(#9201)
dbrown8958 dbrown8958 is offline
Car: 2007 335i
Default 05-24-2015, 09:42 AM
The JB4 has several active safety systems that will trigger SES light flashes.
The first is the over-boost safety. If boost exceeds the value you've set under user adjustment the SES light will flash once and the JB4 will switch itself to map 4 until you restart the car. The default setting is 18psi. Common causes for this are setting the value too low for the map/intended usage, improperly configured or defective wastegates, or JB4 setting problems.
The second is the run-lean safety system. If your air/fuel ratio (either bank) runs leaner than 14:1 over 4500rpm for more than a second the SES light will flash twice and the JB4 will again switch itself to map 4 until you restart the car. Common causes are maxed out fuel trims (see E85 notes above) or o2 sensor faults. Note any o2 sensor fault must be corrected for the tuning to operate properly.
How do you lower your fuel trims is it possible using the mobile app? Asking because I'm going lean in bank 1?
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 05-24-2015, 02:51 PM
Nevermind - the hex file was in my download folder, not in the BMS folder where I did a save as.
trying to download the hex file on first page but it arrives as "attachment" a php file. Can I select the php file to upload??
brainsurgery brainsurgery is offline
Car: BMW E91 LCI 335xi
Default 05-24-2015, 09:57 PM
Try some other web browser.
Vroom's Avatar
Car: 335i 318ti
Default 05-25-2015, 03:34 AM
IE failed, Chrome downloaded the hex file.
ninjacoupe ninjacoupe is offline
Car: 135i..First of the 1
Default 05-25-2015, 05:44 AM
This happened to me as well. I simply renamed the file with the .hex extension and it uploaded to the JB4 fine. Also using IE
Vroom's Avatar
Car: 335i 318ti
Default 05-25-2015, 06:21 AM
I wasn't that brave to rename & upload...
Default 05-25-2015, 06:44 AM
You can open it in tuner pro and make sure all the information is there. I have the same problem with the XDF files just have to rename the extension after downloading them.
rleroy4298 rleroy4298 is offline
Default 05-25-2015, 01:28 PM
Hey Terry, out of curiosity, are you anticipating any firmware updates in the near future? Thanks!
Bullitt1841's Avatar
Default 05-25-2015, 03:52 PM
Are you having any issues with the current firmware? If not, why ask? If so, email Terry directly.
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 05-25-2015, 11:31 PM
Anyone with RBs seeing a much higher FF with Firmware 29? I'm talking over 100 from a previous 60...
Default 05-26-2015, 07:40 AM
Yes. I was about to start doing some vacuum line testing again, but I think it's just the firmware.
Are you adjusting the Duty Bias values at all?
DSCOFF's Avatar
Car: 335i coupe N54
Default 05-26-2015, 07:50 AM
Duty Bias values remain at 50. I replaced all my vacuum lines including my vacuum solenoids and Vanos solenoids coz I also had a high idle issue with Vanos codes. Logs show no underboosting.
I was thinking maybe the rescale of fuel trims has something to do with it but I could be wrong. My FF is at 118 now and may climb higher still.
Stucks Stucks is offline
Default 05-26-2015, 08:00 AM
+1. my car and my friends car are both seeing ff settling much higher than before with firmware 29. before it was at 50-60 for me, and now i see around 108ish. sometimes as high as 116. I also have vargas inlets as well, so the turbos shouldnt be working too hard at all.
Current: 2008 e92 335i coupe.
DSCOFF's Avatar
Car: 335i coupe N54
Default 05-26-2015, 08:06 AM
I'll monitor it again once my SB kit is reinstalled..
lcvette's Avatar
lcvette lcvette is offline
Default Help identifying this JB4 for updating - 05-31-2015, 07:26 AM
This unit was on my father's 135i when he purchased it and he had purchased a Cobb AP so I bought it from n for my 2007 335i. I finally have a few hours today to install it but was wondering what I needed to do to update it? Not sure what model it is?
I plan on upgrading to the new G5 ISO box and tested the PNP harness per the websites write up and it is the correct harness with correct continuity on the specified pins. Not sure if that may help narrow it down. I am installing it along with the BMS DCI filters and planned to run map 5 auto tuning since we have 93 octane at the pump.
Any other suggestions on updating firmware etc is greatly appreciated!
Chris
fmowry fmowry is offline
Car: '08 135i 'vert
Default 05-31-2015, 09:02 AM
For those of us with a pre 3/1/15 board should we be updating firmware to 28_6 and then run something other than 4/2 after the backend flash? This is for FBO on 93 pump.
I'm getting my car back from getting painted and want to get all my ducks in a row. I've read the DME successfully but have not updated the JB4 firmware since I bought it about a year ago.
TIA
Default 05-31-2015, 10:28 AM
There is very little adjustment that can be done via software. If you are getting kicked into Map 4, you probably have a hardware issue, or are running too much ethanol. If it's just one bank, it's probably a hardware issue.
There is no real help you can get here without posting in the Support Section and attaching a log.
Default 05-31-2015, 10:34 AM
Chris
Pop open the black plastic case with a small screwdriver and you will see if it says 'G5' on it somewhere. If you can't tell, it's probably a G4. Then you will have to purchase the G4 to G5 upgrade through BMS.
If it's a G5, then you want to make sure the diodes are cut or removed. There is a thread on here discussing that. As well as plenty of threads on updating firmware.
Default 05-31-2015, 10:36 AM
Oh, and have fun beating your dad's car with your JB4
Default 05-31-2015, 10:43 AM
TIA
There is no such thing as a "pre 3/1/15 board." You are thinking of the 3/1/15 windows software, or "interface."
If you aren't logging all 6 cylinders, update for sure. If you DO update to the latest firmware, make sure you do it with the latest interface/software. Also make sure all your FF values are set to either 0 or 50.
lcvette's Avatar
Default 05-31-2015, 11:35 AM
Hahaha... This is going on my car (07 335i M6)... The JB4 was on my dads 08 135i A6 when we bought it... Caused quite a debacle as we had purchased a Cobb AP and it wouldn't load.... Called Cobb and they walked us through the procedure and still no load.... They said to send the Cobb back for a replacement. We were standing over the car talking looking st the engine and I noticed a wire that looked out of place wedged with the harness running down the passenger side fender, so I started neatening it up and it was loose near the coolant reservoir... So I started pulling it and found a usb plug... So I traced it back to the ecu box and found there was a jb4 already installed... We had a tune setup with the AP already so we removed the jb4 and I Boughy it... So now I'm putting it on my car... I'll have JB4 dads will have Cobb... Now we'll go beat them up at the dragstrip...lol
Chris
lcvette's Avatar
Default 05-31-2015, 11:44 AM
Well, popped the box open, says JB4 v1.1 -- Burger Motorsports, LLC -- All Rights Reserved
I tried looking for info, but keep getting lost by clicking links inside threads and an not finding the correct info..
wespan's Avatar
wespan wespan is offline
Car: Bmw
Default Wespan - 06-01-2015, 11:39 AM
Originally Posted by robc1976
very good question actually!
Very nice setup!
Can you show pics?
Lemans82 Lemans82 is offline
Thumbs up 06-01-2015, 09:59 PM
Originally Posted by bnd
No more wastegate rattle
I had horrible rattle that involved setting my DWP to 18. I set everything to your listed default values and used FUD 98 and it's wonderful again!
Thank you Terry!
It work perfect for my rattle too ! Before uploading hex29 and set FUD to 98 I was setting steering control 10 to 900 to avoid any rattling resulting in lot of lag in the throttle reponse. Now i can set it up to 3500-4000 without any rattling.
Terry, you are a magician, i'm gratefull and way less embarasse when i cruise down the Boulv. Jb4 is by far the Best 500$ I ever spend on a car, or on everything in my entire life.
weebles weebles is offline
Default 06-02-2015, 01:11 AM
Cant log after updating to latest interface and .iso ?
Just says "starting logging" then freezes up. Any ideas?
