(#3926)
jrobohm's Avatar
jrobohm jrobohm is offline
Default 03-02-2019, 12:10 PM
Ouch - looks reparable - do we get a what happened was.. story?
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ BM7s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS LDP
  • Fast Intentions Res. Touring 2.5 CBE
  • Mishimoto Oil Catch Can
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 03-02-2019, 12:17 PM
What had happened was.. it was raining.. I took a right turn and traffic was oncoming.. so I gave it gas.. on Map 5..with traction control off.... back end washed and went up a curb
12.64 @114mph
0-60 4.46
vietnameeh vietnameeh is offline
Car: Q50
Default 03-02-2019, 12:24 PM
Oooo man hope you are ok
IridiumRS400 IridiumRS400 is offline
Car: 2017 Infiniti Q60S AWD
Default 03-02-2019, 12:35 PM
Better tires and a Z1 LSD will fix that problem...
2017 Q60 Red Sport AWD Iridium Blue / Monaco Red / Premium Plus Package 3.0t Sport / XPEL Clear Bra - Full Hood, Fenders, Doors, Mirrors, Rockers, A-Pillars, and Roof & Rear Qtr (Partial) / FI Full D Ps & CBE / Stoptech Trophy BBK FR & RR w/SS-Braided Brake Lines / Infiniti HE / Infiniti Intakes / AMS LPFP & HPFP (not installed) / Ecutek Tune / BMS Pedal Tuner / Infiniti Radiant Sport Grille / EMM Tuning CF Foglight Finishers / CF Duckbill RR Spoiler / Mishimoto OCC / Stillen RSB & SPL End Links
jrobohm's Avatar
Default 03-02-2019, 12:43 PM
On the tires front - LSD is being considered after the WMI upgrade - I am running Dunlop 245/40RF19’s (factory) and am looking at upping them to 255/40’s - but which tire is the question. Suggestion anyone ?
  • BMS CAI w/ Inlets
  • BMS WMI w/ BM7s
  • AMS LDP
Default 03-02-2019, 02:02 PM
Looks like 423 whp is good enough now.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 03-02-2019, 09:59 PM
Thanks man. Not a scratch on me thankfully
12.64 @114mph
0-60 4.46
LsRamAir LsRamAir is offline
Car: '18 Q50 RS AWD
Default 03-03-2019, 02:47 AM
On the tires front - LSD is being considered after the WMI upgrade - I am running Dunlop 245/40RF19s (factory) and am looking at upping them to 255/40s - but which tire is the question. Suggestion anyone ?
Went with Michelin Pilot Sport AS3+ 255/40 here shortly after buying the ride last year, been very impressed with the upgrade. Pilot sports have been my go to for the last 10 years, the best, economical, AND they still allow for light winter if encountered.
The added power from the JB4 overwhelmed my OEMs immediately.
2018 Q50 RS400 AWD (w/Sport Mufflers)
Loving the ride...
Car: '18 Q50 RS AWD
Default 03-03-2019, 02:58 AM
If not much else is wrong, the front bumper is a fairly easy replacement... had mine off recently. Maybe polish your radiators while you're in there! More cooling for JB4!
I did exactly what you did, minus hitting the curb luckily (by inches,) when i test drove my first 2WD RS400... Salesgirl was like "turn off the traction control and really hit it" (she was a lil firecracker!)
I wasn't ready for the surge of power once it spooled up mid left turn... lesson learned! Also, I've been AWD since i can remember... you just get used to mashing throttle 24/7 and not worrying.
Loving the ride...
g0t2bmiirii's Avatar
Default Map 7 Run - 03-03-2019, 07:14 PM
Terry heres a little longer map 7 run i got for my car
monsta121 monsta121 is offline
Car: Q50 SS
Default 03-04-2019, 08:11 AM
@Terry @ BMS can you please take a look at these logs. Both are 3rd gear pulls starting at about 2k rpm.
Mods: jb4 with fuel wires, stillen intakes, megan ldp
Map: 6
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 03-04-2019, 08:18 AM
Probably a bad angle but the fender also needs some TLC. If it were just the bumper I would have grabbed a Sport bumper and gotten to work.
But yes, our stories sound similar, traction control was off and it happened FAST.. happy the headlight and wheels are safe, this should be a quick fix for the repair shop
12.64 @114mph
0-60 4.46
Car: q50
Default 03-04-2019, 12:21 PM
Nice log!
Default 03-04-2019, 12:52 PM
Nice log!
Why its good???
Car: q50
Default 03-04-2019, 12:56 PM
Why its good???
Good long pull with no issues with traction control. No timing drop except for around 5200 where the factory timing table appears to drop. AFR looks good. Looks reasonable to me but I'm not Terry
Default 03-04-2019, 01:12 PM
Yeah i was maybe around 40-50 mph when i did this run. Plus the cold weather helped me out. Im waiting for the weather to get warmer to do another run
Car: q50
Default 03-04-2019, 01:47 PM
I'm waiting for warmer weather as well. I'm running map 6, but would like to try map 7 and compare, but concerned when it gets hot I'll have to drop back.
Default 03-05-2019, 03:04 PM
Look what just came in.
jrobohm's Avatar
Default 03-05-2019, 04:28 PM
VR30 BMS WMI Kit time - Woot!!
  • BMS CAI w/ Inlets
  • BMS WMI w/ BM7s
  • AMS LDP
eltiodolfo eltiodolfo is offline
Car: 2019 Q50 Sport
Default 03-05-2019, 09:43 PM
Terry, could you please take a look at both logs attached? I got a bunch of lights on the dashboard during both pulls. I get a check engine (P0101), traction lights, and the proximity sensors. There are 2 warnings on the gauge cluster. All lights go away after turning the car off and on except the check engine. I ended up deleting the code.
2019 Q50 sport, 900 miles, both 4th gear pulls, 93 octane, fuel wires.
Car: Q50
Default 03-05-2019, 09:54 PM
Dang 900 miles!
I was going to wait for the 1500 mile break in lol
Only have 100 lol
goldstar38 goldstar38 is offline
Car: q50
Default 03-07-2019, 04:29 PM
Terry, please take a look at my log. 93 octane, map 6
Default 03-07-2019, 06:59 PM
Looks fine to me!
Default 03-07-2019, 07:12 PM
You're on a race gas/E85 mix map. Drop down to map2 and log again.
Car: q50
Default 03-08-2019, 06:34 PM
Log check please, map 6 at the track. I can feel and tell it's cutting throttle at the top of 1st. I've heard this is common to prevent over rev.
