stevee's Avatar
stevee stevee is offline
Car: 535i
Default Log review - 09-16-2018, 08:19 PM
hey guys
recently got jb4.
2008 E61 102k miles
VTT stock replacement turbos
AR **
BMS DCI
Amb temp around 85F
Started with map 1, then it went to map 4
even if I try to run map 4 it keeps flashing like overboost.
Default 09-16-2018, 09:08 PM
Originally Posted by stevee
hey guys
recently got jb4.
2008 E61 102k miles
AR **
BMS DCI
Amb temp around 85F
Welcome.
Map 4 is a safety map, meaning if something is really out of whack, the JB4 throws you to map 4 (stock like) to try & save the car from whatever is going on.
In your case- safety 2 = AFR LEAN.
You have some pretty large bank 1 to 2 AFR variances- I suspect an o2 issue.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
stevee's Avatar
Car: 535i
Default 09-16-2018, 09:38 PM
Originally Posted by Dave @ Fuel-it!
Welcome.
thank you.
what's the best way to solve it? i got c4tles d0wnp1pe5
Default 09-17-2018, 05:10 AM
Do you have any O2 codes? You will need a new O2 sensor.
stevee's Avatar
Car: 535i
Default 09-18-2018, 09:28 AM
Hey, yes I got
2C9C
2CAA
2CA6
thanks
Default 09-18-2018, 09:47 AM
Hey, yes I got
2C9C
2CAA
2CA6
thanks
Need to replace primary O2 sensor, not sure which one but I'd probably just do both.
stevee's Avatar
Car: 535i
Default 09-21-2018, 08:38 AM
Now, for some reason car started to somehow slip when shifting. even though I'm not pushing it at all and run map 4. it's like hesitating to shift gears. and this morning when i was driving like 10 mph it threw me trans malfunction.
(I always wait 2-3 min before I drive after start.)
O2 sensors should be replaced today.
Default 09-23-2018, 11:06 PM
Are you running a trans flash?
O2 codes / trans issues arenít related (you probably know this, but just throwing it out there lol).
e92 AT 335xi 2.0
Doc Race Kit 6062
stevee's Avatar
Car: 535i
Default 09-24-2018, 05:16 PM
I know it, it just happened in the same time.
It was trans oil leak from coooling hose.
Fixed already.
I don't have trans flash. should I get it?what's the benefits?
Default 09-24-2018, 10:47 PM
Fixed already.
Faster, firmer shifts- look into xHP
e92 AT 335xi 2.0
Doc Race Kit 6062
stevee's Avatar
Car: 535i
Default 10-02-2018, 10:18 AM
I'll look into it. Thank you
stevee's Avatar
Car: 535i
Default 10-02-2018, 10:24 AM
Now I have another log to review.
Car was jerking under pedal around 30-40%
I changed menu 11 to 1000
now it seems ok, but on the speed around 80 mph under same 30-40% throttle it does the same thing.
I tried to log today, and then it also went to reduced power mode with codes
2D2E
30FE
3100
Ambien temp was around 88 F
car has AR ownpipes, ER CP w/tial, BMS DCI
if someone can advise me on this problem, please take a look at the log
Thank you
stevee's Avatar
Car: 535i
Default 10-03-2018, 01:03 PM
well, I think I messed up menu 11 at 12..
Haynpunch's Avatar
Haynpunch Haynpunch is online now
Car: 07 E90 335i
Default 10-03-2018, 04:44 PM
https://www.n54tech.com/forums/showthread.php?t=10605
set all settings back to default Post 3
enable 6cyl timing logging
start with map 1
logs usually done in 3rd or 4th gear traction off WOT 2k to redline
stevee's Avatar
Car: 535i
Default 10-03-2018, 06:56 PM
start with map 1
here all defaults and I hope I set cyl right
drives ok no CEL pops up, but map 1 feels like regular.
Im new to this stuff, so my question is should ign be like this different?
thank you
stevee's Avatar
Car: 535i
Default 10-04-2018, 08:56 AM
thank you
Based on the sticky thread about logging parameters, my fuel pumps
readings are high.
Can some one help me out? : Please
stevee's Avatar
Car: 535i
Default 10-04-2018, 01:16 PM
bump
stevee's Avatar
Car: 535i
Default 10-07-2018, 12:57 PM
so sad, no one wants to talk to me(
Default 10-07-2018, 04:39 PM
bump
Multiple timing corrections on multiple cylinders. What fuel?
Also- work on NOT taking your foot off the pedal during logging, stay WOT
Also- remember it’s Sunday- lot of the regulars are with family etc.
Cheers,
Dave
e92 AT 335xi 2.0
Doc Race Kit 6062
stevee's Avatar
Car: 535i
Default 10-07-2018, 06:42 PM
Also- remember itís Sunday- lot of the regulars are with family etc.
Cheers,
Dave
last 2 logs are full WOT.
using 93 octane.
What about fuel pumps readings?
Sorry, right it's Sunday.
thank you
Default 10-07-2018, 08:35 PM
using 93 octane.
thank you
Both your HPFP & LPFP- look fine based on the logs
e92 AT 335xi 2.0
Doc Race Kit 6062
