ykarabala ykarabala is offline
Default New JB4, help - 01-31-2019, 07:44 PM
Good evening,
I bought a JB4 G5 from someone secondhand and when I installed the product, my car was stalling, not driving properly, huge power loss, etc. Granted he did have meth injection, bigger turbos, and other modifications. I found a sheet online to reset the "User Adjustable Settings" but the car was still driving very badly. I have attached the .csv file and will post a pic of the "stock settings" I found online that I changed to. I noticed that under the "Water/Meth Injection" settings, the stock JB4 is supposed to be 40, 60, and 9. Since I don't ave either, I changed them all to "0."
I would like to know what I'm doing wrong or if someone can help walk me through this mess.
Car has upgraded charge pipe and dci. Running hirmware version
Thank you,
Default 01-31-2019, 09:42 PM
Originally Posted by ykarabala
Good evening,
Thank you,
Always tough when the unit is used.
Best advice besides settings to ďdefaultĒ
Youíll want to flash a stock turbo BEF for your correct modifications as wel.
Letís get you back to square 1 & go from there.
Set JB4 to 0- flash the appropriate firmware & correct BEF for your mods
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 01-31-2019, 10:03 PM
Worth adding some install photos too, as well as a photo of the JB4 board, so we can double check that if it's not working right off the bat.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 02-01-2019, 09:21 AM
Based on your description the previous owner probably had a back-end flash loaded on top of the JB4. I am assuming you are not. Did you check the Menu 4 settings for that? That setting can't be changed in the interface for some reason.
Default 02-01-2019, 11:29 PM
Sorry the pic is hella ****ty. I had to edit it a lot to make it fit. I installed JB4 properly w the arrows facing same direction and color coded.
I changed it to default settings, but the only values I altered were for the water/meth injection as I set those to 0. Is that ok?
How do I flash to stock turbo BEF? Not familiar at all with the BEF.
I recall setting everything to 0/0 a few months back and the issues remained so I removed JB4 again.
Sounds like we're on the right track in regards to the BEF, so thank you so far!
Default 02-05-2019, 07:56 PM
Bump
Default 02-05-2019, 08:07 PM
I can't see the install photos, would need a clean full throttle log for any tuning advice.
Default 02-05-2019, 08:14 PM
Terry is correct on the log.
Here is the link to the BEF Templates:
N54 BimmerBoost MHD Back End Flash Maps - N54Tech.com - International Turbo Racing Discussion
Ensure JB4 is set to ď0Ē & make sure you have the latest firmware installed prior.
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 02-16-2019, 03:47 PM
I was able to flash PUMP BEF. I am getting a really bad surge at random times. I am going to attach a few logs. 0/5 4/2 or 4/3 are referring to the active maps while logging. The car was surging in both maps, however, it was also driving fine during other times in both maps. No codes, no CEL or 1/2 CEL.
Default 02-17-2019, 09:29 AM
Can you get us a WOT log?
What are your menu 11(pedal input)/12 (bade Duty cycle ) settings?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 02-17-2019, 11:30 AM
What maps should I use while I log?
Default 02-17-2019, 11:46 AM
Tach set to 4 /2 because you are running the BEF
Map 1 or 2
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 02-18-2019, 08:09 PM
I don't know what the hell is going on anymore and I've given up. JB4 won't connect to my Mac anymore so no logs. Regardless of what map I'm in, even 0/0, car still drives like trash. No power, stalls out, surges and bogs a ton then dies. Is there anyone I can send it to, or local to Sacramento, CA area that can check this thing out?
If it means anything... my menu 11 was set to 0. and menu 12 was set to 2.8
Default 02-18-2019, 08:58 PM
As it was a used unit so a good first step would be to just buy a new 2580 chipset from our site for $25, which will have firmware and settings preloaded, and at least restore that all to a known good state. It also replaces the comms in case you static zapped it or something preventing the reconnection.
Default 02-18-2019, 10:27 PM
Tried purchasing but can’t bc of California I’m guessing?
Removed JB4, drove the car again, and it feels great w MHD flashed so my issues are w the used unit
Default 02-19-2019, 10:22 PM
Tried purchasing but canít bc of California Iím guessing?
Letís get you the new chip- shoot an email to sales@burgertuning.com
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 02-21-2019, 11:19 PM
Email sent, thank you!
Default 02-22-2019, 09:02 AM
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 02-22-2019, 10:19 AM
Was told that I am unable to receive it because I live in California.
