(#7026)
Default 07-17-2013, 04:40 PM
Some old version had a bug where when saving the meth page savings it would time out and save garbage. So maybe that was how they got scrambled there. Not really much of a concern unless using meth and if you do use meth if one was set wrong you'd know pretty quickly.
robc1976's Avatar
robc1976 robc1976 is offline
Default 07-17-2013, 06:53 PM
24C is best hands down....wow!
bmwsf bmwsf is offline
Car: bmw 335i
Default 07-17-2013, 10:39 PM
Are you comparing it to 24B or to a different update? 24B has been very smooth for me.
robc1976's Avatar
Default 07-17-2013, 10:47 PM
yes, way better...24B was good bit not this good...low throttle changes are just fantastic.
Car: bmw 335i
Default 07-17-2013, 10:53 PM
Thanks for the feedback. I'll update as soon as I can. :-)
Anyone know if 24C works well with the Alpina B3 transmission flash?
2008 BMW 335i | JB4 G5 | BMS Pump Flash | 3" n54Tuning *** | 3" ER Charge Pipe | 5" ETS FMIC
///ADMAN ///ADMAN is offline
Car: 2013 BMW 335is
Default 07-17-2013, 11:31 PM
It has not been much of an issue (e.g. not many cases of deforming reported)
I bet you mine is melted...
2013 BMW 335is Convertible
PhilV's Avatar
PhilV PhilV is offline
Car: 335is DCT
Default 07-18-2013, 08:05 AM
I agree I had to drive to Philly for work (~360 miles ea way). Ran 23G on the way down, 24B on the way back. Much better low throttle smoothness on 24B. Then yesterday I loaded 24C and wow! My car is feels pretty much stock smooth at low/mid throttle inputs. The best yet. My car FBO 335is DCT no meth.
rdub315's Avatar
rdub315 rdub315 is offline
Default 07-18-2013, 08:50 AM
Finally placed my order for the G5 upgrade!
JB4 G5 ISO, BB pump flash, AA down pipe, AE exhaust, ETS FMIC, ETS charge pipe, Tial BOV, dirty Vishnu DCI, BMS OCC
Default 07-18-2013, 09:03 AM
That would not surprise me.
Car: bmw 335i
Default 07-18-2013, 11:40 AM
I agree. 24C has been good to me. I still don't understand why the transmission is being altered with these different firmware updates. Why doesn't it just use the stock BMW transmission logic?
trebila's Avatar
trebila trebila is offline
Default 07-18-2013, 01:30 PM
It's not the transmission, it's the engine behaviour during shiftings which is different.
themyst themyst is offline
Super Demigod
Send a message via AIM to themyst
Default 07-18-2013, 01:38 PM
if I may make a suggestion (please delete if unwarranted)
would it be possible to dial in boost limit cap thru steering wheel controls? trying to run map 5 with E35 or so and it trying to hit 20 psi is a disaster waiting to happen.
E90 LCI N54 6AT
Default 07-18-2013, 01:48 PM
That is a good idea. I'll add it to menu 15 next time I'm in there.
wreckz's Avatar
wreckz wreckz is offline
Car: n54 TOOPL3SS
Default 07-18-2013, 11:27 PM
Just uploaded new firmware 24c great update my ride feels silky smooth
e46m3to335i's Avatar
Car: 2015 F22 M235i
Default 07-18-2013, 11:59 PM
Interesting.
Installed my G5 ISO yesterday and I swear my shifting is not nearly as quick and crisp in manual mode as it was prior to installing it. Its like now there is a sluggish pause during partial and WOT upshifts. I never experienced this prior to the JB4 being installed.
Side note, I have the Alpina TCU flash and have had it coded in my car for about 3 weeks now. I'm running the 24 firmware. After reading most AT guys feel this firmware is smoother than 24B and 24C.
-Nick
Xshadows Xshadows is offline
Car: 2008 135i
Default 07-19-2013, 06:17 AM
Went from 24 to 24C last night and did some driving around. Feels way better. Keep up the good work Terry!
BrewRifle BrewRifle is offline
Car: 2009 135i
Default 07-19-2013, 08:00 AM
Xshadows are you driving a 6MT or AT? I'm on 24 (A) and wanting to know if going to 24C is worth it for a manual transmission.
Car: 2008 135i
Default 07-19-2013, 10:23 AM
Manual.
DRZZZ DRZZZ is offline
Car: 2009 335ix
Default 07-19-2013, 01:21 PM
No logs, but 24c is smoother for me too. No more CELs with low throttle so far (DCI, 30% E85, AT)
jim66 jim66 is offline
Car: 335is
Default 07-19-2013, 01:52 PM
24C working great for me as well. smoothest yet!
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 07-20-2013, 06:43 AM
ok so it's getting hard to find info on the G4. I've been out of the n54 scene for a little while. I'm building a 135i for a buddy. On the JB4 interface it has FUE=100. I can't remember what this is and can't find it on here. Does anyone know where i can find the list of FUa,b,c,d,e setting?
2011 335is DCT, FBO
aoschadlin's Avatar
Car: 535i
Default 07-20-2013, 08:36 AM
I could be wrong, but I thought those Future Use values often changed from one firmware release to the next?
Latest obsolete firmware in case it helps http://www.n54tech.com/forums/showthread.php?t=20161
I was going to post an old FutureUse text file, but couldn't find it anymore.
Default 07-20-2013, 09:51 AM
Originally Posted by OldBooster
I know this story has many incorrect or out of sync memories, and I would love them to be corrected so we can get the evolution correct. I am called "Old" Booster for a reason. And I hope this answered your question.
It's definitely been a long evolutionary process. I can't recall the dates but can give you the approximate order in which the N54 tuning hardware was released.
1) Do it yourself "Terry Tuner" -- The one that started it all!
2) JB1
3) JB2
4) "Hot pill" add on to JB2 to allow another pound of boost. JB2H.
5) "Race gas switch", bumped boost up another 2-3psi. JB2HR.
6) Combined 3, 4 & 5 in to something called the JBX.
7) JB+ quick install tuner
8) JB3 - G1
9) JB3 - G2
10) JB3 - G3 (added datalogging)
11) JB4 - G4 (added CAN)
12) JB4 - G4, 15ohm version
13) JB4 - G5
14) JB4 - G5 ISO
OldBooster's Avatar
OldBooster OldBooster is offline
Car: 2008 135i AT
Send a message via Skype™ to OldBooster
Default 07-20-2013, 10:01 AM
Thanks Terry. Whatever was current in May, 2009 when I jumped in, is when the magic started for me. I was hooked!
Terry's unmatched dedication to the N54
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 07-20-2013, 12:09 PM
24C is arrest me smooth. Just got my car back from BMW. Went in for the battery cable recall, they also updated the ECU software & put in a new HPFP all on Warranty.
Got the JB4/G5/ISO back in this morning, loaded 24C & went for a test drive. Have a long straight flat approach to my exit of the interstate. Went to WOT on the exit & was thinking the car is kind of slow.
Then I looked down & it was passing through 125mph. Had an old timers memory fart & forgot I started at 80mph. The push was so smooth it did not feel seat of the pants that it was accelerating that quickly.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
