On auto sports shift and S or S+ (Not comfort or eco) up shifts are rough and hesitant. As if I were to let off the pedal for a microsecond and boost dropped, then spooled back up. It’s less apparent st WOT than just normal-fast driving. Not present
I see throttle dropping after shifts, sometimes significantly. Ignition also.
Current settings are standard excerpt for wastegate. Moving that around doesn’t change the issue.
Spark plugs are brand new and I’m waiting on de coils. Running 91 octane.
Edit: running map2. Smoother than map1. Changing map 1-2 doesn’t change the issue either.
Thanks in advance!
Reason: Added logs
Set your shift reduction back to 60 and you could try raising it to see how that does. You could also try switching to an absolute target map to see how that affects it.
