art @ DMD art @ DMD is offline
Car: BMW 335xi
Default Survey for JB4 Mobile Users - 02-05-2020, 05:16 PM
We at DMD are starting a survey for our customers who have installed and used the JB4 Mobile app.
What areas in the JB4 Mobile App would you like to see improved?
What suggestions do you have to accomplish this?
What items are confusing and need clarification?
davidpinaz davidpinaz is offline
Car: 2019 Mini Cooper S
Default 02-06-2020, 07:20 AM
Here are the things I would like:
- An absolute timestamp in the logs. Taken from the mobile device, OBDII data or whatever. MM/DD/YY:HH:mm:ss:ms or whatever. Having a timestamp like this would help use the logs for track day apps like RaceRender, etc. The relative timestamp that is currently there seems too arbitrary to be useful.
- GPS data in the logs. This would also be useful for track day stuff.
- Other OBDII data logging, specifically calculated torque/hp values. However, other information would be good, too. Possibly showing the PID's and letting us choose and save them in a "profile" or some such.
- Easier updating of the firmware/software. i.e. The app should be able to automatically check what exists and be able to compare it to the newest, then prompt the user to update.
Tue's Avatar
Tue Tue is offline
Car: M5
Default 02-06-2020, 10:56 AM
I would like to be able to change in the app:
'3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation. (OFF tach = 0, ON tach = 1000)
Tue
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 02-06-2020, 01:58 PM
I'd definitely like to see more PIDs be loggable. Speed, Boost (in psi), knock, etc.. Being able to control the exhaust flap would be nice too.
Mike Levy
2017 X3 xDrive35i
2000 Kenne Bell F150 Lightning - FOR SALE
2018 Equinox LT 2.0T
Laney182 Laney182 is offline
Car: 328 n20
Default 02-08-2020, 01:33 PM
would be nice to enable/disable asd, boost gauge etc in the app
snowmunky's Avatar
snowmunky snowmunky is offline
Car: 2018 Porsche Cayman S
Default 02-09-2020, 07:01 AM
Confusing and need clarification:
-what all the options bits do on each platform/firmware?
-what, exactly, the TMAP setting does (was previously labeled "N20Map"?
-should we set any of the WMI/E85 settings in the app if we're running an E85/93 Octane mix?
And I'll probably think of more when I get the car out today....
snowmunky's Avatar
Default 02-09-2020, 07:03 AM
Oh, and, make code reading work properly on the Porsche 718 platform!
Car: 2019 STINGER GT2
Default 02-14-2020, 12:32 PM
More gauge themes!
Default 02-17-2020, 08:42 AM
If you got some codes can you email them to george@burgertuning.com. They should be similar to the VAG cars so possibly on a future update most translations will be there.
GaryM GaryM is offline
Car: 2019 Infiniti Q60 RS 400
Default 02-18-2020, 01:48 PM
iPhone X compatibility appears to be lacking: Pages (e.g. firmware update) are not scaled, the only way to get back to the main menu is to exit and reload the app, etc.
It could be user error, of course
Gary
