(#3576)
Mouse Mouse is offline
Car: F30 335i
Default 08-15-2018, 07:04 AM
Dash only. It's the first thing so it doesn't take long.
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 08-15-2018, 09:09 AM
Originally Posted by 5soko
Did the JB4 software download link get removed from the first post? I cant find it
Also, it should be noted in the map directions break down, that map 2 on a PWG car is a absolute map of 14psi not a additive map.
Found it.
14 F30 335xi AT- SpeedTech Stage 3 w/ BW-8374, JB4 w/MHD Flash, E85, AFE Intake, VRSF 6" Race FMIC, VRSF CP, Fuel-it Stage 2 LPFP and PI
Default 09-04-2018, 02:43 PM
JB4_F_EWG_16_TEST5:
1) Revised logic for absolute boost targeting maps resulting in smoother part throttle operation and the ability to set boost by gear values lower than the flash target.
2) Adjusted map4 to a low boost / VALET / safety map with a target of 8psi.
tauzins tauzins is offline
Car: 2014 335i m-sport
Default 09-04-2018, 02:58 PM
JB4_F_EWG_16_TEST5:
Flashing now
Edit: so far I’m noticing it feels like it doesn’t hold boost the same, not sure if that’s exactly what’s going on but that’s what’s it feels like
F30 335i | ER Chargepipe | ER Down-Pipe | Wagner Intercooler | BMS Intake | Meisterschaft Exhaust | MHD BEF JB4 Map 5 / 30% e85
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 09-06-2018, 03:13 PM
Originally Posted by Fmonteiro444
Found it.
Thank you sir!!!! Glad for your help, sad for my brain and eyes that i missed it.
2014 F10 535i N55 PWG
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 09-07-2018, 02:52 PM
Is this a shadow code that can be ignored?
image1 by 5soko, on Flickr
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 09-12-2018, 03:46 PM
When did the change for the DWP go from 80 to 60? Any reason, im still at 80 been working good.
Default 09-12-2018, 04:06 PM
No reason to change it if everything is working fine.
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 09-12-2018, 05:25 PM
Gotcha.. One more thing.
Setting all of the duty bias values to 50 via the default settings per page 1 has no effect on us PWG integrated guys running absolute maps correct?
We should set to 0 or 50 for PWG integrated on absolute maps, aka map 2 for us PWG guys.
Drpoomanchu Drpoomanchu is offline
Car: M235i
Default 09-12-2018, 08:17 PM
With Map 4 being altered in firmware 16 will I still be able to log via JB4 on map 4 while on Bootmod3 flash or will JB4 cut boost ?
Kjeronimo27 Kjeronimo27 is offline
Car: n63
Default Today, 05:14 PM
Hey guys/ terry , I have a question
I took off my jb4 from my 2016 m235i
And was wondering if it’ll work directly on my new f15 x5?
Just wanted to make sure also the map switches are the same within the dash as well
Thanks guys !
