(#3901)
g0t2bmiirii's Avatar
Default 02-27-2019, 01:18 AM
Hey Terry besides WMI, what else you working on? Or updates?
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-27-2019, 03:01 AM
In case you missed it, they now have a heat exchanger thst is $299 rather than $399. Stated to be the same exact item, the $299 one is made in China while the $399 product is made in the United States.
https://www.burgermotorsports.com/pr...finiti-q50-q60
12.64 @114mph
0-60 4.46
Car: q50
Default 02-27-2019, 05:34 AM
The $299 one also says "It's a direct bolt in installation and is made in the USA." Why exactly did I spend the extra $100?????
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-27-2019, 06:21 AM
I think it says that only because they copied and pasted the description. Terry already confirmed that the cheaper heat exchanger was made outside of the US with the same parts and quality and yielded nearly identical testing results
12.64 @114mph
0-60 4.46
Car: q50
Default 02-27-2019, 06:58 AM
That's a bit frustrating honestly.
maxlegends maxlegends is offline
Car: q50
Default 02-27-2019, 08:11 AM
Terry we need a meth kit asap before the summer for the q50 . Eta on this? Thanks
Car: q50
Default 02-27-2019, 08:17 AM
Already exists with firmware 7.
JB4 Q50 Q60 VR30 Water/Meth (WMI) Dyno Info - N54Tech.com - International Turbo Racing Discussion
Default 02-27-2019, 08:52 AM
Just waiting for a couple bits to come in before we widely release the kit.
vietnameeh vietnameeh is offline
Car: Q50
Default 02-28-2019, 09:24 AM
For someone who will probably only be running 91 octane 97% of the time (I have access to E85 if I get bored).
Do I really need the fuel wires? I am so tempted now after seeing the 2019 Luxe put down 420whp with E30 LOL
I just leased a 2019 Luxe and have a JB4 coming already.
based on my limited research I assume the jb4 stock +3 map is best for someone who runs 91 octane?
Dc5guychillin Dc5guychillin is offline
Car: Infiniti Q50s
Default 02-28-2019, 09:29 AM
hi Terry, I keep on getting an error message every time i try to update to both the vex 6 and 7.
it says failed checksum testing file: 3135
Read:5126699
Default 02-28-2019, 09:35 AM
Read:5126699
Make sure it's a JB4 you're updating and not a Stage1. And then try holding phone closer to blue tooth kit under the hood to see if that helps.
Default 02-28-2019, 09:36 AM
The fuel wires are optional for those who are concerned with every last 10hp. They will help power on 91 octane but with the extra install effort certainly aren't intended for everyone.
Car: Infiniti Q50s
Default 02-28-2019, 09:38 AM
yes its a jb4 that i have
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-28-2019, 09:42 AM
For $30 and a fairly easy install (in my opinion this was an easy job), it's worthwhile. I also don't see why you can't go up to +5 or +6 with 91 octane. Someone can correct me if I am wrong.
12.64 @114mph
0-60 4.46
Car: Infiniti Q50s
Default 02-28-2019, 09:53 AM
i put the phone right by the bluetooth dongle and it says the same thing except now it says it can't validate my setting and i now have check engine light on and a few others..please help
Car: Infiniti Q50s
Default 02-28-2019, 09:54 AM
I have just a regular stock q50 silver sport with jb4
Car: Q50
Default 02-28-2019, 10:06 AM
You are my problem ...
I just commented on your youtube vid LOL
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-28-2019, 10:10 AM
LOL that's pretty coincidental I must say...
Just do it!
12.64 @114mph
0-60 4.46
Jasonviper Jasonviper is offline
Car: Q60
Default 02-28-2019, 05:14 PM
Did anyone ever post a pic of the clip clearly identified on the passenger side wire harness?
Default 02-28-2019, 05:20 PM
If you need direct support just email is. Include photos of the JB4 control board.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 02-28-2019, 05:27 PM
12.64 @114mph
0-60 4.46
jrobohm's Avatar
jrobohm jrobohm is offline
Default 02-28-2019, 05:33 PM
FYI - IF the JB4 failed to load the firmware then it maybe currently without firmware - thus causing the Christmas Lights on the dashboard. Once you get the JB4 firmware successfully updated - you can clear the codes from the JB4 app. Remember - the car is not turned on (but in aux mode so everything is powered up w/o the engine running) when you are doing JB4 firmware upgrades.
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ BM7s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS LDP
  • Fast Intentions Res. Touring 2.5 CBE
  • Mishimoto Oil Catch Can
Car: Infiniti Q50 RS400
Default 02-28-2019, 08:50 PM
Jb4 Fuel wires - Google Drive
Car: Q60
Default 03-01-2019, 05:32 PM
Originally Posted by Rs400newbie
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 03-02-2019, 11:49 AM
Looks like 423 whp is good enough now.
12.64 @114mph
0-60 4.46
