(#976)
Single Snail Single Snail is offline
Car: 2011 135I N55
Default 09-27-2018, 10:14 AM
Your intake and Intercooler you offer. I've just replaced the seals on both sides of the intercooler trying to track down this fault.
beetran beetran is offline
Car: 135i N55
Default 10-12-2018, 12:04 AM
Hi Terry,
I have downloaded the map pack for N55 but cannot find E85_PI_ST.
Could you please kindly check for me please? I am building a top mounted EFR 9180 with FBO, PI, Stage 3 pump and planning to run 100% E85.
Thank you for your help
C2YT C2YT is offline
Car: 2011 e90 335i
Default 10-12-2018, 05:41 AM
Well dang.
You are probably going to want to start with a base map and then adjust. That is quite a wild setup. Maybe @jturboawd could point you in the right direction.
Jus2sikwitit Jus2sikwitit is offline
Car: E92 335i XDrive MSport Coupe
Default 10-26-2018, 09:33 AM
I downloaded newest bef. There is no THR map for 98g0b. Only e85_thr. I want to try factory throttle mapping to see a diff between that and pump bef
E92 LCI, N55, JB4, MHD W/BEF, CAI
paolotonzini paolotonzini is offline
Default 10-26-2018, 10:49 AM
@Jus2sikwitit I emailed Terry from bms for that havent herd back yet
lazer's Avatar
lazer lazer is offline
Car: 135i n55
Default 11-19-2018, 01:02 PM
Im running fbo ps1 on 91/93 with 50/50 meth injection on pump flash. I saw on the first post i should run the e85 PI flash. Thats right? 50/50 water meth is good or i should mix more meth
135i 2012 6speeds n55/FBO/ps1/inlet/stg2 lpfp/bms meth
Pump flash
N55_ N55_ is offline
Car: BMW 335i
Default 12-14-2018, 03:23 PM
Hello everyone, having some issues hitting boost.. car drives fine with no misfire and boost leak.
I flashed MHD stage 0. Then flashed the original 98G0B pump flash. Stage 0 flash took 30min. BMS flash take about 45 seconds. Its named pump flash so Car has *********, chargepipe , and JB4.
Car: BMW 335i
Default 12-14-2018, 03:26 PM
I also attached two CSV files.
Default 12-14-2018, 04:55 PM
What chargepipe? oring or WMI cap missing?
Car: BMW 335i
Default 12-14-2018, 04:57 PM
BMS chargepipe. O ring is in place.
Checked intercooler connection and itís tight too.
Supermand333 Supermand333 is offline
Car: 335xi e90
Default Log - 01-15-2019, 02:20 PM
Need help with these settings.
Default 01-15-2019, 02:37 PM
You can make a thread in the support forum with details. As is not sure what your problem is. Also on the logging you can uncheck raw sampling unless there is some specific reason it's on. Makes logs harder to read when on.
xradeon xradeon is offline
Car: BMW 135i M Sport 2013 N55
Default 02-06-2019, 10:35 AM
Hi guys! My JB4 died recently after almost a year using it, I bought it from second hand so no warranty for me... So I went MHD Stage 2 maps route...Now I'm getting a CEL light for the ******* down pipe. How can I get rid of it? I thought MHD maps should get rid of the cel like the JB4 does
JB2 JB2 is offline
Car: BMW 135i M-Sport
Default 02-06-2019, 03:31 PM
You'll need something like this (just make sure to get the right one for your engine):
https://www.vr-speed.com/vrsf-******...-bmw-335i.html
JB2 JB2 is offline
Default 02-06-2019, 03:32 PM
Some of the link got masked but you can find it from the home page.
Default 02-06-2019, 05:27 PM
A new V2 JB4 board is only $175. But that won't solve your issue. For those specific faults you'd have to code them out of MHD using TunerPro. Illegal to do in the USA of course.
Spoolin335i Spoolin335i is offline
Car: 2012 335i
Default 02-13-2019, 10:37 AM
So I finally installed the Pump BEF and I just want to say that it is night and day! Much smoother and more responsive. This may be a stupid question but how is it that the transmission is much smoother in terms of shifting now? DS mode no longer jerks and have the harsh 2-1 shift when iím Just casually driving around the city. DS mode is so much better now and just for casual driving I leave it on DS now. I have the Alpina B3 flash. Can anyone explain why is it so smooth now after the BEF?
