Turbo13 Turbo13 is offline
Car: 2022 TLX Type S, 2011 EVO X, 1991 MR2 Turbo
Default 03-09-2022, 01:18 PM
Hello. Just purchased the JB4 for my 22 TLX Type S. Will I get the updated MAF connectors?
Default 03-09-2022, 01:55 PM
Yes, all new systems will come complete with MAF connectors.
SerenityNow SerenityNow is offline
Car: 2022 Acura TLX Type S
Default 03-14-2022, 05:21 PM
Another log on more mild starts and in Sport mode on Map2. Does AFR look stable enough?
Default 03-15-2022, 01:33 PM
Overall it looks normal and pretty healthy but I would let the car warm up a bit more before getting on it. Oil looks to be at 120F when you first got on it. We usually wait until 160F to start playing around.
Default 03-16-2022, 12:55 PM
Any recommendations: this morning under normal driving conditions on Map2, the JB4 stopped connecting (it wouldn't reconnect and was failing at the handshake step). About 5 mins later the Type S went into limp mode. I pulled over and disconnected the JB4 and started back up (took a little push on the gas to get it to fire up again in stock mode). CEL stayed on, but later in the day I reconnected the JB4 and it was able to connect. CEL was off, but I pulled these error codes from the JB4: P0108, P1B01, P0355 and P5500
Any thoughts on the cause?
Default 03-16-2022, 01:57 PM
Any recommendations
For tech support on BETA products you'd have to email me the details. terry@burgertuning.com.
Buckeye3701 Buckeye3701 is offline
Car: Acura TLX Type - S
Default Me too. - 04-03-2022, 01:58 PM
I had the same thing happen, freaked me out a little. Was this just in Map 2 or did you have it happen any other time.
JB4 installed with MAF connectors (thank you!) along with PRL drop in filter and P2R intake tube. Definitely a noticeable gain especially once the turbo spools up. Still a little lag at the beginning of full throttle - is that tunable? One weird thing on my first WOT on Map2 and in Sport+ mode (logs attached): half way though there was a huge power cut. Very noticeable during the run. How does the log look and any thoughts on why the power cut?
Default 04-09-2022, 09:40 AM
About to install my JB4. What is the best way to share data logs with you all and get quick responses?
ticklemedaly ticklemedaly is offline
JB4 Noob
Car: 2022 Acura MDX Type-S Adv
Default MDX-S Dyno? - 04-10-2022, 03:40 PM
Hate to highjack, but given this is new for Acura TLX/MDX it would be safe to post here...
Are there any dyno runs for the MDX-S yet? I finally took delivery of my long-delayed '22 MDX-S and installed the JB4 today. Will play around with it over the coming weeks but was hoping there was more info on what to expect. Will stick with Map 1 for now, but excited to report it pulls MUCH harder. Once the rain stops I'll run the Dragy numbers too.
Default 04-11-2022, 10:07 AM
As it's BETA you need to email me, terry@burgertuning.com
Default 04-11-2022, 10:28 AM
Since the engine is the same the numbers and gains will be similar. Glad you can feel the difference on map 1, just wait till you go up in maps with higher octane fuel
Default 04-17-2022, 04:53 PM
Havenít had it happen again (running in map 2) after tightening up the connections at the OBDII and MAF connectors. Looks like it was probably a loose connection. Everything is running great now!
hellhorseperformance hellhorseperformance is offline
Car: Acura TLS Type S
Default 04-19-2022, 12:12 PM
I probably pasted right by it, but is there a MAP guide anywhere for this, outside the app to look at? (waiting on my Type S to return from PPF/Tint) so consuming all the data for when we can slap this JB4 in.
Default 04-19-2022, 03:07 PM
Added to the first post
Jonplavist Jonplavist is offline
Car: Civic
Default 05-12-2022, 12:50 PM
What is the "safest" map to run on 93 octane for the Type S?
FckFiat FckFiat is offline
Default 05-13-2022, 09:10 PM
I think Map 3 but don't quote me on it. I ran map 1 for the first time tonight. Just a little bit of fun but certainly a big difference.
Default 05-14-2022, 08:38 AM
Map0?
Map2 is meant for 93 octane though!
Car: Civic
Default 05-14-2022, 09:46 AM
Lol, ok thanks dudes
2022MDX-TYPE-S-BLACKOUT 2022MDX-TYPE-S-BLACKOUT is offline
Car: 2022 MDX TYPE S
Default new here. - 05-20-2022, 10:06 PM
Hello friend,
Got my acura mdx type s couple months ago. Found this site. I'm about to pull the trigger getting the jb4. Can you post some videos how the engine sounds when revving and when idle? been looking everywhere the jb4 seem to be what we needed. thanks.
Default 05-24-2022, 06:34 PM
Originally Posted by 2022MDX-TYPE-S-BLACKOUT
Hello friend,
doesn't make any sound difference. Just runs different boost parameters.
Default 05-24-2022, 08:56 PM
thank you! you think I should order and install it now or wait until it breaks in to 5000 miles? and is it easy to install or should I go to a local mechanic?
Default 05-25-2022, 10:17 AM
No need to wait that long for break in. We JB4 our cars with less than 500 miles on them
Check out our install guide, it's super easy to do yourself.
Car: Civic
Default 05-26-2022, 08:23 PM
Anything in the pipeline regarding revisions or additional power or are we tapped out?
Default 05-29-2022, 10:51 AM
We're still rolling out BETA systems. The plan is to keep maps as is until we're sure they are 100% solid over a wide range of conditions and then once we remove the beta tags we'll jump on to developing higher power maps.
Car: Civic
Default 05-29-2022, 12:57 PM
Sounds good Sir ����
