bonomos335i bonomos335i is offline
Default Car over boosting after relocated inlets and ********* - 02-02-2019, 11:01 AM
Just installed jb4 car ran great then installed relocated inlets and down ***** . Now the car jumps from map 5 to map 4 and seems to be over boosting . I can upload log of second gear pull to help.
Domino_86's Avatar
Domino_86 Domino_86 is offline
Car: 335i sedan
Default 02-02-2019, 04:13 PM
Do you run the latest JB4 firmware?
Default 02-02-2019, 06:55 PM
No I’m about to update it now
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 02-02-2019, 07:24 PM
You might have to manually lower FF since things are flowing more freely and less PWM may be required (it will adjust automatically over time too). Similarly, with inlets you sometimes need to manually adjust duty bias because the flow characteristics differ from stock and it changes the PWM curve required. There is a good thread about adjusting duty bias.
Of course, I could be completely wrong, so a log would help confirm what your issue for sure
Default 02-02-2019, 07:40 PM
Just updated it same thing happened i changed the wastegate adaption to 26 from78 didn’t make a difference
Default 02-02-2019, 07:55 PM
So my it’s running lean. Afr 2 is 15-16 �� boost is steady at 9 then drops when getting lean .
Default 02-03-2019, 10:40 AM
Log?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 02-03-2019, 04:28 PM
so i seen the last safety and it was lean afr. so when i logged it i seen sensor 2 was reading lean. i dont think its actually going lean. when i installed the horrible fitting down ***** the rear o2 was tight and it got a little bent and the wires are touching the aluminum coolant pipe. so im going to take them back off and beat the **** out of them to make everything fit and buy a new o2 and see what that does.
Default 02-03-2019, 05:41 PM
Yeah- double check Install / hardware & Id inspect for damage too.
Reset O2 adaptations after & see.
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 02-03-2019, 06:47 PM
I just switched the o2 plugs up top and the rears read 14 at idle and with the messed up o2 it was reading 16’s. After i switched them the fronts read lean too. So I’m assuming the 02 is messed up . I’m going to replace it. What color and bank is the rear 02
Banzai250 Banzai250 is offline
Car: 2007 e92 335i
Default 02-03-2019, 07:18 PM
Front is black (bank 1)
Rear are grey (bank 2)
Default 02-03-2019, 07:39 PM
Part number?
Car: 2007 e92 335i
Default 02-03-2019, 07:47 PM
I think 17098 and I used the same o2’s for both banks
Default 02-03-2019, 08:14 PM
Ok thanks
Default 02-04-2019, 08:54 PM
swapped a new sensor in and it fixed the problem!
Default 02-04-2019, 09:58 PM
Victory!
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 02-05-2019, 06:04 PM
i have all these codes now?
2C9D Lambda probe heating in front of catalytic converter 2, input signal
2C9F Lambda probe heating behind catalytic converter 2, input signal
2AAF Fuel pump, plausibility
2FBE Fuel pressure after motor stop
2ABC Charging pressure sensor, electrical
3100 low boost mode engaged -- CEL displayed
2C9C Lambda probe heating in front of catalytic converter, input signal
29D1 Misfirings, cylinder 5
Default 02-05-2019, 06:12 PM
If you clear what comes back?
The misfire- well thatís a cyl 5 issue (plug coil- not uncommon)
The 2aaf is generally a tuner code / can ignore- however yours is accompanied with another fuel code- possible an HPFP issue?
The o2 codes- are back?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 02-08-2019, 01:11 PM
The only ones that come back are 3100 2abc 2aaf . What spark plugs do you recommend?
Default 02-08-2019, 03:44 PM
Those codes only come back after i shut it off and turn it back on
Default 02-08-2019, 04:50 PM
And of course i got another safety of lean afr !
Default 02-08-2019, 09:02 PM
Logs?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 02-09-2019, 06:38 AM
Of course i laogged it last night and it didn’t do it. And i pretty sure i felt my clutch slip ��
Default 02-09-2019, 07:58 AM
Of course i laogged it last night and it didnít do it. And i pretty sure i felt my clutch slip ��
#n54life
e92 AT 335xi 2.0
Doc Race Kit 6062
335XI-6sp 335XI-6sp is offline
Car: 2007 335xi 6sp
Default 02-09-2019, 11:50 PM
Hey, I'm having a similar problem. My car was running flawlessly until tonight. Logs below.
2007 335XI, 6 Speed Manual
Current Mods:
-Relocated (MMP) Inlets/(VRSF)outlets, 5"
-Stepped Arm intercooler with upgraded silicone connections
-BMS charge pipe with meth bung
-Full sport exhaust
-Stage 2 Fuel-It pump with WB 550 pump
-Speck lightweight flywheel and stage 3 spec clutch
-Mishimoto oil catch can
Not installed yet:
BMS meth water kit, integrated for JB4
Arm Silicone intercooler connections to charge pipe
