FluffyManogos FluffyManogos is offline
Car: supra mkv
Default Typical data log review if anyone is so kind to do so - 05-22-2022, 06:38 AM
Hello,
First time ever using JB4 or data logging.
2020 supra 3.0
Road was a little bumpy but did a 2k to redline WOT pull in 3rd gear as best i can.
Can someone please review and let me know if everything looks okay?
Bigggg thanks!!!!
Car: Evo VIII
Default 05-23-2022, 04:59 PM
Have you flashed a BEF yet? If not we would highly recommend it. Also try some E30 if you can and upload another log.
Please post in the proper B58 section next time. Thanks!
Car: supra mkv
Default 05-23-2022, 09:21 PM
Thanks for the reply Cannon. Okay i got a couple follow up questions and concerns. i would like to avoid fuel blends for now because its a hassle for me to pump my own gas because i live in jersey (i hate jersey for this). also, i understand that JB4 and a BEF flash is a very competent setup but the main reason i bought the JB4 piggyback tune is to have a piggyback tune that wont interfere with the dme. so if i have to flash a tune for the JB4 for my car to work properly i dont see a point with staying with the JB4?? i understand the monitoring and gauges the JB4 offers but i think i couldve just went with MHD with the monitor license and MHD OTS map that will fix my timings and get the same results because ill be flashign a tune anyways piggyback or not?? idk. i just need help if i should spend the extra money on an MHD license to get the BEF for the JB4 or just return the JB4 and just use MHD OTS map. I hope im not sounding rude. Let me know your thoughts. Thank you!!
Default 05-27-2022, 07:46 AM
Followed up via email, but your map2 log on pump gas looks perfectly normal. Adding in E85 or the BEF are nice options if you're looking to find ways to make even more power. But that just comes down to your individual needs.
