VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 12-15-2013, 02:08 AM
Originally Posted by SteveAZ
This is great..glad to hear the N55 guys will have a viable option. Nice work!
Somebody get one of these on a 2012 so we can see what that HPFP is capable of!
as soon as it ships to my house next week it will be on my 2012 let the fun begin
<-- Click for the build thread Full 1M bodywork,ONE EIGHTY HL,Carbon hood,trunk,side skirts,black lines,CKS coil overs, Sparta Evolution 2 piece rotors , PURE Stage 2 Turbo 24psi e65
CJ2 CJ2 is offline
Car: 335i F30
Default 12-15-2013, 05:37 AM
It was a good day. Next time I'll need to try remembering everyone's username/real name so I know who I'm talking to here.
2013 F10 M5 | PS2 | JB4+BCM | Bootmod3 | BMS Intake | BMS CP's | ER **'s | SSP Spec-R | Meth
10/15/16 Goodbye old friend - 2012 F30 335i | PURE stage 2 turbo | JB4 | BMS intake | ER down pipe | ER charge pipe | ER FMIC | E60 | Meth
BMDUB1 BMDUB1 is offline
BMDUB1
Car: 2011 335i N55
Default 12-15-2013, 07:14 AM
Incredible.....
BMDUB1
Car: 2011 335i N55
Default 12-15-2013, 07:20 AM
That 12.2 was a great run pal, Congrats!
DaleM's Avatar
DaleM DaleM is offline
Band
Default 12-15-2013, 08:00 AM
Just got back from Famoso raceway. Fun day overall and great conditions. I'm fairly exhausted so I'll keep this short for now.
The car is our 2011 N55 335i Steptronic w/ 50k miles.
Mods:
JB4
Vargas N55 Turbo
AA Intercooler
CPE ********
BMS chargepipe
BMS OCC
BMS intake
BMS 2.2g meth
Back end flash
50% E85
Kosei K1 rims all around with Nitto 245/45/17 555R tires out back
Pasasnger seat removed, driver weight 185#
Results;
Managed a best of 11.42@123.10 w/ 1.85 60'. 2nd gear launch. Probably another .3ths in this with more boost and a more aggressive launch.
Terry,
What would our suspension need to make times like this guy in the 60ft? Perhaps I should say, what would you need to get sub 1.60s?
http://www.svtperformance.com/forums...l#post13730232
LOL at his worst being a 1.27! I love the in cabin camera, this guys shifts are impressive. I passed his trailer a couple times on the Interstate a couple times this past week, now I know what car he was towing. He probably won't be going to best Buy in that thing.
Vae Victis!
If you are not going Juice Box then you are going slow.
CJ2 CJ2 is offline
Car: 335i F30
Default 12-15-2013, 08:05 AM
Thanks brotha. It was a lot of fun.
I really want to try running the 1/4 with something besides my 20" BMW OEM style 361 wheels. Looks like a good option would be to swap some K1's onto the car for the day.
BMDUB1
Car: 2011 335i N55
Default 12-15-2013, 10:19 AM
20"?? Damn!
That would be a good idea..
Great job
seroga1986's Avatar
Default 12-15-2013, 05:13 PM
Nice on the record T !!! How are the nt555r's? I had MT's ET streets and those were just dangerous at high speeds. Would you recommend hoosiers for 1/4 mile runs or nt555r?
2008 135i Sport 6at
2013 X3 xDrive28i M-package
Default 12-15-2013, 06:26 PM
I've been running 555Rs on all my cars for years. I love them. Good traction, fine in wet weather, good 10-12k mile wear, etc.
Manson3680's Avatar
Manson3680 Manson3680 is offline
Car: 2012 335i
Default 12-16-2013, 10:04 AM
With the stock turbo 2nd gear launches are much better. With the larger turbo it could go either way. But the 2nd gear launch times were faster than the 1st gear launch times. So I stuck with that most of the day.
So at what rmp would u launch out at in 2nd gear? Looking forward to trying that out as I need all the help I can get. Also seen ur mods list and am interested in getting the back end flash done to my n55. Is that flash available yet or still a work in progress for the n55 public. If available will it be able to be done with a bt cable?
2012 E92 335i xdrive 6mt | Jb4 g5 ISO | Bms intake | intake scoops | cpe charge pipe | Vrsf 7" FMIC | Vrsf ******** | custom Straight pipe | Muffler delete | flex fuel wires | 55/45 e85 e93 |H&R sport springs | Bms short throw clutch stop | Bms modified clutch valve | bms cowl filters | Avant Garde M359 19" staggered wheels | Falken 265/30/19 | bms 12" spacers |
Default 12-16-2013, 10:07 AM
Launching was really tough with this setup. It was a fine line between bogging and running 11.7x, spinning and running 11.8x, and hooking well with enough boost and running 11.4x. More tuning in the spool up range, adding more advance, may help making the launches easier.
trebila's Avatar
trebila trebila is offline
Default 12-16-2013, 10:25 AM
Thanks Terry, I've lowered the fuel scalar to 1.33, and set Open loop fueling to 80, and all is fine.
GetSomeE92 GetSomeE92 is offline
Car: '09 E92
Default 12-16-2013, 10:58 AM
Originally Posted by DaleM
Terry,
I don't think it is possible. The 335i won't fit that kind of tire without serious modification. Plus, no 335i is making close to the kind of power to get into the 8 second club. Also, even though the Terminator came with an IRS, I'd bet he has swapped in a much stronger live axle to handle those launches. That just isn't available for the 335i.
You could probably get into the 1.6s with a lot of modification, and the right tire, but it would probably be easier with an xi model.
335i Coupe: E85 BB flash, JB4 G5 ISO (map 7), DCI and 60% E85 blend: 11.7 @ 120 mph.
Former Best with JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
NeoN's Avatar
NeoN NeoN is offline
Car: 2011 335i X Drive
Default 12-16-2013, 01:07 PM
Those are fantastic numbers. Wow! Great work Terry glad to see the car is coming along..
How does it drive compared to stock? Compared to an N54 RB Car?
2018 C43 AMG Black/Black
JB1 Map 2
Full 20% Tints All-Around
Custom Front-License Plate
Check my YouTube [https://www.youtube.com/channel/UC8K...as=subscriber] Channel for more
paradoxical3 paradoxical3 is offline
Car: BMW x1 35i xDrive
Default 12-16-2013, 02:10 PM
1.6 is cake for xi models. I'm at 1.63 in my X1 on stock 19in runflat tires with a N55. I would expect an aftermarket turbo xi with sticky tires to be in the 1.5's. Or you could just take the car to ATCO and get like a 1.3 :p
Default 12-16-2013, 02:12 PM
All around it drives pretty nice. I'd say comparable to an N54 RB car running something like map 7.
hakentt hakentt is offline
Car: E92
Default 12-16-2013, 08:47 PM
I knew N55 is state of the art motor. E90 is a heavy car. I know that N55 would rock in lighter chassis like E36. With a massive 500 foot pound of torq, are you kidding me
infliktyd135i's Avatar
infliktyd135i infliktyd135i is offline
Car: 09 135i
Default 01-03-2014, 01:18 PM
which car would be faster in a 1/4 mi drag and or 1/2 mi roll racing situation with a AVERAGE driver, a 6mt n54 fully loaded e82 with vtt stg 2/rb's @ 500/500 or a n55 e92 auto with vtt turbo @460?
335iFFM 335iFFM is offline
Default 01-03-2014, 04:41 PM
N55 has a much lighter powertrain so it might be a draw but I think the N55 is faster because you are able to maintain 20psi of boost troughout the power band. The N54 will taper off.
335i N55 DCT
Newguy123's Avatar
Car: 12' 135i
Default 07-23-2014, 09:29 PM
questions.... Was this the Vargas stage 2 turbo? If so what would one expect from the stage 1 as far as WHP and 1/4 mile?
Is it possible to launch in 2nd with my DCT and boost? Or am I stuck to 1st gear roll ons? I know I have the launch mode but it's at 5500 and just wastes time
18 Glacier white RS3
#PURETURBOS
#FUELIT
Peter @ Pure's Avatar
Car: F20 M135i
Default 07-23-2014, 10:02 PM
I ran 11.88 with pure st1 at 120.7
F21 M140i - currently stock
Audi TTRS - 100-200: 5.1, 60-130: 6.0
F80 M3 - 100-200: 4.6, 60-130: 5.3
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 07-23-2014, 10:16 PM
What was your 60ft? That's a pretty quick trap, what transmission does your car have?
Newguy123's Avatar
Car: 12' 135i
Default 07-23-2014, 10:41 PM
That's great I live about 5 miles from them! Did you notice big difference in the pull?
#PURETURBOS
#FUELIT
Car: F20 M135i
Default 07-23-2014, 11:03 PM
60ft was 1.85. I have 8 speed auto transmission. But do shift manually with stick.
peter@pureturbos.eu
pureturbos.eu
