sunnys1 sunnys1 is offline
Car: 340i
Default 340i Cutting out - drivetrain error - 11-19-2019, 01:49 PM
Hi - i'm running map 3 on my B58, and during acceleration it hits me with drive train error and puts me in limp mode. i've attached logs.
Car: 340i
Default 11-19-2019, 03:10 PM
Code thrown 1f053c
Stock car no mods except jb4.
Fuel is UK 99 RON she’ll vpower
Car: 335i, 2009
Default 11-19-2019, 04:23 PM
Seems like you are not the only one.
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Jormy Jormy is offline
Car: '17 M240I
Default Same - 11-19-2019, 06:28 PM
Also happened to me on stock 240i
Been lookin around but didn't find valuable reliable information
JBoe JBoe is offline
Car: M240i
Default 11-19-2019, 11:00 PM
Looks like the car is trying to save itself. You are lean with AFR, DME is pulling back boost, timing has multiple drops, etc. Get a log on map 1 and let's review. Also, update to the latest firmware V14 before you relog.
Do you have EWG and/or Fuel harnesses? Personally I've never seen a stock car on pump gas run map 3 well. The stock fuel system usually hits it's max in that scenario.
AFE Drop-in Filter
BMS Meth Kit (100% M1)
Muffler Delete
CA 91 Piss Gas...
(8oz Boostane 95ish Oct)
E85 (2Gal/Fill)
BEF (Race_WMI)
JB4 (Map 7 - Add 45... 19-20psi)
Car: 340i
Default 11-20-2019, 02:47 AM
Which one should I use
Car: 340i
Default 11-20-2019, 02:49 AM
Originally Posted by Nanometer
Ah nightmare! It happens when traction control kicks in
Car: '17 M240I
Default 11-20-2019, 09:16 AM
Really ? Makes sense for me, because it happened while takin off from a light, but roads were quite snowy and slippery, I was part throttle in gear 1-2-3, no hard accelleration....just casual driving.
However I spent a lot of time getting sideways anytime I can, and it only happened once...
Car: M240i
Default 11-20-2019, 03:18 PM
Use 14.hex and do not turn FUD6 on since you are not using the BEF. That uses same mapping structure you're used to, but offers more accurate logging parameters to view.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
Default 11-20-2019, 05:02 PM
Generally easily resolved. We've disabled that fault in the BEF maps (just posted latest files with fault disabled, make sure you have latest MHD app to update), and if you are on the stock flash then you just need to limit boost in 1st gear to avoid triggering it.
Car: M240i
Default 11-21-2019, 09:39 PM
I have the BEF and still limit boost in 1st and 2nd. Currently set at 6 and 4 respectively. Otherwise the car is out of control. It's still slippery at those levels, but easily managed. I'm not a drifting guy... it's all about speed for me.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
