Ads5053 Ads5053 is offline
Car: 2011 335is
Default Intake vavle cleaning - 07-08-2015, 07:57 AM
Quick question after I spray the carb cleaner and scrub with the wire brushes. How do I suck out the liquid? I don't want to use the shop van in fear of a boom. I currently use a oral ssyringe with a tube attached to it but it still leaves a little pool.
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 07-08-2015, 08:02 AM
paper towel?
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
max's Avatar
max max is offline
Default 07-08-2015, 08:33 AM
Why not use compressed air to blow out the tiny bit of remaining liquid?
Drives 2011 335is
NOTE: Post count does not reflect any actual knowledge about anything.
Grip Grip's Avatar
Grip Grip Grip Grip is offline
Default 07-08-2015, 08:49 AM
What boom? I don't get it? How's a shop vac going to hurt anything?
2009 335i XDrive (wife's)
Sold - '11 335is - N54 - DCT
Sold - '07 335i - 11.8 @ 120
Sold - '08 128i (wife's)
Car: 2011 335is
Default 07-08-2015, 10:18 AM
They say the fumes from the flammable liquid can spark with the shop vac. Alright I'm currently using my blow gun and paper towell.
Car: 2011 335is
Default 07-08-2015, 10:20 AM
BTW I want to yet walnut blasting if someone has the tool for it please let me know. I just need someone tl scan it via cell phone app so I can 3d print it.
Default 07-08-2015, 11:14 AM
Dont use carb cleaner, its bad for the stem seals. I guess others have done this on the N54 but in general its a bad practice to fill the chamber with carb cleaner. Use a towel and air compressor to blow out if you did. You can use a detergent based cleaner but I would stay away from ether base solvents. You need to just walnut blast the head. You can make all the tools you need for 50 bucks at harbor freight.
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 07-08-2015, 11:33 AM
I am in the process of doing this, but don't really have any idea what to get. What do you mean by "50 bucks at harbor freight"?
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
Grip Grip's Avatar
Default 07-08-2015, 12:23 PM
Thanks, I follow now.
Car: 2011 335is
Default 07-08-2015, 12:40 PM
Looking forward hearing What I should buy from harbor freight. I thought I needed the shop vac adapter so that shells don't go everywhere.
Car: 2011 335is
Default 07-08-2015, 12:48 PM
Don't mind my poor typing. I'm on my phone with it's wacky keyboard.
19e92's Avatar
19e92 19e92 is offline
Car: 2007 335i Coupe
Default 07-08-2015, 01:11 PM
I did the intake cleaning last month with carb cleaner. I used 2 cans of carb cleaner, a roll of blue shop towels ($2), a few brass gun cleaning brushes, some brass "toothbrushes".
Please make sure your valves are full closed. I bumped the engine with a switch connected to the starter solenoid to ensure that each valve I was working on was fully closed.
I sprayed carb cleaner in the valve area and then scrubbed with my wire brushes. I had a wand with some thin 1/4 inch tubing hooked up to my compressor to blow out most of the debris. I would then use shop towels to wipe the area. I used a vacuum just to suck out chunks of carbon.
I got good at it so it was only taking me 30 mins / port. I'm sure you'll find a method that works great for you.
Goodluck!!
