LaCross LaCross is offline
Car: 2010 135i
Default What should fuel rail pressure be at idle? - 11-27-2015, 01:49 PM
What should fuel tail pressure be at idle? Google isn't helping
icewall icewall is offline
Car: BMW 135i
Default 11-27-2015, 02:59 PM
well I know with my jb4 its 5 which I think = 700 psi
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 11-27-2015, 03:12 PM
Mine fluctuates between 600 and 750psi.
Car: 2010 135i
Default 11-27-2015, 03:21 PM
Mine is at 430-480 psi. Lpfp is at 80 psi. Bad hpfp?
Car: BMW 135i
Default 11-27-2015, 05:05 PM
hmm that is low but i guess as long as you dont have long starts and your hpfp pressure during WOT looks good then you should be ok?
Car: 2010 135i
Default 11-27-2015, 05:21 PM
My car was shutting off when I came to a stop the other day, had a half engine. Stopped the day after. Now it's starting to misfire on cyl 6
Car: BMW 135i
Default 11-27-2015, 06:01 PM
yeah then probably hpfp is too old.
they are only semi-hard to change. it's not too bad like 6 out of 10 IMO.
Nniftyfour's Avatar
Nniftyfour Nniftyfour is offline
Car: 335xi
Default 11-27-2015, 06:56 PM
430 to 480 is too low, I'd log HPFP and see what it is under load.
Car: 2010 135i
Default 11-27-2015, 07:32 PM
Can't. It'll misfire under any load
1hunglow 1hunglow is offline
Car: 135
Default 11-27-2015, 11:43 PM
Sounds like your hpfp is pretty much done.
The car needs about 600-700 psi to idle
Just be careful until you get it fixed
Nniftyfour's Avatar
Car: 335xi
Default 11-28-2015, 09:18 AM
Well make sure your getting at least 70psi of low pressure fuel at idle. But also the car should thow a fuel pump code if it's that bad. Sounds like a bad hpfp though.
Car: 2010 135i
Default 11-28-2015, 10:29 AM
swapped the injector and it was roasted. Thinking that not enough fuel is getting back there. Now the lpfp is putting out a correct 5bar but the hpfp is still fluctuating between 478-725. It will dip down to 480ish, then jump up to 580ish, then down to 480, then to 700, etc.
Heres a lovely pic of the injector and coil
Car: 2010 135i
Default 11-28-2015, 12:20 PM
this is all i could get because its raining
http://***********/u/lacross/log-1448...&data=1-4-9-10
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 11-30-2015, 09:47 AM
Mine just started going from 700 - 2000 - 700 like a wave, after letting the car idle for a bit. Anyone ever see this?
Enjoying the new tables discovered and the XDF progress made? if you'd like. Every bit is appreciated!
BostonBeemah's Avatar
Car: AW 135i
Default 11-30-2015, 10:50 AM
2000 at idle?? How is that even possible? Sounds like it could possibly be a bad sensor..
RIP 2008 AW/BL 135i
Car: 2010 135i 6MT
Default 11-30-2015, 02:12 PM
Not sure, but it is definitely increasing / decreasing pressure as I can hear the change in pitch in the injectors, that corresponds w/ the rise and fall of logged rail pressure.
bk335xi's Avatar
bk335xi bk335xi is offline
Car: 335xi 6MT
Default 11-30-2015, 02:26 PM
Which cylinder was this on?
08 335xi 6MT | FBO
inevitab1e's Avatar
Car: 2013 N55 135is
Default 10-22-2018, 06:56 AM
Did the new injectors fix your issue?
2013 E82 135is N55 JB4-BEF FBO
