TermiT TermiT is offline
Car: BMW E92 335i
Default Boost drop after 5000 rpm - 09-11-2021, 02:11 PM
Good day! Please help me to disassemble the log, when dialing 5000 rpm under the hood you can hear a crackle of 2 seconds "trrr", and then the boost falls. Turbines are hybrids Turbosystems, the car does not eat oil, does not smoke, the mileage on new turbines is 8000 kilometers
Car: 2008 E93
Default 09-11-2021, 10:38 PM
If you have silicone inlets, check and make sure they are not collapsing under boost.
Especially the newer VRSF.
Default 09-13-2021, 10:03 AM
Agreed.... you can see the boost drop and WGDC increase. Collapsing inlets, boost leak, intake filter issue, or ?
Car: BMW E92 335i
Default 09-14-2021, 01:02 PM
I pressurized the system according to the instructions from the forum, lost several small leaks, installed new solenoids, but the result is the same. The inlet inlets examined them intact, I assume that the rear one sucks, what could be the reason, the poor quality of the inlets? The new K&N filter is in its regular place.
Default 09-15-2021, 09:54 AM
If the inlet is collapsing, that's kind of hard to diagnose/see since it only happens at high boost.
Car: BMW E92 335i
Default 09-15-2021, 02:02 PM
Found the problem. fixed the camera and filmed the video in motion. The back inlet sucks in. Video starting at 2:00 minutes https://youtu.be/1etTscX2ovw
Default 09-16-2021, 06:29 PM
Nice job...you can definitely see it get sucked in!
