(#4576)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 05-15-2018, 08:43 AM
Originally Posted by XXXDrive
Sorry. I was talking about when viewing logs, layout
I can talk to Terry about it.
Going to be doing a giveaway to celebrate 1 MILLION views on this thread. Still figuring out the details, but be sure to check back in here over the next few days.
(#4577)
Car: 335i e90
Default 05-15-2018, 01:39 PM
Any idea why I can't upload the new firmware? Keeps saying I need to choose a new time out but nothing is accepted between 10-40.
'07 e90
(#4578)
Bullitt1841's Avatar
Default 05-15-2018, 05:02 PM
What is the logic behind limiting the graph parameters to a maximum of 12? This forces me to not view all cylinders at once. There are no limitations on Terry's Windows interface.
Just curious.
(#4579)
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 05-25-2018, 03:10 AM
On IOS only when you click view on logs it shows blank screen, if you close and open the app few times and try it works after, this been for a while not only on recent version so not sure the real cause but worth to look at if others having the same.
(#4580)
Default 05-25-2018, 10:13 AM
Originally Posted by cnm135i
Can you please implement a real time WMI flow reading while priming so we know when we have full flow?
Great suggestion!
(#4581)
Car: 2008 135i
Default 05-25-2018, 07:06 PM
Shoot me an email. support3@jb4connectkit.com
Just curious.
I'll look into raising that limit.
I'll speak to Terry about it.
Email me at (support3@jb4connectkit.com). We'll see if the beta fixes your issues.
(#4582)
Incrediblewoody Incrediblewoody is offline
Car: 335i N54 2007
Default 05-26-2018, 03:45 AM
So just installed the connect, if the engine is on it works perfectly, as soon as the engine is off the app cannot find the JB4, any ideas on what to try?
I’ve tried restarting app, turning car on and off.
Frustrating as the main reason for the purchase was to update firmware and you need the engine off...
E92 335i N54 2007 UK
Jb4 firmware: 27/15//2
IOS 11.3
iPhone 7
I’m putting the key in so that all the dash lights and i-drive turn on.
I am not able to use he jb4 steering wheel commands either until the engine is on.
(#4583)
Car: 2008 135i
Default 05-27-2018, 06:39 PM
Iíve tried restarting app, turning car on and off.
IOS 11.3
iPhone 7
Iím putting the key in so that all the dash lights and i-drive turn on.
If the steering wheel controls don't work then you're either not turning the ign on properly or you have an install issue. I'd email BMS support for more help on this or post in the support section.
(#4584)
Lonecitizen4 Lonecitizen4 is offline
Car: 2014 428i XDrive N26
Default 05-27-2018, 08:31 PM
Iím either crazy or this is happening to me too. But Iím on N26. Steering wheel controls worked before.
(#4585)
Ryanmlt1 Ryanmlt1 is offline
Car: C450 AMG
Default 06-03-2018, 10:34 AM
Device: Example iPhone 6S +
OS: iOS 11.4
Engine type: W205 3.0 V6
App build:?
Kit Revision: Rev 3.6
JB4 Firmware Version: Not sure didnt install any
Problem experienced:
I purchased the JB4 Connect kit for my C450 and purchased the App. I installed the kit and opened the app. I am getting a Error Validating Device when I try to connect. I checked lightblue and I am getting bluetooth signal. I have reinstalled the app several times and tried a different phone. I still am getting the error. It happens immediately when I click connect.
I selected F-Series and REV 3.
(#4586)
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 06-04-2018, 10:57 AM
Figured I'd post here because the support email is taking days.
It takes up to a dozen tries to connect. Turned on Auto connect, retry to connect a few times, close & reopen app, start over. Have tried this w/ the phone next to the device & in the car but it makes no difference. Hit or miss every time. Is there anything else to try?
Device: iPhone 6 plus
OS: 11.2.5(15D60)
Engine type: S55 F Series
App build: R4P (Default 1234)
Kit Revision: Rev 3
JB4 Firmware Version: 4/17//5
Problem experienced: Can't connect
(#4587)
Car: C450 AMG
Default 06-04-2018, 11:09 AM
Resolved Through Direct Email. Needed Beta version of new App. Sent latest JB4 Connect kit.
OS: iOS 11.4
App build:?
(#4588)
icecoldak's Avatar
icecoldak icecoldak is offline
Car: 2018 F-150 Limited
Default 06-04-2018, 11:21 AM
Maybe its me, but it seems like allot of connection issues with the connect Kit---Has me thinking if I should spend the extra $$$ to go BT if Im going to have issues all the time!
(#4589)
Default 06-04-2018, 02:30 PM
It's worth it, sometimes there are new updates for android or IOS in which Donnie will have to accommodate with the JB4 app as well. It takes time, but I haven't had an issue with connecting to any device.
(#4590)
Vroom's Avatar
Car: 335i 318ti
Default 06-04-2018, 03:24 PM
I'm wondering too, & I already have one.
(#4591)
jaddi85 jaddi85 is offline
Car: Kia Stinger
Default 06-04-2018, 06:29 PM
Dmac,
I sent an email to support, but figured I'd follow up through the forum as well. I'm getting an Error Validating Device when trying to connect to my jb4. I appreciate any help you and offer.
Device: iPhone X
OS: iOS 11.4
Engine type: Kia Stinger 2.0T
App build: 2.3.1
Kit Revision: Rev 3
Problem experienced:Error Validating Device when trying to connect
(#4592)
icecoldak's Avatar
Default 06-04-2018, 06:45 PM
Originally Posted by jaddi85
Dmac,
Device: iPhone X
OS: iOS 11.4
App build: 2.3.1
Kit Revision: Rev 3
looks like the same thing as the other guy above--his fix was:
(#4593)
bucketfoot bucketfoot is offline
Car: 2014 BMW X1 28i xDrive
Default 06-06-2018, 07:04 AM
Device: iPhone 6
OS: iOS 11.4 (also had the issue on previous version)
Engine type: N20 E84 X1
App build: 2.3.1
Kit Revision: Rev 3
JB4 Firmware Version: 70/2//5
Problem experienced: I'm having an issue where my JB4 keeps resetting to Map 0 only when I am using the JB4 Mobile app.
The number on the message keeps changing, but this is what I keep getting:
(#4594)
Car: 2008 135i
Default 06-06-2018, 11:37 PM
OS: iOS 11.4
App build:?
Resolved via email.
OS: 11.2.5(15D60)
Kit Revision: Rev 3
Email me (support3@jb4connectkit.com) and include a screenshot of the error message you get when connecting.
iOS only experiences a connection issue if the BT radio needs to be reset, the kit is too close to a battery, or there is a hardware problem with the kit (if this is the issue I'll replace the kit).
Android connection issues are virtually completely worked out in the current beta so it is basically comparable to iOS at this point.
I rarely get on the forums now as most of my time is spent in development and handling email support. Anyone who needs help with anything JB4 Mobile related please email support@jb4connectkit.com.
Dmac,
Device: iPhone X
OS: iOS 11.4
App build: 2.3.1
Kit Revision: Rev 3
If I haven't spoken with you via email already email me: orders@jb4connectkit.com
Originally Posted by bucketfoot
Device: iPhone 6
App build: 2.3.1
Kit Revision: Rev 3
Lets double check your install first and go from there. Email me at orders@jb4connectkit.com.
(#4595)
as3.0cl as3.0cl is offline
Car: 335is
Default 06-12-2018, 06:43 PM
Device: S9
OS: android 8.0.0
Engine type: n54
App build: Developer
Kit Revision: Rev 3
JB4 Firmware Version: 32.10
After the update, the app will stay on for about 30 seconds to one minute and then completely close out. tried a restart on the phone which worked for about 2 minutes and then would keep closing out every 30 seconds.
2011 335is - Alpine White on Red - JB4+Trebila BEF l BMS DCI l Mishimoto IC l BMS OCC l Phoenix CP l BWS WMI 100% CM5+CM10 l Turbosmart Plumb Backs l N54tech Dpipes
(#4596)
Car: 2008 135i
Default 06-13-2018, 11:02 AM
Originally Posted by as3.0cl
Device: S9
OS: android 8.0.0
Engine type: n54
Kit Revision: Rev 3
The App Build can be found in the Read Only section of the app. If you aren't on the beta, here is a link: https://play.google.com/apps/testing...o91.jb4_mobile
I've started the next round of public releases. Below is the changelog:
Android:
BT connection code overhaul.
Connection type and engine type selections removed. This is now handled automatically so just hit the Connect button and go.
OTG connections are automatically used whenever a BMS Data Cable is detected. This can be disabled (for those who only use a Connect Kit) in the settings page.
Gauge Selector workaround for Note 3 devices on 5.0.
Tons of bug fixes and usability updates.
Auto-Connect changes.
iOS:
Minor bug fixes.
Regarding the giveaway I mentioned a few weeks ago, I'll be giving away a new Rev 3.6 Connect Kit along with a redeem code for iOS or Android. Still working on how to do the actual giveaway so stay tuned.
(#4597)
Car: 335is
Default 06-13-2018, 03:56 PM
Android:
iOS:
Minor bug fixes.
this is with the Beta app version, i am pretty sure because i got the message on the engine type being removed phone is an S8 no 9, mistype.
Interface version on App Read only is A239
Also i can leave the app open and it will not shut off if it is not connected. once connected is where i get the app crashes
(#4598)
razo razo is offline
Car: bmw g30 540
Default 06-15-2018, 11:35 PM
Device: iPhone X
OS: Example 11.4
Engine type: B58
App build: 2.3.2
Kit Revision: Rev 3
JB4 Firmware Version: Not sure brand new just was shipped from Burger yesterday
Problem experienced: I can not get the app to connect to the unit. I can get error that says go to the settings page and select your kit revision, but when I go the settings tab there is nothing there that allows that choice. I just purchased the app from the appstore today and it looks like it was updated yesterday. At this point I can not activate any maps on my g30 540i.
(#4599)
Default 06-16-2018, 08:15 AM
Originally Posted by razo
Device: iPhone X
OS: Example 11.4
Engine type: B58
App build: 2.3.2
Kit Revision: Rev 3
Try emailing Donnie for the fastest support. He doesn't always check the forums.
(#4600)
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 06-18-2018, 12:18 PM
How accurate is that new 0-60 feature under logs?
2007 AW 335i E-92 6AT MMP Stage 3 @ 25psi / JB4 G5 ISO / XHP STG3 / VRSF D-Ps / MMP INLETS&OUTLETS / WEDGE MHD E50 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / PR STAGE3 LPFP 10.92 @ 132 1.72 60ft 6.96 @ 103 1.55 60ft
Closed Thread
wardyl36
