dannyq2 dannyq2 is offline
Car: 2016 340i Xi
Default 1st log review's 2016 340Xi - 04-11-2020, 02:33 PM
These are the first logs for this new installation. Firmware is V16
2016 340 Xi
63 Degrees F
35% humidity
3000 ft elevation
91 octane
Only mod is a BMS intake.
1st 2 runs are on Map1, 3nd run is map 2. Don't know what the others are, I really didn't do any other full throttle runs,
Please let me know how it all looks and any recommendations.
Thank you
Car: 2016 340i Xi
Default Looking for direction - 04-15-2020, 11:28 AM
I would like to get some direction on how the logs look and if I can go to Map 5.
Default 04-16-2020, 09:36 AM
Runs look OK to me, some timing drops, but to be expected on 91 octane. Is mixing in E85 an option to get octane up?
As it stands on this fuel I'd keep it on map2. But adding in EWG connector would be helpful on the tuning end to get boost up a bit.
Car: 2016 340i Xi
Default Looking for direction - 04-16-2020, 10:16 AM
Thank you for the reply. I do have 93 octane I can use, E85 mix will not be in the cards, it's a long ways away. Is Map5 a "learning" map? Or it is not useful in my case? I will get the 93 octane, that should help. I just needed a base line to go off of. I will install EWG after I take care in for it's service in June. I will be removing the JB4 for the service visit.
