steve30's Avatar
steve30 steve30 is offline
Car: E36 M3, E90 335i
Default Log Check please - 09-17-2018, 09:43 AM
Just realized after I posted in the old section that log checks have been moved..
anyways.. updated the firmware/BEF on my single turbo setup.
This is on pump gas (94) map1 wg spring is ~12lbs.
Doc race w/ a GTX3584RS.
3rd gear pull.
Any input is appreciated, thanks!
Default 09-17-2018, 11:10 AM
3rd gear pull.
Overall this doesn’t look bad.
Could try map 2 if you want. May get a bit better spool if you up DWP a bit too, maybe try upping by 5
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
steve30's Avatar
Default 09-20-2018, 10:31 AM
upped the DWP by 5 and did a 3rd gear pull.
Default 09-20-2018, 10:38 AM
Looks pretty clean, how does the car feel?
e92 AT 335xi 2.0
Doc Race Kit 6062
steve30's Avatar
Default 09-20-2018, 10:43 AM
It feels great, pulls pretty strong but needs more boost for the top end! I just finished installing the meth kit with dual cm7 nozzles so I'll be upping the boost soon. I'm sure I can set it to map2 on pump gas and be safe for a little more power. I've been driving it on just wastegate for the last couple months making sure everything is holding together.
Default 09-20-2018, 10:57 AM
Throw it on map 2 & do 1-2 adaptation pulls & then do a clean log.
I agree I think you’ve got a little more room in there.
e92 AT 335xi 2.0
Doc Race Kit 6062
steve30's Avatar
Default 09-26-2018, 04:38 PM
Here are a couple logs on map2. They aren't perfect, I started at just under 3k rpm and one of them I didn't get to redline. I'll do a better one on the weekend when the roads are a bit more clear lol.
Default 09-27-2018, 09:16 AM
Not bad at all. Lower FF to 20 and get another log. Looks really good from what I see.
steve30's Avatar
Default 09-29-2018, 07:01 AM
I had the wg adaptation turned off, but adjusted the FF down to 20 and it seemed to pull much harder. I'll get a log of it this evening if I can.
Default 09-29-2018, 11:20 AM
e92 AT 335xi 2.0
Doc Race Kit 6062
steve30's Avatar
Default 10-14-2018, 11:30 AM
FF set at 20, 3rd gear
kind of weird but I feel like it pulls harder with the tablet not plugged into the jb4.. same thing with the 2step, seems to work a lot better with no tablet plugged in.
Default 10-14-2018, 07:38 PM
Overall looks fine.
Odd about the tablet lol
e92 AT 335xi 2.0
Doc Race Kit 6062
steve30's Avatar
Default 10-17-2018, 01:13 PM
Originally Posted by Dave @ Fuel-it!
Overall looks fine.
It seems like its been a problem for a while and others have had similar issues.. When the tablet is connected the 2step struggles and hits the set limiter at half the speed. When its unplugged the 2step bounces off the limiter with ease..
Anyways.. I installed the meth kit with twin cm7 nozzles. Filled it up a few days ago and purged it. There seems to be a leak on the pump inlet line I'll get it fixed and hopefully get a meth log asap before winter arrives for us here in the north lol
Default 10-18-2018, 11:04 PM
#n54life
e92 AT 335xi 2.0
Doc Race Kit 6062
