuning device?
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
12.19 @ 115.87 on 93 (Map 6)
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 10-03-2019, 06:23 AM
I don't see you have the meth kit. that can be added
12.64 @114mph
0-60 4.46
Car: Red Sport 400
Default 10-03-2019, 06:38 AM
My bad, meant to clarify. I guess i'm talking more on the JB4 tuning/control side of things not necessarily hardware. I remember reading a while back that JB4 on BMW/Stinger side have more features/control vs the Q50
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
Car: q50
Default 10-03-2019, 11:11 AM
Agreed, not much being shared or future plans other than they said they were working on the flex fuel kit.....which is a disappointment since they just did the meth kit. Would like more PIDS and direct WG control and spark.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: Red Sport 400
Default 10-03-2019, 12:13 PM
So based off of this statement I guess there is still some more room for JB4 to improve in your opinion of course? Staying away from Ecutek is getting harder and harder these days lol
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
Car: q50
Default 10-03-2019, 12:19 PM
Ecutek has PIDs for actual manifold air temps, individual cylinder knock and spark, etc. They should be available on JB4. The only saving grace for BMS is some of the Ecutek tuners raised their prices. Once up rev is sorted it's going to be a viable option at a much cheaper cost.
Q50 Premium RWD
BMS HE
Low cost LSD
Default 10-03-2019, 02:03 PM
The only way to use those is to reflash the ECU as it's the flash itself that adds the logging channels missing from the factory data set.
Car: q50
Default 10-03-2019, 02:26 PM
Does that mean that there are no more PID's going to be added to the platform?
Q50 Premium RWD
BMS HE
Low cost LSD
Car: Red Sport 400
Default 10-04-2019, 05:40 AM
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 10-04-2019, 06:26 AM
Fuel Wires reattached, quick Map 2 and some Map 3 log to see if my previous condition of maxed trims and weird AFRs are now under control.
12.64 @114mph
0-60 4.46
Car: q50
Default 10-04-2019, 07:36 AM
AFR and trims look better once you get out of 1st gear. Looks like some wheel spin or traction control kicked in. Boost is lower than I would expect you to be running, but I guess you did say this was map 2/3.
Q50 Premium RWD
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 10-04-2019, 08:08 AM
I did have wheel spin, you're spot on. And yes, it was 97 degrees here yesterday so my rule of thumb is never to go above Map 3 if the temps are above 90. Tomorrow AM I'll be making a 37 min drive in 50-60 degree weather, all highway, so I'll get another log in Map5/6. Thanks for the quick look.
12.64 @114mph
0-60 4.46
Car: Red Sport 400
Default 10-05-2019, 03:09 AM
Map 6 on 93(Modified Map 2 +6)
Definitely don't plan on doing multiple runs with this map but everything looks okay to me? Would appreciate another set of eyes.
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
Sleeper2017RSAWD
