135idct 135idct is offline
Default map sensor 3.5 problem n55 EWG - 11-03-2018, 01:46 PM
Tried two new n20 3.5 map sensor to push 20+ psi, switch on the n20 option to 1 in jb4 setting still not work, i see drivetrain and those codes can't delete them.
121533 boost pressure sensor, plausibility: Pressure upstream from throttle at motor stand
121202 boost pressure sensor, plausibility, caster: pressure too low.
and rough idle
when i install back the 2.5 OEM sensor everything is fine.
What would be the problem?
3.5 sensor part# (13627843531)
running n55_EWG_RACE_BEF
Default 11-03-2018, 05:14 PM
Something with the flash probably. If you somehow flashed it for a non-stock sensor it can be difficult to unflash that settings. May need to flash to stock, then reflash again, etc.
If that isn't it then maybe something is wrong with the sensor itself.
Default 11-05-2018, 09:16 PM
is it related to jb4 firmware? im running EWG_15 not the latest one.
any bugs with the 15 firmware about the 3.5 map sensor?
