TommyV TommyV is offline
Car: 2008 335i
Default Log file for review - 09-12-2018, 08:39 AM
I finally got around to logging in 3rd gear, traction off, 2000 - 7000 rpm (approx). Can you please review and give me some feedback? I'm running the JB4 on Map 5, with an MHD backend flash and a 7" HD VRSF FMIC and DCI. Stock turbos.
2018-09-11 15_53_24.csv
Default 09-12-2018, 10:18 AM
Attachment 79182
What fuel? LPFP looks to be struggling up top.
Enable 6cyl logging as well in your user adjustments.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2008 335i
Default 09-12-2018, 11:31 AM
OK, I see the 6-cyl Timing Logging (0-6), what value do I put in that field?
How can you tell the LPFP is struggling?
Edit: 93 Octane fuel
Default 09-12-2018, 12:38 PM
Value depends on your dme- so check which dme you have
LPFP you can tell is struggling based on the “FP_L” column in your log- up
Top it is falling into the 40s, healthy range is usually considered mid 60s- 70+. Seeing that you are also only running 93 and the value is that low, I’d assume your LPFP is pretty tired.
Depending on power goals & future plans, I’d be happy to assist you with selecting the right LPFP upgrade for your car
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2008 335i
Default Enabled 6cyl logging - 09-14-2018, 09:59 AM
Here's another run. Ambient temp was around 85F.
2018-09-13 16_53_13.csv
Default 09-16-2018, 01:50 PM
Attachment 79280
Timing doesn’t look great with multiple corrections.
LPFP still struggling.
Until you address the issues, run a less aggressive map, 1
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2008 335i
Default 09-16-2018, 05:06 PM
Thanks for looking, I understand about the lpfp, what would cause the timing issues?
Edit: I don’t see any timing drops until I lifted the throttle at redline. Maybe I don’t understand what I’m seeing
Default 09-16-2018, 06:57 PM
Edit: I donít see any timing drops until I lifted the throttle at redline. Maybe I donít understand what Iím seeing
Look at the individual cylinders. Variances between- signify timing correction on that individual cylinder(s)
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2008 335i
Default Ok, I see what you're talking about in the mid-range - 09-16-2018, 08:26 PM
I'm a novice on this stuff, I really appreciate the input! What I went and read about timing drops said that I either need more octane or a less aggressive program. I'm running map 5 and have the MHD background flash. I thought map 5 would compensate for the fuel I use. I'm I missing something else that could be causing it?
What would you recommend for the lpfp issues? I don't currently have any goals to go for bigger HP, I just want it to run at full potential for what I have.
Default 09-16-2018, 09:05 PM
Map 5 can compensate a bit, but itís not a miracle worker. I know you guys like map 5, Iíve never been a big fan. Log map 1 and see how timing looks, if itís cleaner- then you have your answer.
Shoot me an email: dave@fuel-it.com & we can get you setup for your goals
e92 AT 335xi 2.0
Doc Race Kit 6062
