bettercallbrody bettercallbrody is offline
Car: Lancia Delta
Default MMP Overboost - 02-05-2019, 11:38 AM
Hello all. Trying to get boost dialed in on this one, map 2 makes all the boost. I feel like I've missed something
MMP100's
All the bolt ons
Pump BEF
Default 02-05-2019, 11:53 AM
MMP100's
All the bolt ons
Pump BEF
Hi-
Your settings, specifically your Duty bias settings are completely wrong. Make the adjustments following the link below- double check current settings, also enable your 6cyl logging. And relog.
See the screenshot of Terry’s DEFAULT- DB settings here:
JB4 N54 Hybrid Turbo Setup Directions - N54Tech.com - International Turbo Racing Discussion
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 02-05-2019, 12:01 PM
Yes, should've mentioned that I tried the those settings first, here's a log from that, sorry I don't remember which is which.
Default 02-05-2019, 12:06 PM
Neither one of those logs have the default settings listed via terry’s post.
Start there... check and ensure your FUD settings are correct & enable your 6cyl timing & relog.
We will evaluate off of that
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 02-05-2019, 12:54 PM
Here ya go
Default 02-05-2019, 12:57 PM
Here ya go
Set Duty bias to 40 from 4K to redline
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 02-05-2019, 02:17 PM
Ok, I'll get a log of that tomorrow, other cars need my attention for now
Default 02-05-2019, 02:55 PM
Sounds good
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 02-06-2019, 02:36 PM
Here's todays log, really appreciate that you guys provide this support BTW!
Default 02-06-2019, 02:59 PM
Don’t mention it.
Can you get a 3rd gear log?
2k to redline, WOT?
This log is 2nd gear & a bit short
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 02-06-2019, 03:53 PM
Sure thing, another quick question, since BEF the DTC is off every time I start the car, seen that before? I press the button and the light goes out
Default 02-06-2019, 11:10 PM
Sounds like you may have accidentally set something via your steering wheel- you can change it, if it bugs you- look up the wheel settings
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 02-11-2019, 05:16 PM
Its Log!
Default 02-11-2019, 09:56 PM
Its Log!
Overboost galore.
Can you get me a clean log in just 3rd?
2k to redline WOT.
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 02-12-2019, 10:02 AM
All this overboost makes me so nervous, should I try 35?
Default 02-12-2019, 10:54 AM
Sure- but you need to make sure you are in 3rd gear for logs. Not 2nd
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 02-12-2019, 03:53 PM
OK first one is at 35 and the second is 30
Default 02-12-2019, 11:55 PM
Something is off here you are way overboosting.
Just to double check- you are running the HYBRID BEF, your JB4 is set to 4/2?
Meth add should be 0 as well- u aren’t running meth
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 02-20-2019, 03:09 PM
Was on Pump, there's no Hybrid Pump for the I8 on MHD. I typically try to do one thing at a time when tuning, so I wanted to get it going on low boost without E85 mix or water meth first. So now it has a E40 mix and Hybrid Race BEF. Is it possible I need to adjust the wastegate actuators? I put vacuum to them and by eyeball they seem to be fully closed at 5" of vacuum, which worked great on the last N54 with MMP I did. I lifted a little early here, felt a bobble/misfire or something
Default 02-21-2019, 09:55 AM
You can manually adjust (tighten or loosen) the WG- I have heard of wg isssues on a few local MMP sets.
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 02-21-2019, 10:39 AM
Yeah, done it on many others, sounds like its necessary on this one, stay tuned lol
Default 02-21-2019, 02:43 PM
#n54life lol
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Lancia Delta
Default 04-02-2019, 02:40 PM
OK, so checked WG actuators and have them set to close fully around 7" of vacuum. No change, pulling hair out. Noticed menu 12 set to 5. That shouldn't cause me this problem should it?
Default 04-02-2019, 02:46 PM
Have a current JB4 log?
Car: Lancia Delta
Default 04-02-2019, 03:31 PM
This one's from a couple weeks ago, but nothings changed
