e46m3to335i's Avatar
Car: 2015 F22 M235i
Question Easiest way to adjust DP's that are already installed? - 09-03-2013, 11:22 AM
Like the title reads. I'm getting a decent vibration/rattle during left hand turns. Pulled the car up on a set of ramps and dropped the cover to find the rear turbo DP pretty close to the sub frame/body.
What's the easiest way to adjust only that DP without removing and installing everything again, if there is a way.
Thanks in advance!
-Nick
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 09-03-2013, 02:47 PM
If adjusting it is problematic, you could try to kill the rattle by wrapping that DP with header wrap or something, in the are that you think is making contact.
Darkcyd335xi's Avatar
Darkcyd335xi Darkcyd335xi is offline
Car: e92 n54 xi
Default 09-03-2013, 03:02 PM
Problem is depending how much contact it's making, the header wrap will eventually start to wear where its making contact with the subframe. Only way to really adjust it is to loosen the clamp and adjust as necessary. I don't think there would be an "easy" way to do it if you're looking for a more permanent fix. Good luck!
