mulch mulch is offline
Car: 2016 Audi A3 2.0 Quattro
Default Logging? How to.. - 10-24-2019, 04:38 PM
I have the Jb4 installed with B/T and all seems well. I now want to do some logging to see what Im getting.
How do I do it? I understand that i use the logging button but when? I keep reading something about 3rd gear? How long to run it?
What is the exact process?
Pat
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 12-01-2019, 11:09 AM
You can either manually log or let the app handle it for you automatically.
Manual Logging:
Hit the 'Start Logging' button before you start your pull.
Do a pull in a slightly longer gear (1st and 2nd are usually too short to give much valuable info so I always use 3rd).
Hit 'Stop Logging'.
Automatic Logging:
In the settings tab find the 'App Settings' section then 'Logging Settings'.
Set your WOT Autolog Timeout to something other than zero. Since I use 3 seconds, this means that once my pedal goes BELOW my threshold value (mentioned below) it will wait up to 3 seconds for the pedal to go back above that threshold, otherwise it will end the log.
Set your WOT Autolog Threshold. Since I use 90%, this means that once my pedal goes above 90%, a log will start.
Once you set those 2 parameters, the logging will be handled for you.
Default 12-02-2019, 10:17 AM
Manual Logging:
Hit 'Stop Logging'.
Automatic Logging:
Wow totally forgot about this thread.
After some more reading and trial and error I got it down. Many logs recorded and I have been tweaking some Maps. Just about ready to post them for someone to look at.
Thanks for the reply.
gpdriver177 gpdriver177 is offline
Car: 2019 BMW M5
Default 12-06-2019, 08:44 AM
- Deleted
