Car: 535 2008
new map 6 goal is 26psi -
02-16-2022, 08:03 PM
Hey yall looking for some feedback on these runs. I also have meth setup but not active should I use for lowering intake air temps?
currently straight E85 fuel
Pure stage 2 turbo
Dorch stage 2 HPFP
Fuel it stage 2 LPFP
VRSF intercooler
VRSF down pipe
MST intake and filter
FTP piping,inlet, boost pipe, etc
Burger charge pipe
2015 535 - JB4 - Pure Turbos Stage 2 - VRSF DPipe- Burger Intake - Straight piped - MHD Backend Flash - BMS Meth - VRSF Intercooler - VRSF Charge Pipe - Dorch Stage 2 HPFP - Fuel it stage 2 LPFP
Car: 2008 E93
02-16-2022, 09:39 PM
Pure stage 2 turbo
Dorch stage 2 HPFP
VRSF intercooler
VRSF down pipe
Burger charge pipe
Wrong sub forum
Car: 535 2008
02-17-2022, 05:17 PM
Wrong sub forum
oh yea thanks for letting me know, i think someone moved it over for me now to correct sub forum
02-18-2022, 11:10 AM
I moved it but stick to 1 support thread and one or two logs for assistance.
Car: 535 2008
02-20-2022, 02:22 PM
oh ok i thought since upping boost new thread sorry. heres 2 runs i just did at 26psi and i am running straight E85
Car: Evo VIII
02-21-2022, 02:22 PM
Log looks solid.
Car: 535 2008
02-21-2022, 02:25 PM
Originally Posted by Cannon @ BMS
Log looks solid.
Awesome thanks for feed back. and another question some people have told me to keep my meth injection system for summer IAT to bring them down do you think its necessary. or can I even increase boost more with Meth?
Car: Evo VIII
02-22-2022, 01:11 PM
Meth will always help bring down IAT's. As far as increasing boost...What transmission do you have? I would also recommend taking the car to a dyno to see what it makes if you plan on running meth in the summer. Highly recommend to keep the car under 600 whp.
Car: 535 2008
02-22-2022, 03:00 PM
when i was at 25 psi, i made 503 whp and 560 tq on a dyno jet, havent dyno since i bumped to 26
Car: 535 2008
02-22-2022, 05:02 PM
I have the auto 8 speed transmission with XHP stage 3 Flash
Car: 535 2008
do you think i have room to bump it up to 27 psi? -
03-02-2022, 11:40 AM
do you think i have room to bump it up to 27 psi? based on this map
03-02-2022, 11:50 AM
Timing looks pretty good but your WGDC is getting pretty high.
Car: 535 2008
03-02-2022, 02:22 PM
and running it high would cause failure? so what would you suggest?
Car: Evo VIII
03-03-2022, 10:42 AM
Absolute failure, no. Naturally, the more boost you run could shorten your turbo lifespan.
What sparkplugs are you currently running and what's the gap?
Raise all Duty Bias Values +5 and post another log.
Car: 535 2008
03-04-2022, 12:47 PM
ill do a log with updated figures tonight, im running iridiums NGK 97506 2 Step Colder and gapped to .20
Car: 535 2008
heres a log -
03-05-2022, 12:00 PM
heres a log
Car: 2014 435i
03-21-2022, 08:17 PM
IMO Logs looks strong but seems like you are about maxed out.
I'll be curious what the BMS experts thoughts are when they respond.
Either way, strong setup and tune.
Car: Evo VIII
04-04-2022, 02:17 PM
heres a log
Log looks good. It would appear your turbo is giving everything its got. Do you have a full exhaust?
Car: 535 2008
04-04-2022, 04:24 PM
yes full exhaust i believe 3" all the way back and i added 2 resonators to quiet it down
Car: 535 2008
04-07-2022, 01:56 PM
How do I turn my methanol/water injection back on in the settings? And what settings and numbers do you recommend I want to use it for cooling the iat’s since it’s hot here in Southern California. I run a 50/50 mix and have a size 10 nozzle I believe thanks ahead of time
04-11-2022, 10:29 AM
Meth Safety Mode:
0 - Raise boost as a function of meth flow & historic timing (default)
1 - Raise boost as a function of meth flow only
2 - Start at high boost target and reduce IF flow drops below flow level for 1 second under boost.
3 - Start at high boost target and disable all safety systems. Meth flow is completely ignored.
Meth Trigger Mode:
0 - Meth flows on maps 3, 6, and 7 (default operation)
1 - Meth flows on all maps
2 - Meth flows on map 3 only
3 - Meth is disabled on all maps
4 - JB4 bypass with meth control
Set scaling to 60, min boost to 6 or 8, and additive to 50 to start if running map 3.
Car: 535 2008
04-11-2022, 11:20 AM
thanks Steve
