(#1026)
Trevor008's Avatar
Trevor008 Trevor008 is offline
Car: 07 e92 335i
Default 01-31-2011, 09:28 PM
Hey T am I understanding the new feature correct in that if you have boost limit set-up and you use the steering wheel volume or talk button while driving, the bost limit will be disabled? Or do you have to be in set-up mode to disable it?
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 01-31-2011, 09:42 PM
Nice just downloaded and gonna try it out this week, i will try to get some logs by the end of the week!
The boost reduction new setup sounds NICE!
2014 F10 535i N55 PWG
Default 01-31-2011, 09:49 PM
Right, press down on the volume button or the talk button to disable the 1st and 2nd gear boost limiting. Like if you are trying to do a burn out at the track.
ace008 ace008 is offline
Default 01-31-2011, 10:18 PM
Quick question on the firmware updates, does the car engine have to be on when connecting it to the JB4 interface?
shoes's Avatar
shoes shoes is offline
Car: 07 BSM E92 335i
Default 01-31-2011, 10:20 PM
Ignition on, engine off.
Default 01-31-2011, 10:25 PM
Hmm how do I turn the ignition on? The key is in the car, engine is not on, but fails to connect unless I turn the engine on as well.
iv55 iv55 is offline
Car: 2007 335i coupe
Default 01-31-2011, 10:29 PM
Push the start/stop button with the key in the ignition and no feet on the peddles.
SlicktopTTZ's Avatar
Turbo Lover
Car: 300zx TT, 1M
Default 01-31-2011, 10:33 PM
To make sure, I like to start the car, connect the interface, and then press the ignition shortly once. This will stop the engine but leave all other electronics on. (Ready for ignition)
Default 01-31-2011, 10:36 PM
How does adaptive PID / feed forward scaling work with switching between maps? Will it have to relearn every time I switch?
Default 01-31-2011, 10:37 PM
It's always on and adjusting and does not reset or need to reset with map switches.
Default 01-31-2011, 10:43 PM
Worked like a charm! Thanks!
Default 01-31-2011, 10:57 PM
T, I apologize if I'm behind the curve but can you expand on the "Lowered range in lean run safety"?
I have no idea what this is.
No prob
Default 01-31-2011, 11:29 PM
For the boost reduction in 1st gear, what do you guys like to set it at to get the best possible traction? I got some pretty decent tires, vredesteins 275s in the rear, but when full boost comes on, even on map 1, I spin the tires? 10 PSI max on 1st gear? Also, what rpm do you usually shift at for a 6mt? Is 6200 rpm still the best shift power to get the most power a near stock for with *** back and DCI.
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 02-01-2011, 09:59 AM
Try 10psi as it wont go under stock target either way.. See if you can go WOT on 10psi, i would'nt go lower IMHO, usually in warm wetahter with 275's, you should stick.... In first gear Red line shifting is good.
Default 02-01-2011, 10:23 AM
10psi is a good boost cap for 1st gear on street tires.
Jeff@TopGearSolutions's Avatar
Jeff@TopGearSolutions Jeff@TopGearSolutions is offline
w00t
Default 02-01-2011, 10:33 AM
10 psi with traction in the winter would be nice
Specializing in Aftermarket Performance Solutions for BMW 135i 335i and 535i
mcc mcc is offline
Car: 335xi
Default 02-01-2011, 01:14 PM
This may be a terribly asinine question but while using the the JB4, is the CANtool needed to access all the parameters or is the JB4 capable on it's own? Thank you
Default 02-01-2011, 01:29 PM
On its own the JB4 can do everything the CANtool can. With JB4 there is zero need for the CANtool
elsabor67's Avatar
elsabor67 elsabor67 is offline
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 02-01-2011, 02:01 PM
Just downloaded the updates also. Gonna try to see if I can do some logs on teh way to work and on the way home and then do the update and see the differences and send these up.
In the last couple of days that I have been driving on MAP 1 I can definetly tell that it will maintain the stock boost levels until the engine is warmed up. After that, all I can say for now is that I wish April was here so I can lay down better rubber on the road.
Autobahn.......its what's for dinner!!!
Default 02-01-2011, 02:44 PM
No the CT is no longer needed!
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 02-01-2011, 04:27 PM
Just curious, but did you guys change anything in the way the throttle adjusts in cruise control? If you are in cruise control and shift gears, the time it takes for the car to automatically re-apply throttle seems to be greatly decreased now.
Just an observation
whitecord whitecord is offline
Car: 135i msport
Default 02-01-2011, 05:32 PM
i am having trouble downloading the new interface. it said compressed fold is invalid or corrupted. 1/1 downloaded fine still?
CBR335 CBR335 is offline
HP addict
Car: 09 E92 335
Default 02-01-2011, 06:21 PM
No problem here. Just delete the compressed folder, download it again and unzip. Make sure the folder is saved with the .zip extension.
xbox_fan xbox_fan is offline
Car: BMW 335i E92
Default 02-01-2011, 11:39 PM
I'd recommend running the usb cable through the bottom of the ecu compartment into the glove box, there is a diy somewhere and it was very easy to route it this way. If youre installing the JB4 it is only a few minutes extra to do it properly...
HondaGoneRogue's Avatar
HondaGoneRogue HondaGoneRogue is offline
They like my swag....
Default 02-02-2011, 06:31 AM
+1 There is a DIY on youtube. It's cake.
http://www.youtube.com/watch?v=PRSptRTQmt8
