Originally Posted by JonEQuest
I can tell you that I have the 750-cc injectors and they may be slightly oversized. I am currently down to 30 for fuel bias. I am definitly NOT an expert on this but bigger may not be better.
Kit has been fully installed in the car for over two weeks now and I have yet to get the port injection to work
Recheck the wiring multiple times
it has the JB4 Port injection controller
I have tried multiple different settings from different forms
Fuel enrichment reads but the trim levels go to max
Zero on the wmi
(no water meth kit is installed Just looking for reading from the port injection)
Yellow wire is on pin 9
White wire on pin 15 db5
Purple wire with the black wire adapted on Pin 21
I open the unit up to check for power and the green light blinks
I have tried meth scaling on 99 and 100
Fuel bias at 50 all the way down
Boost additive 75
Menu eight on the JB4 set to 0
I have also replaced my JB4 board thinking that was the issue and yes both of them work with my anti-lag
The duty bias adjust itself to 50 after multiple test runs
I do not have an ethanol sensor yet so I didn’t change any of those settings
Running HPI 650 injectors the positive side seems to be opposite of the port injection but injector should fire the same on both positive and negative side which I tested them to make sure🤷🏽*♂️
I even taped in a lightbulb to the injector harness which I have yet to see anything happen.
Huge fail trying to upload the screenshots from my iPhone maybe you can decipher these🤦🏽*♂️🤦🏽*♂️
Meth Prime/Purge
Boost Additive (0-75)
Signal Scaling (0-100)
Min Flow Boost (PSI)
External Output
Purge
75
100
2.0
Enabled
Min RPM
Max RPM
Min TPS
Min Gear
Min Advance
Min AFR
O
0
0.0
0.0
Ethanol Setup
BitO: JB4 2/3 FlexFuel Input
Bit1: JB4 14/15/16
FlexFuel Input
Bit2: DTML FlexFuel Input
Bit3: DTML WMI Input
CANCEL
SAVE
Default Wastegate Pos
PID Gain
Auto Shift Boost Redux
FF/Wastegate Adaption
Fuel Open Loop
Meth Safety Mode (0-3)
Meth Trigger Mode (0-3)
Max Boost 1st
Max Boost 2nd
Max Boost 3rd
Future Use A
TAP Setting
6-Cyl Timing Logging (0-6)
18A0S = 4, IJEOS = 5
dIl LTE
29.0
75
25
60
137
60
0
0
0.0
0.0
0.0
Options
Bit O: Disable Wheel Controls
Bit 1: Disable WG Adaption
CANCEL
SAVE
