(#9001)
Bullitt1841's Avatar
Default 04-08-2015, 11:04 PM
So far it's been stable so I expect to post 28.82 soon. If you want it sooner just email me. The only real difference between it and whats posted is map 7 when using a back end flash map.
So is there much difference between this new Map 7 and a Map 3 with a 70 ADD?
Default 04-09-2015, 07:39 AM
The new back end flash map 7 is very similar to map 3 w/ a 75 additive.
bmsportzn135i's Avatar
bmsportzn135i bmsportzn135i is offline
Default 04-09-2015, 08:47 AM
And when will this new map7 firmware be released?
537.75HP 540.63TQ
Default 04-09-2015, 08:54 AM
I'd like some more map 7 data so I can determine if we need to ramp it up or down for the average back end flash FBO E85 and/or meth user. I'll throw it in the first post to speed up that process.
seroga1986's Avatar
Default 04-09-2015, 09:20 AM
You can say things are getting serious up in JB4. Awesome! Thanks T!
2008 135i Sport 6at
2013 X3 xDrive28i M-package
suprchrgd's Avatar
suprchrgd suprchrgd is offline
Default 04-09-2015, 09:21 AM
My car seems to be very happy on map7 with the newest update! I feel like this current update is the best my car has ever felt
JB4G5 ISO/BMS E85 Flash, vrsf dp's, vrsf 7" fmic, vrsf cp with tial, 255 walbro inline,e60,alpina trans flash
gzim89's Avatar
gzim89 gzim89 is offline
Car: bmw e90 335i
Default 04-09-2015, 10:00 AM
what does middle and 3/4ths respresent on hijacked boost gauge?im on latest firmaware and interface n i put 1 for n20tmap
thank you
Default 04-09-2015, 10:09 AM
thank you
It depends on your overboost failsafe value (if you are using the 3.5 bar TMAP sensor). Full scale is approximately 10% over the value you enter.
gzim89's Avatar
Car: bmw e90 335i
Default 04-09-2015, 10:31 AM
i have the 3.5bar sensor,my overboost is set at 23psi im on rbs.
so again what is half on gas gauge?how many psi
does it show 0 to 36psi?
Default 04-09-2015, 10:36 AM
With an N20 sensor it's 110% of the boost safety setting. So boost safety set to 23, means full on the gauge is 25.3psi.
gzim89's Avatar
Car: bmw e90 335i
Default 04-09-2015, 10:50 AM
thats perfect terry thank you
gzim89's Avatar
Car: bmw e90 335i
Default 04-09-2015, 11:04 AM
Is fue now called meth trigger?mine is 100 now for some reason,sjould i set to zero since i use meth?
Default 04-09-2015, 12:00 PM
And half of that is 12.65
Default 04-09-2015, 12:02 PM
Meth trigger mode and meth safety mode can both be set to 0 whether or not you use meth. Their values are listed in the notes.
Default 04-09-2015, 12:22 PM
Terry,
So when are you going to output Water Temp and Oil Temp as dedicated logging parameters?
Default 04-09-2015, 12:43 PM
Boring.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 04-09-2015, 02:15 PM
Boring.
I would say a small memory log that retention on size or time would be a great feature in the future, so if it happen that you get error or anything wrong happen while you don't have your laptop plugged and connected then you drive back home you can retrieve those recent saved logs internally and check what went wrong.
Maybe not possible on the existing jb4 but can be an optional option of internal memory, personally I would pay extra $$ for such option if I'm buying new jb4
KeepRidingDirty KeepRidingDirty is offline
Car: 2007 BMW 335xi
Default 04-09-2015, 02:55 PM
What should my AFR bias be set as? Mine are all set as 0, is that correct?
luv135i luv135i is offline
Default 04-09-2015, 03:11 PM
The AFR BIAS need to be changed to on the new firmware?
Default 04-09-2015, 03:25 PM
Boring.
Hey, I need to know how much longer I need to wait before I mash the fun pedal!
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 04-09-2015, 03:52 PM
Is AFR bias used on JB4 only without flash tune?
How to use Duty Cycle adjustment? What are we trying to achieve or prevent?
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
Cloud9Blue Cloud9Blue is offline
Car: 09 E92 335i
Default 04-09-2015, 03:59 PM
Terry,
Water and oil temp is quite critical for some of track goers. Right out the lack of those two logging parameters are about the only disadvantage that JB4 has comparing to a flash only tune for track use.
09 BMW E92 335i: EFR 7670 / Motiv / AP Racing / Wavetrac / TC Kline [Full Modlist]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins
CHECKERED's Avatar
ex deus machina
Car: E92 N54 335i
Default 04-09-2015, 04:13 PM
if you know your low fuel pressure is good, you can used FUD
FUD 5 - Output water temp under low fuel pressure
or
FUD 11 - Output oil temp under low fuel pressure.
Car: 2007 BMW 335xi
Default 04-09-2015, 04:14 PM
It doesn't say so, I just noticed mine are all 0. I think I remember there being numbers there before.
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 04-09-2015, 04:36 PM
0 or 50 is default
