(#7551)
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 09-18-2013, 04:44 PM
Originally Posted by ReefSki
When I try and download the excel doc for steering controls I get;
"Invalid Attachment specified. If you followed a valid link, please notify the administrator"
Try it again.
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 09-18-2013, 07:11 PM
26.6 awesome it is.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
rudypoochris rudypoochris is offline
Default 09-18-2013, 08:48 PM
Hi guys,
Can someone explain the difference between DWP and base duty cycle in more detail?
Background: For the longest time I had been on ISO 17-19 or so and it seems that recently the wastegate tuning has been focused on rattle fixes and not performance or economy. Upgrading to the BB flash and ISO 25/26 my fuel economy dropped from 23mpg to 15mpg. I finally found an ISO 25 setting of DWP 52 and base duty of 2.2 that brings me back up a bit on economy to around 20mpg, but its still not great. If I go to DWP 80 like I used to have I lose about 5mpg and if I go down to 38 or so again I lose 5mpg. The car isn't exactly smooth or snappy on boost response so I am thinking of going back to ISO 19 if I can't sort this out. Thoughts?
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
Default 09-18-2013, 08:57 PM
Make sure you're measuring economy tank to tank using the odometer. I would not be surprised if the DME was very inaccurate with the various flash tuning changes we make on that end. But as a general rule lower DWP (menu 10) will result in less tip in boost and better economy. ISO19 was pretty decent firmware also. I always tell people run whatever works best for them. Half the time when we change something to improve it for customer A we make it worse for customer B. Although, I'm pretty happy with 26.6 currently.
Default 09-18-2013, 09:02 PM
Instead of the SLD stand alone I'd invest in our back end flash, which has an SLD built in to it. You'll need the back end flash for the NLS anyway.
Stucks Stucks is offline
Default 09-18-2013, 09:06 PM
Originally Posted by Stucks
Just uploaded iso 26_5....will try it out on my way home from work tonight and report back. 25 and 26.2 had some slightly violent jerkiness with the transmission that I did not like.
Verdict is that the transmission jolts/jerkiness has disappeared. seems to be fine now. menu 10 is set to 70(3500rpms) and menu 12 is set to 34 (3400 rpms). Cant really tell much of a difference from the previous version my car liked (23g) other than when i let off the throttle, it feels a bit more forceful...whereas in 23g, id let off the gas and it would feel smooth....now with 26_5 i let off the gas and abruptly the car slows down and jerks like the brakes have slightly been applied.
Current: 2008 e92 335i coupe.
Tmos's Avatar
Tmos Tmos is offline
Car: BMW 135i _ JB 4rd
Default 09-18-2013, 10:29 PM
Just loving 26.5 FUD=20 with BMS Pump flash
Awesome responsiveness throughout throttle range with silky smooth gear changes on my MT. No rattle issues as stock turbos have recently been replaced. 10/12 menu settings are 90/25. My car is running better than ever. Once again, spectacular work Terry, BMS FTW!
2009 E82 135i MT | JB4 G5 ISO * TREBILA Performance Custom flash * cp-e CP / Forge Performance DVs * BMS DCI * WAGNER FMIC * Xcede Performance *** * ***** Mids * BMS OCC * BMS Thermostat * BMS CDV * BMS Clutch Stop * RB PCV
robc1976's Avatar
robc1976 robc1976 is offline
Default 09-18-2013, 11:32 PM
Terry, what is default menu 12
kuch335's Avatar
kuch335 kuch335 is offline
Car: 07 335i Coupe
Default 09-19-2013, 04:05 AM
Anything in 26.6 other than FUD=20 being default? I barely have 5mi on 26.5 yet .. lol
2007 335i E92 AT - JB4 G5 ISO + BMS E85 Flash, MR5 Intake, VRSF ***, VRSF 7in FMIC, ER CP, Fuel-It Stage 1, RB PCV, UUC Corsa Exhaust, Sachs SRE Coilovers, M3 Control Arms, H&R Sway, BA Diff Lock, MDF Scoops, Tint, LED Int, LUX V3, CF Hood, Mini Battery
elsabor67's Avatar
elsabor67 elsabor67 is offline
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 09-19-2013, 04:47 AM
Dang!!!!! And I just did 26.5 last night. Feels strong and very smooth power engagement.
Autobahn.......its what's for dinner!!!
Robert's Avatar
Robert Robert is offline
Car: bmw
Default 09-19-2013, 04:48 AM
Originally Posted by Darkcyd335xi
Per our emails T, you know my choice...I'm an FUD=20 fan! I like the throttle logic of ISO 25. I prefer a touchier, more responsive throttle.
Totally agree here. I am still on 25 for a good reason and it works great with AT race flash.
2008 e92/MHD Wedge E85/Alpina TCU /RB Inlets/MMP Outlets/Vrsf DP/Helix FMIC/Forge DV/BMS CP/DCI/Fuel It st2/TBI/TC Kline/Swift SA coils/MF lsd/Hotchkis sway bars/M3 front and rear links/ Diff LDK/AKG Race subf/diff bushings/Megan toe links /TSW18 forged Nurburring/Mich PSS 245/265 /BMW(Brembo)M perf 370mm BBK
P90Puma P90Puma is offline
Car: 08 135i FBO
Default 09-19-2013, 05:28 AM
I didn't buy the SLD standalone I bought the wires for the JB4 along with the relay/wires for NLTS, are you saying they were not required and all I needed was the USB cable + BT cable for the backendflash?
Default 09-19-2013, 02:55 PM
Ships as 27. I run 33 on our 135i as it was a rattler.
robc1976's Avatar
Default 09-19-2013, 03:09 PM
Sissy do you suggest for RB'S...just curious.
Default 09-19-2013, 03:10 PM
Each car is different. Going too high on menu 12 may cause it to oscillate or shift a bit rougher at low throttle. Ultimately as close to 27 as you can get is probably ideal from a drivability perspective.
robc1976's Avatar
Default 09-19-2013, 04:24 PM
This was not supposed to say "sissy" damn auto correct lol!
robc1976's Avatar
Default 09-19-2013, 04:26 PM
I am 90% sure what the setting does....do you mind a passing a quick explanation
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 09-19-2013, 05:52 PM
If menu 12 is too high the jerking is abundant. Past 35 you should feel some jerking. Not driver friendly.
robc1976's Avatar
Default 09-19-2013, 06:06 PM
I know that, I was just wondering what this strong actually does to wastegate position ECT.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 09-19-2013, 07:22 PM
Edit: I fail.
Default 09-19-2013, 07:24 PM
If you want a generic rule of thumb menu 10 is for when boost is < 1psi and menu 12 is for when boost is > 1psi.
Pessimistic Poster
Car: 135i N54
Default 09-19-2013, 07:29 PM
I've had it backward the whole time?
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 09-19-2013, 07:32 PM
But does a higher setting on 12 also mean more closed, like it does on 10?
2013 335is DCT -- Quaife | JRZ RS1 - 450/800# | M3 + Hardrace arms | e93 M3 + Hotchkis f/r sways | BMS CP + OCC | ETS 5" IC | AFE DP's + DCI | RB PCV + Thermo Delete | Setrab + Improved Racing oil cooling | Stoptech f+r BBK | Cobb BQ Tune
Car: 2009 335i AT
Cool 09-19-2013, 07:39 PM
Yes.
robc1976's Avatar
Default 09-19-2013, 07:46 PM
so to high menu 12 would cause wastegate to be to close to early causing jerky throttle.
