C2YT C2YT is offline
Car: 2011 e90 335i
Default 2011 335i N55 - FBO w/ Inlet & Outlet - 09-13-2018, 03:36 PM
Looking for a little advice here, took logs on Map 1 and Map 2. I just installed my Pure inlet last night along with a VRSF outlet. The car is FBO on e30 (5.5 Gallons) and on the Pump BEF.
When I compared to my earlier logs, it looks like I might have a small boost leak based on my increased wgdc. I thought the inlet was suppose to reduce this. Any other input would be great, thanks!
Car: 2011 e90 335i
Default 09-14-2018, 05:38 AM
Here is a Map 5 run from this morning. WGDC still seems to be maxing out. Fixed a leak at the tmap last night where it was going through the threads. I used a boost leak tester and soapy water, couldn't find a leak anywhere else.
Car: 2011 e90 335i
Default 09-14-2018, 05:52 AM
Now that I think about it, one thing I have adjusted is the setting 11 on the gauges. I believe it is the boost ramp in or aggressiveness based on throttle input. I want to say I put it to 1400-1500 or something like that. I will verify on my lunch break and put it back to 0 to take a log or two.
Car: 2011 e90 335i
Default 09-14-2018, 05:33 PM
More logs, could really use some input. I spent today setting the duty bias. looks like I need to shift it to the left a hair, but overall happy with it.
Getting a little lean on initial spool no matter what the map is. I assume this is for lean spool? Drops boost after though.
Map 2 has quite the corrections on it. Why would this be when map 6 does not?
Any overall input would be fantastic! Thanks!
Default 09-16-2018, 02:04 PM
Overall doesnít look bad.
I think another 1-2 gal of e85 is going to help clean timing up.
Boost doesnít look too bad, letís get the corrections sorted first.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2011 e90 335i
Default 09-16-2018, 04:26 PM
Already running 5.5 gallons, so 6-7 gallons of e85 will be alright?
I ran the same tank on this log and it seems to be pretty happy. Adjusted the duty bias and let the FF learn some more. Let me know what you think. I'll fill up with 6.5 gallons of e85 later this week. Heading to the drag strip on wednesday, so hopefully everything goes smooth.
Default 09-18-2018, 11:07 AM
Looks a bit happier, cyl 4 seems to be consistently dropping- something to keep an eye on.
Little more octane should help, if not will want to look at other ign related options.
e92 AT 335xi 2.0
Doc Race Kit 6062
