(#26)
KLR STINGER KLR STINGER is offline
Car: Stinger
Default 02-11-2020, 01:31 PM
Starting to work on a PID control system for the EWG control. Those running them can drop me an email if they have time to log the latest firmware.
Does the PID control setup remove the ability to manually adjust DC at RPM intervals? like is it adjusting DC based on PID feeback from map sensor?
Default 02-11-2020, 05:02 PM
Not at all, the user adjustment becomes the feed-forward profile, or in other words, the baseline the PID is operating off of. And then WGDC is the output which will vary based on boost vs. target, or in this case ECU_PSI vs. modeled DMEBT.
Car: Stinger
Default 02-11-2020, 05:16 PM
Ah.. ok. That makes sense. Was wondering what the feed control was in the PID.
Default 02-11-2020, 05:30 PM
For those who installed the EWG connectors how was the sample harness length? Ideally we want to make them both the same length to make manufacturing easier so the passenger side will need to have the slack tip-tied together.
Vortex3.3 Vortex3.3 is offline
Car: Genesis g70
Default 02-12-2020, 08:19 PM
Will there be any benefit to using this set up on a car that still has oem primary cats?
atr1 atr1 is offline
Car: Stinger GT
Default 02-12-2020, 10:42 PM
It was ok but it did not leave much choice for the routing of the driver side but it worked fine for me. The passenger side is too long as you said, but we can just stack and zip tie, so it is also not a big problem.
Default 02-14-2020, 03:46 PM
It will just depend on the tuning situation, fuel being used, etc. The more aggressive the setup the more useful EWG control is.
Car: Genesis g70
Default 02-14-2020, 03:56 PM
So would you say map7 would see some improvement?
2019 genesis g70 3.3 sport
Jb4, bms intakes, ark midpipes, jun bl catback.
Default 02-14-2020, 04:08 PM
The higher the boost the more benefit we'll expect to see, but that is what BETA testing is for, to hash these things out.
Car: Genesis g70
Default 02-14-2020, 06:44 PM
And as far as going completely *** less does the jb4 prevent a cel code from Popping up or are anti foulers needed?
Default 02-14-2020, 06:51 PM
Outside USA passive delete can be used. Inside USA can't help you as it's illegal to remove emissions equipment.
Car: Genesis g70
Default 02-14-2020, 10:35 PM
So anti-foulers?
Default 02-14-2020, 11:03 PM
So anti-foulers?
Sorry that isn't my department, can't help anyone with how to defeat emissions controls.
Car: Genesis g70
Default Yesterday, 07:01 AM
With these connectors taking over the iat spoofing position can we used that iat set up in position #1 right now or will it be a later update?
DaBears4Lyfe DaBears4Lyfe is offline
Car: Kia Stinger GT1
Default Yesterday, 08:09 AM
Cables were fine. Driver side i had more than enough to wrap through by the ECU and across the engine by the rubber seals to try and keep it clean. I have to add some flare to them this weekend to clean it up but it runs right with the OBD cable.
Passenger is a bit long but i stuffed it in by the Fuse box and have that fuse box / Piggyback cover that Khartunerz sells to cover to hide everything
