shaudfab's Avatar
shaudfab shaudfab is offline
Car: Merc
Default N54/N55 Single Turbo Twin Scroll Manifold ShaudFAB - 09-02-2014, 10:06 PM
Hello all,
Been working on some manifolds for the N54 and N55 motors. So far its been great.
Top Mount Twin Scroll Manifold
Twin Turbo manifolds and kits
http://instagram.com/shaudfab
www.shaudfab.com
shaudfab@gmail.com
Text 805-727-4652
Early stages
blaster3500 blaster3500 is offline
Car: 2007 335i
Default 09-02-2014, 11:19 PM
Nice to see more and more options! Price point? Also o2 location?
07 E90 335i 6mt
shaudfab's Avatar
Car: Merc
Default 09-02-2014, 11:47 PM
02 sensors are being placed right under the turbo flange in the divided runners so they will not be mixed. Pricing will be around $2k mark for top mount.
EvanL's Avatar
EvanL EvanL is offline
Car: 07 E92, 08 E61 (N54s)
Default 09-03-2014, 06:39 AM
Looks clean. What material and tube/pipe thickness are you using?
shaudfab's Avatar
Car: Merc
Default 09-03-2014, 07:44 AM
Thanks,
304 Stainless steel
Schedule 40
EvanL's Avatar
Default 09-03-2014, 09:56 AM
Originally Posted by shaudfab
Thanks,
304 Stainless steel
Schedule 40
Thanks for the info. Thinking of going single in the next year or so and can't decide if I want to DIY or purchase an OTS solution.
Couple follow-ups related to longevity; Are you backpurging/inerting the weld environment? 304 or 304L?
shaudfab's Avatar
Car: Merc
Default 09-03-2014, 10:33 AM
304L SCH 40
I always back purge every manifold I make, can't have that sugar.
EvanL's Avatar
Default 09-03-2014, 11:22 AM
304L SCH 40
Man after my own heart--thanks for the info!
Laurus_CEO's Avatar
Laurus_CEO Laurus_CEO is offline
Default 09-03-2014, 12:21 PM
Good ****! So happy to see more and more options for going single. Are you saying that just the manifold will be $2K?
shaudfab's Avatar
Car: Merc
Default 09-03-2014, 02:48 PM
Well I plan on creating a kit as well but for now sell the top and bottom mount manifolds. Bottom mount price is going to be around 1500 top around 1900. This isn't cheap material I am using the best stuff here no short cuts. FFTEC are the only ones who are selling manifolds only for DIY guys. Those are priced over $3k. There aren't any manifolds for N55 guys so I am taking a shot at it with the bottom mount, I can provide the hardware but I am not a tuner.
MuNky6913's Avatar
MuNky6913 MuNky6913 is offline
Default 09-04-2014, 12:50 PM
looks very clean and tight! i have question more for my knowledge. i plan to make a top and bottom mount manifold by the end of next year and am gathering info where i can find it. when looking at the manifolds that are out there i always see the runners extend around and meet at the collector. is there a draw back of say connecting each to the next? not sure if im saying that right. say you start with one cylinder. that comes out and turns a 90 to go straight in front of the next cylinder which you, maybe, could be able to connect to with another 90, just have to put a hole in the back/bend to connect, oriented in the same direction. then have that attach to the third cyl through the bend part of the 90? then route to wherever, say down or up. i really hope i'm making sense. i'm going for the twin upgrade so thats why i'm using 3. i would draw what i mean but i should be wearing a helmet 24/7 if that would be determined by artistic talent. in my head, that has no idea about flow and what not, its kind of like the one HPF just released not to long ago, but 3 cyl and tubing instead of a machined block. Thanks for any info.
2009 135i - Berk Tech. Race Axleback - Injen Short Ram Intake - BMS JB4 G5 ISO - CXRacing FMIC - ER Chargpipe - BMS Straight Down ***** - Walboro Inline Fuel Pump - Spec Stage 2+ Clutch - Spec SMFW - BMS Dual Meth Kit - BMS Backend Flash
shaudfab's Avatar
Car: Merc
Default 09-04-2014, 03:05 PM
Hello,
Basically you want to make sure each runner flows smooth like water. Imagine each runner flowing water you want it be free flowing with no interruption all the way to the turbo. By placing the collectors closer to the turbo you are allowing the manifold to flow better without gases interrupting each other.
jdm5596 jdm5596 is offline
Default 09-07-2014, 02:29 PM
Hmmm... when could I buy one??? What wg flange are you putting on? And where?
shaudfab's Avatar
Car: Merc
Default 09-07-2014, 03:28 PM
PM sent.
shaudfab's Avatar
Car: Merc
Default 09-07-2014, 03:33 PM
Also putting a bottom and top mount kit together, looking for beta testers 135/335.
Michael1972 Michael1972 is offline
Car: 2007 BMW 335i
Default 09-07-2014, 08:00 PM
Pm'ed you about testing.
Vertigo's Avatar
Vertigo Vertigo is offline
Car: AW 335i
Default 09-08-2014, 05:19 AM
PM sent. Car is in the garage with stock turbos off right now. Stage 2 head is being installed. Ready to test fitment!
2008 335i stock
_Calle_ _Calle_ is offline
Car: 330Ci
Default 09-09-2014, 03:26 AM
great work, looks very nice and clean.
but the flange looks a little bit to thin for me.
Twin scroll is the best future. Waiting to see a BW EFR on the N54/N55, but they need more space as Precision.
shaudfab's Avatar
Car: Merc
Default 09-09-2014, 02:55 PM
Thank you.
Flanges are not thin. Turbo flange is 1/2" thick, head flange is pretty thick as well same size vargas, RB, fftec and VM and others use.
scotte30m3 scotte30m3 is offline
Car: 07 335i sedan
Default 09-09-2014, 04:59 PM
I'd love to see someone make an undivided t4 turbo manifold that could be used with a quick spool valve. Those things completely change the spool characteristics of a big singles... I had one on my 2JZGTE single swap and the QSV gave it a nice flat TQ curve.
FBO (-meth), JB4 and RBs.
Car: 330Ci
Default 09-10-2014, 03:19 AM
Thank you.
OK, than it looks thin only of the pic.
shaudfab's Avatar
Car: Merc
Default 09-11-2014, 07:39 PM
Motoxracer1551's Avatar
Motoxracer1551 Motoxracer1551 is offline
Car: 3000GT VR4
Default 09-13-2014, 03:55 PM
Any updates on this? Pics installed?
I would like to see s pic of this installed on the motor in the car but with no turbo. Im just curious where the turbo flange ends up in the engine bay.
Looks really good though. This is probably the best low cost option for single turbo setups available right now!
2007 BMW 335i E92 6MT - Jet Black/Blk Dakota
MODS:*MHD/JB4*BMS CDV & Clutch Stop*335is Mounts*E46 M3 Trans Mounts*I-Drive Retrofit*80W LED AE*VRSF **'s*Brembo's*
1995 Mitsubishi 3000GT VR4 6MT - *SOLD*
*RB TT's*FBO*400+AWHP
Daily- '01 Mazda Protege 2.0L- MPG mode!
shaudfab's Avatar
Car: Merc
Default 09-13-2014, 11:05 PM
Pm me i can send you some info.
Torgus Torgus is offline
Default 09-16-2014, 01:05 PM
what you are describing is a log style manifold and it should work fine, be cheap to produce, and offer great spool. they work fine on other platforms.
Got Boost?
