prelude2perfect's Avatar
prelude2perfect prelude2perfect is offline
Car: '07 335i
Default How to raise idle with tunerpro - 02-17-2016, 12:40 PM
Can someone walk me through which menus and how to adjust it? I've used tunerpro to delete the cold start function already so I'm familiar with how it works. I just want to make sure I'm going to the correct menu and adjusting the right areas.
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 02-17-2016, 01:32 PM
Open up the "Idle Setpoints" folder, then go through each table in there. Say you want a 900rpm idle.... every value you see that is less than 900rpm, simply change it to 900rpm.
Leave the values that are currently higher than your desired idle alone
Enjoying the new tables discovered and the XDF progress made? if you'd like. Every bit is appreciated!
BostonBeemah's Avatar
Car: AW 135i
Default 02-17-2016, 02:13 PM
This^ and sounds like you've had limited experience with TunerPro. Don't forget to save each table change first, as well as save the bin changes once you are done.
RIP 2008 AW/BL 135i
Car: 2010 135i 6MT
Default 02-17-2016, 02:33 PM
+1, this could be the cause of much frustration if you forget!
Car: AW 135i
Default 02-17-2016, 02:38 PM
Haha I have to admit I've been there after making a a ton of changes and not saving each individual table
RIP 2008 AW/BL 135i
Car: '07 335i
Default 02-17-2016, 03:25 PM
Thanks so much guys! Just got my SMFW in and want to get rid of the chatter
Best 1/4 ET: 11.4
feauto335xi feauto335xi is offline
Car: e90 335xi
Default 02-17-2016, 07:12 PM
Keep us updated on how it helps.. what fluids did you use? I wish you could do a before and after lol
