(#4251)
Car: q50
Default 06-03-2019, 04:16 AM
Originally Posted by Serstylz2
Anyone else experiencing problems with the app? 2nd time in 2 days, I start it up and it loads to Map 5 correctly buy shows my Target (additional PSI request) as 0 instead of 5
Is that at WOT? By the looks of the AFR youre either on decel or in lean spool mode.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-03-2019, 04:23 AM
Either sitting in my driveway or just pulling off. Was just trying to capture a screenshot of the Target parameter. It fixes if you change to a different map (will still say 0) then back to the original map.
12.64 @114mph
0-60 4.46
Car: q50
Default 06-03-2019, 04:33 AM
You're not going to see a target boost at idle or cruise because the car isn't trying to make boost. You have to be at WOT to see the target go above 0.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-03-2019, 04:45 AM
That's strange, it used to show me 5 at all times at Map 5. Also, if I switch off that map to another map then back to map 5, while sitting still, it'll show me 5. I'll take a video shortly
12.64 @114mph
0-60 4.46
Car: q50
Default 06-03-2019, 04:53 AM
That sounds like a firmware bug. I just pulled my log from the drag strip and looked at the target and it didn't sit at a constant number.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-03-2019, 07:18 AM
Originally Posted by Silversport22
Here is the link. Is the the legit JB4 direct from you guys?
https://rover.ebay.com/rover/0/0/0?m...2F264148692109
Yea that's them
12.64 @114mph
0-60 4.46
Default 06-03-2019, 08:51 AM
The target shown at idle will vary based on firmware. At some point we had target showing if pedal input was 0 (e.g. at idle) for informational purposes but not sure how we left it in the latest version.
Esco Esco is offline
Default CANFlap - 06-03-2019, 06:13 PM
Question Terry,
Noticed that on the jb4 mobile app there is an option for "CANFlap". I'm assuming this currently does not apply to us.
jayhawk91 jayhawk91 is offline
Car: Infiniti Q50
Default Map 6 Log review - 06-03-2019, 06:39 PM
Hello Terry,
Would you mind taking a look at a couple of my logs and seeing if there is anything of concern? 2017 Silver sport with AMS LDP and Fast Intentions CBE running 93 octane. Boost is set to 8.0 from 3500-5500 rpm and tapers off to +0 at 7000. Thank you!
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-03-2019, 06:47 PM
Without even looking, boost set to 8.0 needs to be changed
12.64 @114mph
0-60 4.46
djslug2000 djslug2000 is offline
Car: 2017 q60 ss
Default 06-03-2019, 07:08 PM
Anyone know what the SS times are for 1/4 mile with jb4 Pump gas
Default 06-03-2019, 09:03 PM
Originally Posted by jayhawk91
Hello Terry,
I think you'll be better off on map5 here.
Car: q50
Default 06-04-2019, 04:15 AM
highly dependent on the setup and other mods. I went 12.4 with ********* and WMI in not very good air.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-04-2019, 06:38 AM
RWD/AWD changes the responses
12.64 @114mph
0-60 4.46
Car: q50
Default 06-04-2019, 06:58 AM
^^^True this!!! The AWD's are running better times due to better 60fts.
g0t2bmiirii's Avatar
Default 06-04-2019, 08:02 AM
AWD should be slightly better on a 0-60.
Car: q50
Default 06-04-2019, 08:08 AM
Yeah, that's the world of drag racing. Whomever gets out quicker typically runs faster/quicker. AWD even with the weight penalty are putting the power down better so running quicker times. Get some drag radials on a RWD and its a different story.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-04-2019, 09:26 AM
About 3000 miles on these intakes, 4019 miles total on the car. Should I be. concerned?
12.64 @114mph
0-60 4.46
Default 06-04-2019, 09:27 AM
Fairly typical in some climates, they get a lot of airflow! You can clean every 10k-15k miles with a S&B (or any) filter cleaning kit.
https://www.burgertuning.com/product...ning-oil-kit-1
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-04-2019, 09:31 AM
Thanks, I'll pick that up since you all saved me some cash on the maf housing
12.64 @114mph
0-60 4.46
Car: q50
Default 06-04-2019, 09:40 AM
Just keep rotating the filter until all sides are dirty
vietnameeh vietnameeh is offline
Car: Q50
Default 06-04-2019, 12:58 PM
I am not sure why I am such a wuss to do a pull lol
but I tried to log on a freeway onramp
This 2019 Luxe stock 91 Octane Map 1 and fuel wires
I also uploaded a random Map 0 to see how the car works stock
everything look ok? could I try map 2 next?!
It's getting warmer here in CA so I am little hesitant
sorry if the logs suck, I can take another if needed lol
Default 06-04-2019, 01:20 PM
Looks fine to me on map1!
Car: Q50
Default 06-04-2019, 01:25 PM
Thanks! Map 2 next!
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-05-2019, 02:34 PM
12.64 @114mph
0-60 4.46
