(#126)
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 08-26-2018, 03:35 PM
Originally Posted by 135idct
any updates
I havenít had time to do anything unfortunately.
Car: 09 E92 SG
Default 08-27-2018, 10:23 AM
Does anyone know in the BEF which Throttle parameter is which?
Start-Pedal progression Special AT
Start-Pedal progression Sport
Start-Pedal progression Soft
Soft and Sport remain untouched in the JB4 BEFs, so I think its ECO and Sport+ mode. Could Special be Comfort mode and Sport be Sport mode? Is Start-Pedal auto and Pedal manual mode?
Car: 09 E92 SG
Default 09-05-2018, 12:05 PM
any updates
I found a finger-width hole in the silicone compressor outlet pipe. So It's just gushing air out the side. I'm thinking I must have touched it to the hot manifold the night I fixed the manifold.
Either way, Jeff sent me a new one that should be coming in today.
spammer's Avatar
spammer spammer is offline
Car: 435i
Default 09-05-2018, 12:44 PM
Nice! So there was a leak, glad you found it. Looks like a pain to locate.
Car: 09 E92 SG
Default 09-05-2018, 03:53 PM
The only reason I found it was because I knew that clamp on the compressor outlet was loose. While feeling around, my finger slipped into the hole!
135idct 135idct is offline
Default 09-05-2018, 05:12 PM
this part can handle the heat, the problem the unprofessional shop install the kit. im sure this part damaged not from heat.
Car: 09 E92 SG
Default 09-07-2018, 10:12 AM
The shop was professional. I believe I may have done this myself. I agree this silicon hose will handle the heat. I plan on replacing it this weekend.
Car: 09 E92 SG
Default 09-09-2018, 04:03 PM
Found and fixed the leak. Tomorrow I'll start tuning from scratch.
Default 09-09-2018, 05:13 PM
What was that touching ?
Default 09-10-2018, 08:21 AM
Excited!
Car: 09 E92 SG
Default 09-11-2018, 12:16 PM
The night that I fixed the wastegate, we went out to do pulls. That's when I realized the outlet clamp was never tightened because it wasn't really boosting. We got back to the house and while positioning the hose we must have touched it to the exhaust manifold and burned a hole in it. And it just got worse with time.
Excited!
I'm having connection problems with JB4 mobile currently so no tuning right now.
Car: 09 E92 SG
Default 09-13-2018, 01:08 PM
Currently trying to dial in some over boost issues but the car feels great. Keeping the boost at 20psi until the overshoot is dialed in.
Default 09-13-2018, 01:13 PM
I had to get terry to send me a firmware with spool mode partially or fully disabled. If you want me to send you the firmware send me your email. The spool mode made my speedtech constantly overboost.
Car: 09 E92 SG
Default 09-13-2018, 01:21 PM
PM Sent.
My FF adaptation and duty bias is slowly going down from defaults still. What are your settings at?
Default 09-13-2018, 01:22 PM
What's ur FF in jb4 settings in this pull?
Car: 09 E92 SG
Default 09-13-2018, 01:24 PM
It's at 52.
Default 09-13-2018, 01:58 PM
It's at 52.
u set duty bias all 50?
Car: 09 E92 SG
Default 09-13-2018, 02:08 PM
Yes and it has been slowly learning down.
duty_15 50
duty_20 50
duty_25 50
duty_30 50
duty_35 50
duty_40 50
duty_45 50
duty_50 47
duty_55 45
duty_60 48
duty_65 52
duty_70 50
Default 09-13-2018, 07:25 PM
duty_15 50
duty_20 50
duty_25 50
duty_30 50
duty_35 50
duty_40 50
duty_45 50
duty_50 47
duty_55 45
duty_60 48
duty_65 52
duty_70 50
try to lower FF
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 09-13-2018, 08:25 PM
try to lower FF
Lowering or raising the FF will lower and raise the entire boost curve. He needs to see if the over boosting is consistent at certain RPM and adjust dutybias if it is.
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
VRSF Chargepipe | BMS Intake | Custom MHD | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | AEM Meth Injection | Pure Stage 2 V3 | Pure Inlet | GFB DV+ | AR DP |
Default 09-14-2018, 05:43 AM
You’re close. I send you a spool mode disabled firmware but it doesn’t look like you need it since at max throttle it’s not putting wgdc at 100 like mine does. Default pid gain is 25 and you’re at 15. Typically you keep at 25 until smoothing curve and then can tighten. You looks close. I would move ff down 10-15 and let it learn up and go from there. If you get bad boost spikes then disable spool mode.
Car: 09 E92 SG
Default 09-14-2018, 09:52 AM
Youíre close. I send you a spool mode disabled firmware but it doesnít look like you need it since at max throttle itís not putting wgdc at 100 like mine does. Default pid gain is 25 and youíre at 15. Typically you keep at 25 until smoothing curve and then can tighten. You looks close. I would move ff down 10-15 and let it learn up and go from there. If you get bad boost spikes then disable spool mode.
Something weird happened today. I was at about 75mph cruising in 5th, manual mode. I gave it a little more than half throttle to pass someone and when I let off the gas it jerked pretty aggressively. Got a Drivetrain Malfunction for "1F0526 DME internal error: monitoring torque comparison" and hitting the gas did nothing. Tried to clear codes while driving but couldn't. Checked what map I was in and the JB4 said "invalid nap selection" and it magically ended up on Map 1. But when I checked the logs while this was happening it says I was still in Map 6. I had to pull over, restart the car, clear the codes, and switch back to Map 6.
Anyone got any thoughts on this?
Car: 09 E92 SG
Default 09-14-2018, 10:12 AM
This was on the JB4_F_EWG_16_TEST5 firmware.
1) Revised logic for absolute boost targeting maps resulting in smoother part throttle operation and the ability to set boost by gear values lower than the flash target.
HKD126 HKD126 is offline
Car: 2014 335i
Default 09-15-2018, 10:28 AM
Just curious, what spark plugs are you running on this beast?
Car: 09 E92 SG
Default 09-15-2018, 02:52 PM
NGK 97506
