cjet68 cjet68 is offline
Car: 2011 BMW 335i N55 M Sport
Default 2C90, 387F, & 2C57 codes Help needed - 08-21-2018, 05:26 AM
Yesterday afternoon, as I was getting on the highway, light throttle, I got the following codes.
2C90 present
387F not present
2C57 not present
Codes have not appeared again and engine seems as quick as ever.
Was running Map 0.
93 octane
no other mods besides BMW Performance Edition, dealer installed.
Retrieved codes using a Foxwell nt520.
Thanks, Chris
Default 08-21-2018, 07:54 AM
2C90 present
387F not present
2C57 not present
Was running Map 0.
93 octane
Thanks, Chris
Can you post descriptions ?
Default 08-21-2018, 09:11 AM
Blow off valve jammed closed
Power management standby current violation
Charging pressure control plausibility pressure too low
In order of codes from title.
Default 08-21-2018, 02:01 PM
When you clear, do they return?
Default did not clear the codes - 08-21-2018, 07:09 PM
After the codes appeared I parked the car for about 2 hours. When I restarted the car the check engine light was NO longer illuminated and when I went into Check control function it said all OK.
I read the codes later that day and left them in there just incase.
The codes have not reappeared as of tonight and I've driven about 50 miles since then. Car feels good, strong.
Default Codes Still Present - 08-30-2018, 05:50 AM
I am still getting the 2C90 blow-off valve jammed closed, 387F power management standby current violation, and 2C57 charging pressure control plausibility, pressure too low.
Do you think it might be the Pneumatic Wastegate Control Valve(BMW Pressure Valve 11 74 626 351) ?
Codes have not appeared when running Map1 with JB4.
Codes only appear when running Map0.
Jon @ BMS's Avatar
Jon @ BMS Jon @ BMS is offline
Administrator
Default 08-31-2018, 10:01 AM
What year/model vehicle? Got install photos for us to look over?
It is the sole responsibility of the purchaser and installer of any BMS part to employ the correct installation techniques required to ensure the proper operation of BMS parts, and BMS disclaims any and all liability for any part failure due to improper installation or use. It is the sole responsibility of the customer to verify that the use of their vehicle and items purchased comply with federal, state and local regulations. BMS claims no legal federal, state or local certification concerning pollution controlled motor vehicles or mandated emissions requirements. BMS products labeled for use only in competition racing vehicles may only be used on competition racing vehicles operated exclusively on a closed course in conjunction with a sanctioned racing event, in accordance with all federal and state laws, and may never be operated on public roads/highways. Please see http://www.burgertuning.com/emissions_info.html for more information on legal requirements related to use of BMS parts.
Default 387F, 2C90, 2C57 codes continue - 08-05-2019, 12:33 PM
I get these codes from time to time.
Oddly enough it happens when I am taking a left turn, like getting on the highway/freeway.
Codes go away after shutting the car off for 10 minutes
Ideas appreciated on what to check. Maybe poor voltage connection?
Thanks for ideas or links to help solve!!!
2011 335i N55, JB4, BMS chargepipe. 37K miles
