(#601)
Default 11-25-2019, 06:32 AM
Originally Posted by jb4998
Thank you for the reply... I was wondering, can you use AFR to track a boost leak? The reason I ask, I notice after I fully let off the throttle after any decent turbo engagement the boost is hanging between 0.1-0.4, and this in turn is causing the AFR to stay low, around 3.x-4 until I get on the throttle again.
Is the 0.1-0.4 boost reading indicative of a boost leak? Is coasting around in gear at 3-4 AFR going to cause a rich condition?
I would send you the logs, but I have already sent you two emails in the last 24 hours, and I don't want to be that guy
See reply on your other post.
blackgti blackgti is offline
Car: M235I
Default 11-26-2019, 02:27 PM
This may have been asked already but I cannot seem to find the answer. Is Map 3 the same as Map 2 except the peak boost is 6 vs 5? Iím running 93 with a ** and IC if it matters.
Default 11-26-2019, 03:12 PM
Correct. Map 2 has slightly more torque. Map 3 is done in such a way that its good for DSG and manual on 93. Power delivery feels more linear.
Car: M235I
Default 11-26-2019, 06:06 PM
Great thanks George. My car definitely feels better with Map 3 than Map 2 and even Map 6 now that itís colder out.
7.5smurfrabbit 7.5smurfrabbit is offline
Car: 2019 rabbit gti
Default latest firmware - 12-02-2019, 10:29 AM
whats the latest firmware?
Default 12-02-2019, 10:37 AM
Its always in post 1.
Default 12-03-2019, 06:27 AM
thank you master george
Nora2004 Nora2004 is offline
Car: 2017 Seat Leon Cupra 300
Default 12-04-2019, 10:18 AM
I may regret asking this, but here goes, fuel duty bias, I've noticed having this set to 100 across the board will result in an AFR of mid 13's, but when logging in map 0 the stock AFR target is 14.6! Is it best to leave it as is or is the stock 14.6 target better? I had noticed a good while ago when helping a friend setup his map 6 he had forgot to enter the duty bias figure so they were left at 0, looking at his logs everyone of them had the AFR's bang on 14.6, that got me thinking and lead me to this question?
Any thoughts on this before I go and blow my motor up? Lol
Default 12-04-2019, 11:47 AM
All other piggy backs use stock targeting. Even though the logs might look ugly at higher boost levels it wont melt the engine. At a certain point though boost wise you get a timing benefit when running richer and allows for more boost add safely without the ECU having to intervene continuously with corrections so 100 is the recommended value. This is also why we only recommend map 1 for guys that dont want to connect the AFR wire which is what does this biasing.
Default 12-04-2019, 12:05 PM
This is interesting! So right now I've got my boost dialled in with max ignition advance the ECU can offer, I'm currently low to mid 13's AFR, I get the while richer running helping to cool down the combustion, which I guess will result in more power in certain situations! So I'm assuming I can set my duty bias to zero, target 14.6 and log to ensure my ignition advance doesn't **** itself and I'd be good to go? I'm also assuming I can change the bias values in 10's to richen or lean the mixture?
God I love this ****!
Default 12-04-2019, 04:15 PM
Something like that but over all the 100 settings in the fuel bias will give you best performance. Normally its not something we adjust unless the car is going super rich. At 14.6 you will trigger a EGT safety the ECU has and then it pours in fuel especially under high load driving.
tegxsi tegxsi is offline
Car: RS3
Default 12-05-2019, 10:26 AM
I was tinkering with a JB4 for Gen3 EA888...
I was kind of concerned how the AFR are in low 14s at peak boost/torque then slowly tapers down. I also noticed that it wasn't running any ignition advance in these areas either.
I learned that these cars will add more fuel based on load and modeled EGT in ECU. The exhaust manifold that is built into the head is water cooled to help keep EGT down. The engine also gets up to temperature amazingly quick.
It's really a neat little engine. Runs even better with a splash of E85.
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
Default 12-05-2019, 04:43 PM
Nice, also posted in wrong section
audi_driver_ audi_driver_ is offline
Car: 2016 S3
Default Yesterday, 10:17 PM
Two quick questions:
1. I pulled code 3B9D No Description Found and have not been able to find any info on what exactly that code is - and input?
2. Is it common to have to attempt to clear codes several times before they are deleted? (3+)
2016 S3 with JB4 map 3 + intake.
Default Today, 05:48 AM
Its primary O2 sensor signal to low. It will trigger that sometimes with AFR connection. Best bet though is to do a few logs and email them over to make triple sure the car is not running lean.
