rocksandblues rocksandblues is offline
Car: 2008 335
Default Newbie no start - 01-16-2019, 06:11 AM
Will try to figure out the search function too..
2008 335, bought the shopping list of *********, intercooler, intake, charge pipe, and of course JB4
Followed directions. no start. left battery disconnected and was able to pull cam shaft sensor?? car ran perfect before all the bolt ons...
where to start trouble shooting?
thank you
Car: 2013 Genesis Coupe
Default 01-16-2019, 06:22 AM
JB4
Default 01-16-2019, 06:23 AM
thank you
You probably did not install JB4 correctly
Car: 2008 335
Default 01-16-2019, 07:16 AM
kinda figured that...
That is why I am here
in searching I am reading about arrows on opposite sides...
codesx codesx is offline
Default 01-16-2019, 10:21 AM
thank you
Please define "no start" further.
Money's on JB4 install.
It's not uncommon where a connector isn't fully seated.
Also, if it's 'jammed' into the ECU housing and not properly laid out without stress on connectors, you're bound to hit issues.
2008 335i Convertible, E93, N54, A/T
JB4 Map 1, PUMP BEF, 94 Octane (15 PSI)
xHP Stage 3 (v2.0)
Ultimate Racing CAI (selling)
VRSF CP
HKS BOV
NGK 5992 Plugs @ .020
Parts I have/ordered and am now working to install:
BMS WMI
BMS FMIC
BMS OCC
BMS DCI
RB PCV Valve
Maintenance:
2018 - Plugs, Ign Coils, Walnut Blasting
2019 - Valve Cover Gasket & OFHG (pending)
Default 01-16-2019, 10:22 AM
Oooo. Don't connect them backwards :/
xHP Stage 3 (v2.0)
VRSF CP
HKS BOV
BMS WMI
BMS FMIC
BMS OCC
BMS DCI
RB PCV Valve
Maintenance:
