eddiefromcali eddiefromcali is offline
Car: 2022 Tundra
Default 03-14-2022, 03:53 PM
Terry,
Did you guys do anything to the traction control when on the dyno? I've had other cars on the rollers and we've always pulled a fuse or relay but not sure about this truck.
I want to do a before and after and just want to make sure I don't waste the shop's time while I'm there.
Default 03-15-2022, 10:04 AM
Payam did the runs but other than push button disable I don't recall any issues.
Default 03-15-2022, 01:26 PM
No issues with getting it on the dyno and turning off traction control.
Car: 2022 Tundra
Default 03-16-2022, 09:04 PM
Thank you! Were pulls started in a specific gear? Manual mode shifting?
Default 03-18-2022, 04:17 PM
5th gear, manual.
Mmk23 Mmk23 is offline
Car: Land cruiser lc300
Default 03-23-2022, 03:56 AM
I think itís time to update maps 👍🏻
BoTurki2022 BoTurki2022 is offline
Bo.Turki
Car: 2022 TOYOTA LAND CRUISER 3.5 TT
Default 03-23-2022, 11:52 PM
Originally Posted by kwihk
Hi just did some log on dyno
with stock, map1 ,map2, map5.
running on 98 fuel , complete stock car.
good increase on torque but nothing on HP...
map2 was disappointing. map1 had the best graph for sure.
sharing files~
hope we get some better number
Strang !!
I've got massive power gain on all maps !
what I found out that some car will show the power gain after 10-20KM odo riving, note that new ecu's will need some date feedback from the sensors to relearn.
In my personal car 2022 VXR it take around 10KM odo for adoption.
Bo.Turki
Default 03-23-2022, 11:56 PM
Originally Posted by Mmk23
Is there any updates coming for the maps?
App got an update last night so check if any reflect on map's, If not it will be released soon and for the main time stick to map3 on pump gas with some octan booster or 10% methanol (blind with pump gas)
Default 03-24-2022, 05:15 AM
Where can I find the update
kwihk kwihk is offline
Car: LC300
Default 03-24-2022, 12:12 PM
is the tune completely identical for lc300 and tundra ?
because i have the tundra jb4 installed on my LC300...
Default 03-24-2022, 01:19 PM
It’s same
Car: 2022 Tundra
Default 03-26-2022, 10:29 PM
I dont see an update for the Android version of the app since 10/21/21. The only firmware available via the app is "JB4_P85_TOYOTA_1"
Default 03-27-2022, 08:29 AM
That is the current firmware for them.
Car: 2022 Tundra
Default 03-27-2022, 08:31 AM
Thank you, Terry!
Car: 2022 Tundra
Default 03-27-2022, 10:26 PM
Question for you guys. Is the boost I'm seeing in the jb4 data logs the actual boost or what the truck thinks it's seeing?
Default 03-28-2022, 09:39 AM
Boost and boost 2 is what the car is making. Ecu PSI is what the car thinks it's at.
Car: 2022 Tundra
Default 03-28-2022, 03:48 PM
Thanks again for the prompt responses guys! Still learning and want to make sure I'm reading all this right
roboots21 roboots21 is offline
Car: 2022 Toyota Tundra
Default 05-05-2022, 09:56 AM
Have you guys been able to make any progress on incorporating some of these additional CANBus signals into the JB4 Tundra firmware? I was hoping to be able to put things like IAT and Trans Temp up on my gauges but they currently aren't captured by this firmware. Any thoughts?
Default 05-14-2022, 05:24 PM
Keeping busy around here...
Car: 2022 Tundra
Default 05-14-2022, 05:27 PM
[youtube]oVB8s7IC0YQ[youtube]
That's awesome. Will this support Sport + as well?
Default 05-14-2022, 05:30 PM
Heck yeah! I'm liking what I see here!!!
Default 05-15-2022, 07:27 AM
I don't see why not, although our truck doesn't appear to have Sport+ mode as an option. If you have it drop me a JB4 log at idle with that mode selected, I'll see if we're reading it properly!
Default 05-20-2022, 10:25 AM
Terry .. I downloaded and flashed the beta FW to my JB4. I note that some more gauges are functional (yay!) and that the option of the drive mode switching shows up. I normally have Map 1 selected right now, and I enabled Bit 0 in options to attempt to do the drive mode map switching. For some reason, all drive modes (ECO, Normal, Sport) stay at Map 0. I've tried various times to switch maps in both Normal and Sport, and the app never shows the map different than 0. When I switch off Option Bit 0, I can see that Map 1 is selected for all 3 drive modes. With this being Beta, I don't expect a near term fix and perhaps I'm doing something wrong, but if I can provide anything like a log or what not, please let me know! Perhaps the app isn't showing up correctly?
Default 05-22-2022, 08:39 AM
You're the one who emailed me about this same issue right? We'll see what sorts of problem reports come in. It's a new feature so always possible its buggy.
Default 05-22-2022, 08:45 AM
Correct .. that was me.
